Question about Weber Genesis Silver B Grill
My grill won't heat up above ~250 degrees. - Weber Genesis Silver B Grill
  • 140 Answers
It may need a clean
Posted on Aug 06, 2010
Won't heat up above 200 degrees.
Try turning off the valve to the tank, then leave the knobs on the grill open for 2-3 minutes. Turn off the grill knobs, slowly, slowly open the valve on the tank. Relight the grill and see if it gets hot.
Mar 26, 2014 | Broilmaster Premium P3 Grill
Hotpoint oven won't heat above 250 degrees broiler works fine as well as the stove top
either its the oven sensor rod located at the top of the ovens cavity,or your bake element could be getting a hot spot which is when it gets a discolored spot in the element and can no longer pass sufficient current to heat the oven past 250 degrees
Jul 28, 2012 | Hotpoint Ovens
Master forge l3218 Low Heat Issue
Had the same issue with the three burner model, the grill wouldnt heat as quickly as it should. Thought it was an issue with the regulator but decided to work our way from the burners to the tank to eliminate possible causes. we got to the valves were you select the heatnig level and discovered that sugar ants had gotten into there somehow and died, enough of them to block the valve without completely closing it. to solve we removed the valves, disassembled them and ran a pipe cleaner through them to clean any buildup away. after doing this for ll three and reassembling the parts and putting them back onto the grill it works perfectly and heats up like it was brand new.
Apr 29, 2012 | Grilling
The traegger will not heat up past 350 degrees
Unfortunately, it's not realistically designed to heat above 250 -275 Degrees F. No matter what they call it, it's still a smoker, more than it is a grill. Even the Owner's Manual says the the optimal operation temperature is 180 to 200 degrees F. It's not designed to sear steaks.
Perhaps, if it was made of cast iron, rather than sheet steel, you could get the temp up past 350 degrees. If you really want a true smoker/grill, pay $700 to $800 and buy a Big Green Egg. And you wont have to buy some specialized pellets to burn in it. Just good old fashioned lump charcoal or wood chunks.
I wish I had better news for you, but it is what it is. Thanks for choosing FixYa.
Aug 23, 2011 | Traeger Industries BBQ070 All-in-One Grill...
One day it will not heat up over 300 degrees and the next day it will heat up over 400 degrees without any problem. I dont know if it is the gas tank or the grill. Nothing on the grill appears to be...
More than likely, it's the OPD valve on the LP G tank. When it won't heat up above 300 degrees is after the tank was turned OFF & then turned back ON? If that is the case, disconnect the gas line from the tank, wait 5 minutes, reconnect the hose to the tank and turn the tank valve On VERY, VERY SLOWLY. This will keep the tank valve from locking up the grill regulator and thereby, gas will get fully to each burner. If this doen't correct the problem the first time, repeat the above procedure.
That should solve your problem
Mar 06, 2011 | Fiesta Blue Ember Gas Grill
LOW HEAT WHEN ON HIGH
This can be caused by the safety valve in the propane tank. Most times this can be corrected by tuning off the valve on the tank, make sure all the controls on the grill are in the off position. Then turn on the tank valve and try restarting the grill. All the controls on the grill must be off, before reopening the tank valve. If that does not work try another propane tank.
Mar 14, 2009 | Weber Genesis Silver B Grill
Weber Genesis Silver B Grill Logo
162 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Marvin
Marvin
Are you a Weber Grilling Expert? Answer questions, earn points and help others
