Question about Mitsubishi VS-50605 50" Rear Projection Television
Mitsubishi Projection Television wont turn on
My television is not working. How do I check to see if the fuse(s) is out? Please guide me step by step. Is it worth have a technician out to fix my 7 year old tv? please advise. thanks.
  • lyjenny79 Apr 28, 2008
    Hi...... I checked the 4 fuses by the naked eye. It looks ok? I am not sure what a ohms meter is and how much it cost. Can I get is for a reasonable price and where? The model of my Mitshubishi is 45607. When I press the power, there is no light nor sound.
  • Mitsubishi Master
  • 8,617 Answers
Un plug the set first then remove the back, and depending on the model number you should have two or three fuses on the board on the right side where the power goes check them for continuity with an ohms meter. What is the model number of your set? Also does the led indicator light up?
Posted on Apr 27, 2008
  • Sonny Berry
    Sonny Berry Apr 28, 2008
    radio shach has them for reasonable prices. Or you can get one from this link and they also sell the service manual for you model and offer free on line tech support to help you repair your set. they email the service manual to you.
    http://servicemanuals.vstore.ca/
Power comes on and the back off.... Code is two flashes then paus then two flashes.... Where do I check to find fuses to the convergence?
This is a short protect error code. The affected parts is not only the pico fuses but also the convergence IC(STK393-110) that is mounted on the large aluminum heat sink. I have a link where you can buy the repair kit that includes steps-by-steps instructions that will guide you in the whole process of repair. Click the link below.
Mitsubishi V21 chassis(WS-65511) convergence repair kit ($42).
Scroll down to V21 chassis convergence repair kit.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Sep 13, 2011 | Mitsubishi WS-65511 65" Rear Projection...
Mitsubishi tv
Check 5A micro fuses F9A04 and F9A05 and if one or both are open replace both convergence IC's part# STK394-250
Aug 29, 2007 | Mitsubishi WS-55859 55" Rear Projection...
We have a mitsubishi diamond television the timer keeps turning off and now the television wont turn on at all
hi,
Your tv have problem with Digital module DM board. there seven filter capacitors (1000uf 16V ) in the DM board. if any one of it is faulty the this problem can occur. its a regular complaint for this model. just replace the capacitor. i have added the picture of the DM board you have to replace the marked capacitors . Also check the two fuses in the same board 4Amps fuse and 2Amps fuse.
ok
Jun 08, 2011 | Mitsubishi WS-65909 65" Rear Projection...
Hi, I have a Mitsubishi WS-55809 with a 2,2 error
I am the only one here who has step by step and start to finish instructions for this repair---based on my doing hundreds of these sets with this problem.
I can tell you best place to buy the chips and the pico fuses.
Give me email and I will send to you if you rate this solution as very helpful and MAKE A COMMENT HERE.
sd tech
Sep 13, 2010 | Mitsubishi WS-55809 55" Rear Projection...
Tv wont turn on its a mitsubishi wide screen model number WS-65809. also forgot password for parental locks so when it is on cant watch anything but Disney, and Nickalodian!!!
I can help you unlock your Mitsubishi HDTV V-Chip at least, for when you get it back on.
Please follow these steps to bypass the vchip or reset the V Chip password.
I hope that helps.
_______________________________________________
Reset Mitsubishi HDTV VChip Password
Bypass Mitsubishi HDTV Front Panel Lock
Mar 13, 2010 | Mitsubishi WS-65809 65" Rear Projection...
MY T.V. WONT TURN ON
this sounds like your flyback converter is burned out on the circut board....cheap part! but must be done by pro!
Dec 09, 2008 | Mitsubishi VS-50111 50" Rear Projection...
Tv wont turn on
ok is in shut down mode kine of proteccion some of the fuses are pico fuses but you may have problem with convergence IC's that what I' check first if that is ok go to HVT .. if U still have problems e-mail me
Mar 30, 2008 | Mitsubishi WS-55859 55" Rear Projection...
No picture no sound
check the main fuse inside the chasis, if burt start to replace it , if it goes again, check for primery fuse,
if the main fuse is ok, check for the secondary fused or dead short, check the horizontal transistor to make shure it's not shorted.
regards
bob
Jan 03, 2008 | Mitsubishi VS-55705 55" Rear Projection...
Tv wont turn on
That same thing just happened to my t.v. The repair person will be here on 10/10/06. I will let you know what they say.
Aug 22, 2006 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi VS-50605 50" Rear Projection Television Logo
78 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
