Hi, I have a Miele W 828 washing machine. The drum is not turning , motor is working and the belt is just slipping. I tried to turn the drum with hand but can`t it is stuck. is there any suggession for how to repair
  • 43 Answers
SOURCE: zanussi washing machine drum will not go round at all
Tracy
The bearing may have siezed or you have something jammed between the drum and outercasing
Posted on Mar 23, 2008
i had a similar problem with a zanussi machine
a cheap bracelet got washed with some clothes and it found its way into the drum housing jamming the drum.
it may have been cheap to fix, but i just got rid of it cos it was 4 years old anyway
i now have a zanussi ZWF1231W just past its 1 wear warranty that has just died completely except for an "on indicator light"
the store inform me that i will have to pay the zanussi engineer a Euro 90 call out charge, plus labour costs, plus parts if needed.
im a little bit disappointed with zanussi to say the least
Posted on Apr 23, 2008
JR JR
  • 116 Answers
SOURCE: Washing machine will not spin dry but washes properly
CLUTCH MAY NEED TO BE REPL/ IF DOES NOT SOLVE REP/ TRANSMISSION
Posted on Nov 30, 2008
barkencoa
  • 3463 Answers
SOURCE: WASHING MACHINE DRUM WILL NOT TURN
There is no adjustment provided for lining up the pulleys.
If it comes off then there are a couple of reasons that come to mind,the belt is too slack, the belt is worn,the drum is out of alignment with the motor pulley, caused by worn drum bearings, the motor is loose, a loose drum pulley, or you are not lining the belt up properly, overloading can also throw the belt off.
Hope this helps.
Plz leave feedback.
Ta.
Posted on Dec 09, 2008
abhishek33
  • 1239 Answers
SOURCE: drum won't turn, new belt fitted
Hi this is abhishek and welcome to fixya
see whther any coins or pins anything small stucked below tub ,,this will cause drum not turning ,if its not also timer may be the problem.....better to fix it
thank u....
Posted on May 03, 2009
Im trying to replace the drum belt on a Miele t7734 tumble dryer, but cant seem to get around the front or back of the drum to get the belt around it. Am I supposed to dismantle the whole machine to do...
Some dryers disassemble from the front, making it possible to slip the replacement belt over the drum and connect it to the tension idler and the motor pulley.
Dec 20, 2014 | Miele Dryers
Hi i have a speedqueen awm373w-3062 have noise on
Hello.
Loud noises coming from a Washing Machines are most often caused by loose objects inside the unit or by a broken dryer belt. The Washing Machines belt allows the dryer's motor to run smoothly. Continuous wear and dry conditions may cause the belt to dry out, eventually Washing Machines cracking and then snapping. This will cause a loud noise within the unit. Repair and fix the dryer belt of a Washing Machines to get rid of loud noises.
Instructions And Things You'll Needed to solve the problem.
Screwdriver ,Replacement Washing Machines belt
1 Stop the Washing Machines and look inside the dryer's drum for any loose objects such as coins, pens or anything else that may have been in a pocket of clothing. Remove the object and restart the dyer to determine if the noise has stopped.
2 Unplug the Washing Machines from the wall outlet to disconnect all power to the unit.
3 Remove the lint trap from the lint compartment on the top of the dryer.
4 Remove the screws that hold the top panel in place. Pull the panel off to access the
dryer belt.
5 Tilt the dryer forward and lift the dryer drum to remove the belt. Check the Washing Machines belt. A belt that is worn, cracked, split or broken will cause loud noises.
6 Slide the old belt off of the drum and pull it out to remove it. Take note on how it is positioned over the drum.
7 Install the new belt. Lean the front panel away from the Washing Machines and slip the new belt over the drum. Locate the position of the old belt and slip the new belt following the old belt's position ensuring the grooved side of the belt faces down. Push the idler pulley towards the motor to allow you to slip and loop the belt around the motor pulley.
8 Place the top panel on the Washing Machines and screw it in place.
9 Open the Washing Machines door and use your hand to rotate the drum counterclockwise a few turns to ensure the belt is secured.
10 Plug the Washing Machines into the wall unit and begin use .
Aug 02, 2011 | Washing Machines
Miele w1113. Washer drum won't spin during wash cycle
I assume you are saying the machine is working except the drums not turning? - you need to see if the belt has come off because thats what i would check first if you hear the motor start/stop after it fills up with water.
May 30, 2011 | Miele Touchtronic W1113 Washing Machine
Miele novotronic w864 The motor is still working but the drum is not going round. Could it be the drum belt?
Providing the motor is okay then yes could be the belt...if so you will find that the drum turns by hand no problem with ease........In which case order new belt....
Mar 03, 2011 | Miele W864 Front Load Washer
How do you replace the belt on an indesit moon washing machine? I have managed to take off the belt fromt he motor and the drum, but trying to get the replacement band back on it very hard - if it just...
Most belts for washing machines are of the stretch type and they will take a lot of force to get on.Try to put on motor pulley first the try on drum pulley one side or other whichever feels easiest as you start it on pulley start turning drum pulley whilst holding the belt to stop it slipping,keep turning until it goes on then line up to centre of drum pulley.
Hope thet helps.
May 09, 2010 | Washing Machines
Am trying to replace the belt on a hotpoint aquarius wf240 washing machine. I have removed the 2 bolts which appear to hold the motor in place ( 1 bolt on each side). However the motor still will not
Hi. The motor is non adjustable on this washer. Tilt washer forward, get someone to hold it steady, and put belt round motor pulley first, then slip belt on drum pulley, and slowly turn drum by hand, feeding the belt on as you turn drum, be careful not to trap fingers, as it is very tight, this is normal, as the belt is a stretch type, this is the reason the motor is non adjustable. Please rate my advice. Thanks.
May 30, 2009 | Hotpoint Aquarius WF220 Front Load Washer
Drum won't turn, new belt fitted
thank u....
May 03, 2009 | Washing Machines
Ultima wt940 Not spinning
Hi.
Possible slack belt which will slip with full load of water and washing, check tension, or maybe motor fault. the motor can sometimes work o/k on spin, but not on wash
Nov 23, 2008 | Washing Machines
Miele T220 drum doesn't turn
sounds like belt may be slipping .. check idler pully for tightest against belt .. belt may be streached and need replacing
Oct 14, 2007 | Miele Novotronic T220 Electric Dryer
Washing Machines Logo
50 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
