Question about Denon AVR-1706 Receiver
Schematic for denon avr-1706 - Denon AVR-1706 Receiver
  • 27 Answers
SOURCE: No system setup menu on screen
its related to the control AVI switch inside on the right side with the contact and 7 Ri sisters.
about 200.00 something to repair.
I can help with some money do you have the reciever still???
Posted on Nov 11, 2008
  • 119 Answers
SOURCE: Denon AVR-1706 Left Front and Rear speakers
go into the settings menu and do a sound test using the recievers pink noise tester to test each speaker connected, if while doing this test you still get no sound from those two speakers check connections, make sure speakers are not blown.
if speakers and connections are good then the reciever needs repair
Posted on Aug 02, 2009
  • 506 Answers
SOURCE: my denon avr-1706 is going into protection mode
You either have an overloaded output or a shorted powersupply. If you have verified that your connections are not the cause then the problem is internal and will require service from a trained technician. Switching power supplies are notorious for going bad. Two of the main components are the FETs used for switching and the PWM generator.
Posted on Feb 11, 2010
dunnbiker
  • 8546 Answers
SOURCE: how do I connect my computer to denon avr-1706
Depends on your computer's sound capabilities. At a minimum you could use its analog headphone and microphone jacks as Output and Input, respectively and run them to a Tape loop on the receiver.
If you have compatible digital audio ports on your PC, conenct them to their respective corresponding outs and ins on the Receiver.
Posted on May 02, 2010
dunnbiker
  • 8546 Answers
SOURCE: when my Denon AVR 1706
What's "too loud"?
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Posted on Jul 29, 2011
How to hook up a denon avr -1706 receiver to a lg smart tv
When connecting your AVR-1706 to your LG TV, you will most likely be limited by the connections on your AVR-1706 as it does not have any HDMI capability.
In this case, depending on your LG TV, you would get the best video performance by using the component video connections from your TV to the Receiver. These are the one labeled Y, Pb, and Pr. These are special cables and you will need 2 sets if you want to run video out of your TV (perhaps you are using the internal tuner). Refer to page 6 of your AVR manual for the TV video inputs. Please note you will only use one type of input such as Component, S Video or Composite (descending order of performance). You must connect the Video Out from your AVR to the back of the TV's Video In as shown on page 6 as a minimum to get signals from devices other than the TV.
On page 12 of your AVR manual you can see the connections for TV outputs including the audio connections to the AVR. In the case of audio, you can either use Optical Digital (Toslink) out from the TV or coaxial (RCA) cables: Again in descending order of performance.
If you don't have the AVR-1706 manual handy, you can see it at the following link: http://a248.e.akamai.net/pix.crutchfield.com/Manuals/033/033AV1706B.PDF
Mar 02, 2015 | Denon Audio Players & Recorders
Fiber optic wire hooked to Denon AVR 1706
Go to page 19 in this manual - it should get you to where you want it to be.
Dec 12, 2011 | Denon Audio Players & Recorders
How do I connect my computer to denon avr-1706
May 01, 2010 | Denon AVR-1706 Receiver
My denon avr-1706 is going into protection mode immediately after turning on. whats the problem?
Feb 09, 2010 | Denon AVR-1706 Receiver
Denon AVR-1706 Left Front and Rear speakers stopped working. Any suggestions?
Jul 18, 2009 | Denon AVR-1706 Receiver
Denon AVR 1706 reciever
it a control switch and power supply that needs to be replaced they have blown.
get in contact with me so I can help you financially...I can buy your unit for parts.
It will cost more than the unit
radricktip@gmail.com
Sep 27, 2008 | Denon AVR-1706 Receiver
Denon AV Receiver 1706
Do you still have the unit still ??
Sep 04, 2007 | Denon AVR-1706 Receiver
Remote control for Denon AVR 1706
YES YOU CAN THERE MAYBE A FEW DIFFERENCE BUT YOU WILL BE FINE TO USE IT
Jan 10, 2007 | Denon AVR-1706 Receiver
Jan 04, 2007 | Denon AVR-1706 Receiver
Denon AVR-1706 Receiver Logo
120 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
