Question about Polaroid LCD-1750 17 in. HD-Ready Television
Power light gone after rainstorm . What can be done? This is a new TV.
  • 4,472 Answers
If it is a new tv then you should have it repaired under manufacturer 12 month warranty. I would call them directly at: 1-800-POLAROID to get this problem taken care of. If you need further assistance please let me know.
Thank you,
Lee
Posted on Aug 06, 2010
What do I have to do to repair my Toshiba smart LED TV
Hiu Annick,
The cause of this problem lies in the power supply board of your TV. Most probably the main dc filter capacitor, the thickest one on the whole board, 150mf/450v should be defective. If you open the back cover and check, you may find this capacitor swollen up at the top. Apart from this you may find some other small capacitors also gone bad.
Another thing, please never leave your TV in stand by mode for long hours, specially when you are not home. Any power fluctuation during this period can harm your set.
A word of caution, please be very careful if you want to do it yourself, because your set is a big one and any wrong move can damage the panel.
I hope this helps.
Good Luck.
Aug 25, 2015 | Toshiba Televison & Video
Kdl-52ex700 powers on but black screen
It's a faulty television. More than likely something in the mobo has gone wrong. I'd recommend returning the TV for a new one if you have that option, and if not, send it off to your manufacturer so that warranty work can be done on it.
Feb 22, 2015 | Sony KDL-52EX700 52" HDTV-Ready LED TV
During a rainstorm the electric power went out, and now I can not get the power back in my hitachi model 50UX58K.
see the indicator of your tv. if it is glowing then any of the IC may be gone bad. if not u need to check the power supply. these tvs has very complicated schematic diagrams.
Aug 25, 2011 | Hitachi 50UX58K 50" Rear Projection...
No pic
Your TV has gone into standby mode either because of what you may have inadvertently done or there is a fault in the power supply.
It may be a simple fix or could be a more elaborate problem that will require a technician.
Oct 28, 2009 | Sport & Outdoor - Others
Power went out today and the TV is not turning on now
Most likely when the power came back on, there was a surge that damaged the power supply board in your TV. If your TV is completely dead with no blinking or standby lights, then the power supply is bad.
The power supply is the first board that the plug from the wall is going into.
You can check this by taking the back cover off and check for capicators that have gone bad. These will be capicators that look bubbly on the tops that are budging out. If you see any and know how to solder, replace these capicators with the correct voltage and Farad readings that are usually listed on the capicators themselves. Make sure to mark which side the white stripe on the side of the capacitor is as the orientation is very important.
Replacing the capicators is usually a cheap fix but if you do not want to or cannot solder the capicators or if you do not spot any bad capicators, just replace the whole power supply board. This can be done by just unscrewing it off the LCD panel, disconnecting the connections to and from the board, replacing the new board, reconnecting, and screwing back in the new board with the same screws.
Oct 16, 2009 | Sharp LC-19SK24U TV
Won't power on
Your power board has gone out. If your tv is under warrenty then you can get it done for no cost. Vizio will send power board and main board and Tv tech will come on-site to install the parts.
Mar 17, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
No picture, no sound, power light stays on
this is a tricky one but i would say it could be a pannel inside that has gone with all the moving of the tv about you could hav just moved something inside that shouldent hv moved ( its easley done ) best thing to do is take it to a phillips dealer.
Mar 10, 2009 | Philips 60P8341 60" Rear Projection...
Samsung 40 inch lcd tv
the issue is with capacitors on the power supply board ,open your TV and look for caps with damage on the top,the caps are 110 volt change them to 120v
and your issue will be gone.
I have done this with four of this kinda of TV and all are working like a charm
Nov 10, 2008 | Samsung LN-T4065F Television
Red light blinking
thear two ic that have gone bad this set need to go to a repear shop for this work to be done.
Mar 30, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sound but no picture
sound to me a power supply problem but this is not my field, techman will help you.....good luck
Aug 08, 2006 | Toshiba 55H70 55" Rear Projection...
Polaroid LCD-1750 17 in. HD-Ready Television Logo
16 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
