Question about Protron PLTV3250 32 in. LCD Television
Lost the remote and touch pad stopped working, although the blue power indicator is on.
  • 11,361 Answers
You need to look at the power supply module for bad caps with leaking/bulging tops first, this is a very common problem with this model. Right now the 5VDC standby is working but not the rest.
http://s807.photobucket.com/albums/yy352/budm/Protron%20PLTV%203250/
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx
Posted on Aug 06, 2010
The touch pad on my 990 legacy remote does not work?
The touch pad does not respond
Claudia, dismantle and try to clean or just replace with a good universal remote.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Mar 25, 2016 | Televison & Video
I lost the 27208 remote that came with two contractor-installed Hunter fans with lights (incandescent). The fans, lights, & remote have worked fine for 5 years. I purchased a new 27209 remote at Lowes...
If you are trying to use a combination of wall switch and pull chain control, the simple logic in the receiver can't figure out what to do. Try disconnecting all fan power at the source, removing and reinstalling the remote battery, restoring power, and trying all combinations of switch settings and power off - power on operation until you get results (or give up).
Feb 28, 2017 | Hunter Dryers
My touch pad is not working. There is an orange light on it.
I am really sorry to hear that your touch pad is not working. You mentioned that you see an orange light on it, where did you see it? is it on the top of your touch pad? if it's just on the top of your touch pad, all you have to do is just press the button right beside the orange light. Because the touch pad is being disable indicating the orange light, when you press the button you will see a blue light indicating that you enable the touch pad.
Thanks.
Jul 24, 2011 | HEWLETT-PACKARD HP ProBook 4520s Notebook
My Emachines E625's touchpad has stopped working. What can I do?
it stopped working how.. its not powering at all? if yes, try to remove battery, put in power adapter and try to power it. if it powers, plug in battery while machine is on.
May 04, 2011 | Acer Aspire 3000 Notebook
Key fob stopped working the door locks. I changed
the circuit boards on those factory remotes, sometime break where the battery is clipped in, check to make sure the solder is holding the clip properly and it is not loose, also they remote may need to be programmed to the vehcile with a scan tool, usually only found at GM, Also the rubber part of the remote on the inside where the pad touchs the circuit board, uses a small screwdriver and touch the exposed circuit, if the remote locks the doors, try putting in tiny peice of alumumn tape of the inside pad, the connectiveness of the rubber wears off. If not try above or dealer.
Sep 28, 2009 | 1999 Chevrolet Silverado 1500
My touch pad thing with play, pause, volume, stop etc. has stopped working. The blue lights on them arn't showing up either. Can anybody help please?
There is most proably a button on your keyboard that turns your touchpad on and off. Hunt around for that. Look for keys that have blue writing on the foward edge of the keys these usually indicate a secondary function for that key. You have to press the key that turn this secondary function on and off and then look for a key with blue writing that may have to do with your touchpad
Aug 07, 2009 | Computers & Internet
HP Pavilion dv8000 - touch scroll pad won't work
at the top black rim around the touch pad, there is an orange light showing, press and have it show blue. It will work now.
Cheers.
Please rate this fixya.
Apr 10, 2009 | HP Pavilion dv4000 Notebook
Touchpad wont work on mains power
In the acer power management in the control panel you can specify when the mousepad turns on and off, like when plugging and unplugging the laptop. You can also do this for the wireless and other settings.
Mar 23, 2009 | Acer Aspire 3610 Notebook
1996 Toyota Celica remote security system no longer works
Hi, Contact your dealer and get instructions for reprogramming your remotes. When a security system loses power for an extended amount of time the programming for the remotes are lost.
Mar 09, 2009 | 1996 Toyota Celica
My kenwood kac7201 amp wont turn on but it has power to it
Recheck the voltage precisely like this:
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
Jan 22, 2008 | Kenwood KAC-7201 Car Audio Amplifier
Protron PLTV3250 32 in. LCD Television Logo
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
