Question about Toshiba CZ32T31 TV
The picture bows in on the sides - Toshiba CZ32T31 TV
53" rca model p52754at
CRT pictures that "bow-in" on the edges usually indicates that the high voltage power supply is failing.
Dec 03, 2010 | Televison & Video
Bowed in on both sides. colored lines everywhere
Open fuse/bad connections on HV ckt board and one or two bad capacitors.
Mar 22, 2010 | RCA D52W19 52" Rear Projection Television
Sony KV-32FS13:Pictured slightly bowed down at sides
Your symptoms sound like you have a problem in the pincushion circuit.
I would recommend you have a technician take a look at this, as this can be a tricky circuit to trouble shoot.
Aug 15, 2009 | Sony Televison & Video
Bowed Picture
This is a convergence problem. If you can solder, you should be able to repair this yourself. Please update this to confirm the model as P52960 and whether or not you wish to attempt the repair and I will supply additional details and instructions.
Dan
Oct 06, 2008 | RCA P52960 52" Rear Projection Television
I have a pic problem is it fixable
If the picture is bowing in on the sides, this is called a pincushion problem. Please confirm that your model is KP-53XBR45 and I'll look up the probable defective parts.
Dan
Aug 26, 2008 | Sony KP-53XBR45 53" Rear Projection...
Projection T.V. Picture
Replace Both of your STK ICs convergence ICs STK392-110 use 150s Better ICs Call Mats 1-800-628-1118 Also RK42 RK46 RK48 RK50 RK54 RK58 RK60 will have to get back to you on resistor values
Jul 21, 2008 | Hitachi 60SX12B/13K 60" Rear Projection...
Problem with convergence
bad convergence ic's
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 03, 2008 | Philips Magnavox 9P6034C 60" Rear...
Picture bowed on sides
how badly is it bowed on both sides? if it is too much. ther is a fuse resistor that is gone bad near the coil in the east west section. you need to replace that. if it is not too much..you need to get into the service mode to fix that..good luck
Apr 05, 2007 | Samsung PCK520R TV
Toshiba CZ32T31 TV Logo
70 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
