Question about Uniden GMR-325/2 2-Way Radio Walkie Talkie Dual Pack
I took out the rechargeable batteries (replaced with regular AAA)in my Uniden walkie talkies and now one is set for channel 19 and one for channel 6 so they cannot communicate. How do I set the channels the same?
    President:
  • 2,761 Answers
Press the channel/scan up or down arrow key to change3 the channel on either radio. Need the operating instructions? You can download/print them here:
http://www.banoggle.com/Products/Uniden/manuals/GMR-325-2om.pdf
Bill B
Posted on Aug 06, 2010
What is the range of the uniden black walkie talkie gmrs 520
  • Pair of GMRS/FRS 2-way radios for person-to-person communication while hiking, skiing, and more
  • 22 channels (8 GMRS and 14 FRS); wireless range of up to 2 miles
  • Auto squelch function shuts off weak transmissions and unwanted noise at range limit
  • Single call alert tone; automatic power save circuit extends battery life; includes 2 belt clips
  • Each radio runs for up to 48 hours on 3 AAA batteries (not included); 1-year warranty
May 30, 2014 | Uniden Black Walkie Talkie Gmrs 520
My Uniden walkie talkie keeps saying L very time I push a button
You've set the keylock feature on your walkie talkie. From the Uniden manual...
KEYLOCK
ON/OFF Press and hold the call/lock key until the "L" appears. After 1 second, the LCD will return to the channel display. To exit Keylock on mode, press and hold call/lock again. Note: While in keylock on mode, it will still receive transmissions.
Feb 10, 2014 | Uniden GMR-1035-2 2-Way Radio
Uniden walkie talkie says L every time I push a button
KEYLOCK
Feb 10, 2014 | Uniden Radio Communications
Motorola XTR 446 talkie walkie is not receiving
Try programming the radios without an eliminator code and see if they work together then. If so, there is something wrong with the eliminator code portion of the radio. Also, check your batteries, switch batteries between the units and see if the problem moves to the other unit. It takes more energy to transmit than receive, so a bad or very weak battery could exhibit a similar problem. The radio icon will illuminate whenever a radio is transmitting or receiving. When the radio is in standby mode, the icon should not be shown. Your radio with the icon on all the time may be stuck in transmit. Check your PTT button to see if it is slightly stuck or depressed. Here's a link to the user guide http://www.motorola.com/web/Business/Products/Two-Way%20Radios%20-%20Unlicensed/_Documents/XTR446/Static%20Files/XTR%20Manual%20EU.pdf?localeId=103
Best regards.
Jun 24, 2012 | Radio Communications
Cobra pr 3850wx bought new NiMh 800mAh 1.2v rechargable batteries now the base charger lights won't come on when i put the radios in it
  • A Cobra 3850wx Radio requires 4x600mAh NiMH 1.2V AAA Part # GA-3ANH rechargeable batteries.
  • Not just any AAA rechargeable battery will charge in the unit.
  • All will work in the radio but not all will charge inside the radio. It has to be a specific battery.
  • This is an example of what you need. GA-3ANH batteries which will charge inside your radio. http://www.tomsawyer2wayradios.com/catalog/item/3823249/5076887.htm
Regards, Tony
May 22, 2011 | Cobra Microtalk 100 FRS Walkie Talkie...
Walkie talkies were working yesterday (gift from Christmas) and today the red power light is on indicating both working, but we can only get sound out of one of them.....any suggestions? brand new...
These walkie talkies are pretty simple to use. Turn on and turn the volume up and talk. So if you turn it on it is possible for there to be enough juice in the batteries to make the LED function but not enough to modulate (or talk) to the other walkie talkie. Have you tried to replacing the batteries with new ones yet? Sometimes recharge ables go bad and they are no good when you install them into your item. So make sure the batteries you installed are "new." And replace in both units. Should this not work, given the nature of the item and the age of those who will more than likely be using them, they break and soldier joints come loose. The back has a screw that is a specialty tool to remove. Outside of removing that and taking a look there is not much that can be done. Make sure to put at least 5 feet between the two radios to allow for good reception.
Regards, Tony
Apr 17, 2011 | Digital Blue LEGO Walkie Talkies
It came with battery i assume are rechargable but when plugged in there is no sign that they are charging and when you take them off the charger they die in a few seconds
It looks like some of these came with alkaline battery backs, some with rechargeables, and some with no batteries. The rechargeable packs will be marked "NiMH" with the part number FA-BD on them. If yours are the rechargeable types they probably need to be replaced. You can also power the units with 4 AAA alkaline batteries.
Bill B
Feb 25, 2010 | Cobra MicroTalk FRS 110-2 (14 Channels)...
Walkie talkie symbol stuck on cannot remove it
The symbol you are describing indicates you have the radio on HI power. It will not go away unless you reprogram the radio to LOW power, or change to a low power channel. Here is a link to the user guide: http://www.motorola.com/staticfiles/Business/Products/Two-Way%20Radios%20-%20Unlicensed/_Documents/XTNiD/Static%20Files/XTNiD%20Manual%20EN.pdf?localeId=252
Best regards.
Feb 06, 2010 | Radio Communications
Uniden GMR-325/2 2-Way Radio Walkie Talkie Dual Pack Logo
494 people viewed this question
Top Uniden Radio Communications Experts
Steve
eradiostore
eradiostore
Marvin
Marvin
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
