Question about Sewing Machines
Goes too fast, has no slow speed, sews several stitches at a time and I am unable to stop when I need to
  • 135 Answers
Sometimes the foot pedal sticks, tap on it a few times with your foot to get it to stop, if that doesn't work, unplug the machine for a few minutes then try, if that doesn't work then it will need to go in for repair.
Posted on Aug 19, 2010
Tension issues on my singer quantum 9960
A #16 needle seems pretty big for FMQ. Are you also getting pin holes in the fabric? Try using a top stitch, embroidery, or metallix needle.
Eyelashing is often a result of moving the fabric too quickly. Try speeding up your sewing speed or slow down the fabric movement. The object is to get the stitch speed equal to the fabric movement--and keeping it consistent. I tend to make swirls too fast which causes eyelashing.
It could also be tension. Be sure to ALWAYS RAISE the presser foot when threading the top thread.
What causes thread eyelashes when sewing
LOOPS Tension or Speed
Dec 10, 2017 | Sewing Machines
Tl2000 and it is skipping stitches while quilting. I have changed the needle. I used needles 14 16 & 18 I have cleaned the machine. When I sew seams I have no problems.
Have you changed the type of needle--top stitch, embroidery, microtex? Sometimes that will help. Also, my skipped stitches occur in FMQ because the fabric is moving too fast for the machine speed or I have a jerky movement. It helps me to try slowing down the fabric movement or speed up the machine and practice making smooth, consistent movement. I've never done FMQ with a needle larger than an 80/12, so you might try a smaller needle to reduce the fabric grabbing the thread.
Skipping the Skipped Stitches in Your Free Motion Quilting
Skipping Stitches
FMQ Troubleshooting Tips Tricks
Oct 31, 2017 | Sewing Machines
What is the proper quilting stitch for FMQ
Straight stitch. Doesn't matter what stitch length you set. The stitch length is determined by how fast or slow you move the fabric in conjunction with the sewing speed of the machine. FMQ means that you manually move the fabric, so the feed dogs are disabled and a darning or FMQ presser foot is installed on the machine. The darning or FMQ presser feet have shorter shafts than other feet, which allows space for you to manipulate the fabric.
Search the internet for Free Motion Quilting. There are tons of web sites and videos available.
Jan 04, 2017 | Sewing Machines
Why is it seizing up and clocking after doing basic sewing?
Juki HZL F300 Exceed Sewing Machine at Ken's Sewing ...
www.kenssewingcenter.com/juki-hzl-f300-exceed-sewing-machine-p-30...
The Juki HZL F300 Exceed Sewing Machine is a classroom model and will exceed ...High speed sewing up to 900 spm, stitches per minute; Power at low speed ...
Juki HZL F300 Exceed 106 Stitch Computer Sewing and ...
www.allbrands.com/products/22395
$749.00 - ‎In stock
Juki HZL F300 Exceed 106 Stitch Computer Sewing and Quilting Machine +$50 Knee Lift Lever + $50 ... High speed sewing up to 900 spm, stitches per minute
Juki Exceed HZL F300 Home Deco Computerized Sewing ...
Dec 01, 2015 | Juki HZLF300 Sewing Machine
When following manual directions to wind a bobbin, it starts out OK, but after several winds, the thread turns out with little loops on the bobbin. ??? Sylvia
Make sure that you are running the thread through the winder tension guide before it goes bobbin winder. Best to consult your owner's manual.
Also, it helps to slow down the winding process. Slower speed winds the bobbin more consistently and does not stretch the thread as much as a fast speed will.
Beginner Guide to Sewing Sewing Machine Parts Reference Guide
Nov 28, 2015 | Sewing Machines
Having difficulty with free motion machine embroidery on my Janome Mystyle 16, top thread keeps breaking. What can I do to stop the thread from breaking? Plus the stitching is very erratic,any ideas?
1. Set up for regular sewing (not embroidery).
2. Adjust the tension of the bobbin and the top thread so that you have a nice straight stitch.
3. Check your thread quality. Is it fuzzy or have small trails sticking out. No Walmart thread allowed. Only top notch embroidery thread allowed.
4. When you've been successful with the thread and tension go ahead and set up for free arm.
5. Sew free arm but remember machine has to keep up with you. If you go too fast you will be pulling the thread and probably will break the thread.
6. Your erratic stitch is caused by the speed at which you are moving the hoop. Going fast; then slow is going to make a long stitch and then a short stitch, etc.
Apr 03, 2015 | Janome Sewing Machines
I find my janome overlock machine is very slow ,i would like to know how to increase its speed
There is no speed seperate control on overlockers other than the foot control but most sew at 1500 stitches per minute, very fast compared to sewing machines.
What is your stitch length set to as this could be the problem. For normal four thread stretch seam you would want the length set to beween 2 and 3 so double check this - the length knob is usually a knob on the right side near the flywheel.
Hopefully, the above solves the problem for you but if not, please message again.
Aug 28, 2011 | Janome 1600P-DB Mechanical Sewing Machine
When I begin a sewing stitch, the speed starts slow and increases every time. How do I change it so that I can begin a stitch fast or slow and control it without having to ease up to speed every time?
Good day!!!
please apply a some oil on the motor and other moving parts inside you sewing machine..
After that reboot the machine and used it....first try is persisted but when you used it continuously for at least 10 minutes your machine is OK...
thanks for using fixya
Jun 29, 2011 | Husqvarna Viking 1
Machine does not sew steady or fast...have to pump foot pedal
Machine is slowing down if it has to change the speed. So if design contains a lot of long stitches or not optimized it will be sewn slow. If your software is surely updated to the latest version and still machine is sewing slow then probably you need to optimize your design.
P.S. Software Live Update you can find under "Help" submenu.
Nov 21, 2009 | Singer CE-200 Quantum Futura Computerized...
My necchi sewing machine stitches too fast
A lot of machines have a speed control, either on the machine or the foot control. I looked thru the manual and did not find anything about speed control. Look under the foot control for a screw that may have a + and - . Otherwise, you may want to take it back to see if service can adjust it for you.
Jan 10, 2018 | Necchi 3537 Mechanical Sewing Machine
Sewing Machines Logo
91 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
