Question about Uniden BC60XLT Handheld Scanner
HOW DO I PROGRAM THE CHANNEL IN AND LEAVE IT ON SCAN AND IT PICK THEM UP
    President:
  • 2,761 Answers
To enter a known frequency into your scanner:
- Power the scanner ON
- Press the MAN key to stop scanning
- Press MAN repeatedly to select the channel to program
- Enter the desired frequency, including the decimal point
- Press E to enter your data into the scanner's memory
Repeat the process for other frequencies, and press the SCAN button when you're finished programming.
More detailed programming steps are presented in the factory operating manual, which you can download/print, free of charge, here:
http://www.uniden.com/pdf/BC60XLTom.pdf
For a comprehensive database of active frequencies in your area, visit:
www.RadioReference.com
Bill B
Posted on Aug 06, 2010
The electricity went off last night and now my tv doesn’t get any channel from the antena. I already scan for channel but the tv doesn’t pick any channel
unplug the tv and let it sit for about 5 minutes.
then plug it in and follow the user manual's steps to re-program the channels.
if that fails, then contact a repair facility for help. not knowing the make or model of equipment makes further guidance difficult to impossible.
Mar 25, 2018 | Televison & Video
How to tune in Channel 60 in a Sony Triniton CRT?
assuming that you can "pick up" channel 60..and that the signal is strong enuff...that is part one..make sure you have a good antenna connection and that the antenna is positioned for maximum pick up, then do the scan mode on the tv via the remote control. it will re scan the channels and if the signal from channel 60 is being picked up strong enough, it will program the channel into your set automatically.
Sep 03, 2014 | Televison & Video
Cant get my digital antenna to pick up any channels
In your area, it may be necessary to use an antenna with an amplifier.
Jun 29, 2017 | Televison & Video
I have a RCA LCD TV model no. RLC3708A and when hooking it up when I took it out of box, I got to
I think you are confusing the channel on the tv and the channel of the cable company that is not something that you can pick up with the scan tv, scan tv is good for picking up local channel meaning air channel that we get with a antenna only not the cable chanel
Jun 24, 2012 | RCA Televison & Video
How do I program a uniden BC 145xl base scanner
  • Press the power button to turn the scanner on.
  • Press "MAN" (for manual)
  • Now pick a channel where you want to store a frequency at and enter it on the keypad.
  • Now press the "MAN" button again to go to that channel.
  • Now enter the frequency you want into that channel and don't forget to include the decimal point.
  • Now press the "E" button (for enter) and you have programmed one frequency.
  • Repeat these steps until your scanner is programmed.
  • Now you can press the up and down arrow buttons to scroll manually through the channels or just press "scan" to scan through them.
  • Make sure to keep your squelch just above the noise so you pick up stations well.
  • Hope this helps.
Nov 24, 2011 | Uniden Radio Communications
How do I manually program frequencies?
  • Hi, i can help.
  • This scanner is pretty easy to program. Follow these steps ---
  1. First press the "MANUAL" button to stop the scanner from scanning.
  2. Now pick a channel you want to store a frequency on. For instance if the channel will be 15 the press the number 1 and then the number 5 and then press "MANUAL" again.
  3. Now enter the frequency you want to program and include the decimal point.
  4. Now press the "E" button to enter the frequency into that channel.
  5. Repeat them steps to fill up your scanner.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Sep 19, 2011 | Uniden BC248CLT Base Scanner
Need to program channels
This is a LCD tv right?U want to hook up free air or pay cable tv.Go in ur tv menu goto setup,go down to CH.press than pick AIR or CABLE.Than just pick one press scan u will get all free air channels or get all ur pay cable channels
May 26, 2010 | Vizio L37 Television
Is my Toshiba 27AF42 TV bought in 2002 capable of receiving digital signals? And whether it is or not, how do I integrate my VCR into the TV and my converter box? Right now the TV is hooked up with the...
This is probably way too late an answer, but I just ran across your post. No TV made in 2002 has digital tuning, so you would need the converter box to watch off-the-air digital broadcasts.
To hook up the pieces, take the converter box output and run it to the VCR antenna input jack. Then run the output from the VCR to the TV's antenna input. Leave the VCR and TV both on channel 3 (or channel 4 if that's what you have the converter box output set for).
To watch TV, leave the VCR off and the signal from the converter will pass right through to the TV. You'll do your channel changing with the converter box, so the TV stays on channel 3. To record a program, just remember that the VCR will always need to be tuned to channel 3 (4), since it will have to be on the converter box output channel. Again, you pick the actual TV channel with the converter.
Note that this arrangement will allow you to program your VCR to record while you are out, but there are some limitations. You can't record things on different channels, since you won't be home to switch channels on the converter. The VCR is always recording on channel 3 (4), and the program you'll be recording is whatever channel the box is set for. If another program comes on on a different channel later, you won't be around to switch. But you could program different recording times on the same channel, anyway. You also can't record one program while watching a different channel, unless you had a second converter box.
Hope you can still use the information provided here. If this has been helpful, please take a moment to rate this a fixya. Thanks for asking here!
Dec 16, 2008 | Toshiba 27AF42 27" TV
Uniden/bearcat BC-100
If it's indeed a BC-100 and not a BC-100xlt, the 16 channels are easy to program and use.
1. Press MANUAL 3 MANUAL with 3 being the number of the channel you wish to program.
2. Enter the frequency for that channel (e.g., 162.55) followed by ENTER.
3. Follow the same sequence for each channel you wish to program, except that pressing MANUAL after you program a channel will advance the scanner to the next channel.
To scan, simply press the SCAN button after your frequencies are programmed.
Bill B.
San Antonio
Jul 15, 2008 | Uniden BC248CLT Base Scanner
Uniden BC60XLT Handheld Scanner Logo
70 people viewed this question
Top Uniden Radio Communications Experts
Steve
eradiostore
eradiostore
Marvin
Marvin
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
