Question about RIM BlackBerry Bold 9700 Smartphone
Hi i bough new blackberry 9700 on bell net work and now i am starting it, not tuning on half way blackberry bar showing and going off again, and turning on again... same thing happening
My mobile show " enter
Reflash your blackberry bold 9700, it should be reset your MEP counter. If still not working, bring your blackberry to nearest local mobile repair shop in your country and asking them to doing blackberry bold 9700 unlock process using cable unlock and will make your blackberry unlocked with default factory setting like new one.
Aug 30, 2011 | RIM BlackBerry Bold 9700 Smartphone
Tip
How to unlock your Blackberry to any network
How to Enter Unlock Codes on BlackBerry Bold (9000), 8800, 8820, Curve (8300, 8310, 8320), Javelin (8900), Gemini (8520, 9300), & Onyx (9700):
Note: NO SIM is needed to unlock the phone. After phone is unlocked, remove the battery, insert SIM as desired and re-insert the battery. Phone MUST be restarted to use the new SIM card.
1) Power on
2) Go to Settings
3) Go to Options
4) Go to Advanced Options
5) Go to Sim Card
6) HOLD ALT and press: mep2 (Please note that you will NOT see what you type on the screen) *
7) It will ask you for the unlock code. Enter it and then press trackball to confirm and your phone is unlocked!
* If your phone is a 9700 or 9000 that requires a second code (ie.Bell), please repeat until step 6 and press mep4 to enter the second code.
You can try sites like this for the mep2 or mep4
http://www.cellphoneunlock.net/shop/category.php?id_category=17
on Apr 21, 2010 | Cell Phones
Hi,i have blackberry bold thats needs to be reset its MEP4 code.It is zero left.what should i do?
Don't worry. Reset your Mep counter by cable method. after doing this process. your blackberry bold 9700 unlock. after that you no need to unlock your blackberry bold 9700 by network.
Jul 28, 2011 | RIM BlackBerry Bold 9700 Smartphone
Hi my blackberry was working fine havnt dropped it or anything woke up this morning and the alarm clock was upside down, took out the battery and put it back in, the blackberry bar loaded but started to ...
It might sound absurd but the frantic truth is that the LCD screen of your phone is bad which might be as a result of previous shocks and abrasions which it has been subjected to.This is a common feature of the 9700 bold.
The only solution is to replace the LCD screen of your phone,it cots between 40-79 dollars .
Take care..
Aug 23, 2010 | RIM BlackBerry Bold 9700 Smartphone
How do i get my mep code to unlock my phone
I dont know about others but 'unlockgenie' definetly works. It worked for my blackberry curve 8900.
Aug 11, 2010 | RIM Blackberry 8310 8320 8330 Curve 8100...
Hi
u can get MEP code for your blackberry from this web http://blackberryimeiunlockcode.com
thanks
Aug 10, 2010 | RIM BlackBerry Pearl 8100
I want the unlok code of my blackberry 9700 bold
There are two methods for unlocking Blackberry Bold 9700 by MEP number and by IMEI#.
The simplest method for unlocking by IMEI#.
You can find your Blackberry Bold 9700 IMEI number by follow one of these steps.
1.By Pressing *#06# into the phone.
2.On your Blackberry cell phone, go to Options-->Status.
3.put the battery out,there should be a white sticker it will show your Blackberry IMEI #.
This Blackberry Unlocking codes provider provides unlock code for Blackberry Bold 9700.
Hope this helps.
Jun 25, 2010 | RIM BlackBerry Bold 9700 Smartphone
Hi, My problem is that no dialled, recived or missed calls show on the log list. what shows are the last numbers befpr the problem accured. My phone is blackberry 9700. help is needed sultan.
You might check that you are using the most current system software for your BlackBerry Bold 9700 Smartphone.
Many quirky behaviors for these devices are fixed every time a new software version is released.
The latest software as of March 20, 2010 is BlackBerry Handheld Software v5.0.0.64
Instructions for reinstalling BlackBerry Bold 9700 Firmware and System Software are here.
Mar 08, 2010 | RIM BlackBerry Bold 9700 Smartphone
RIM BlackBerry Bold 9700 Smartphone Logo
96 people viewed this question
Top RIM Cell Phones Experts
Longtime User
ismael castillo
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
