Question about Health & Beauty
MODEL 85B0000 NEBULIZER GETS VERY HOT AT THE TUBE ATTATCHMENT STEM. wHY?
3 Suggested Answers
  • 659 Answers
SOURCE: low flow hot water in Delta Shower
If your water heater is old or has been recently replaced, it will slough off debris that will get caught in the hot water supply side of the faucet. You have to disassimble the faucet and use a dental pic to remove the debris from it. This is a real common occurance. You can also try to flush out that side by removing the parts and then slowly turning on the water without the parts inside. Be careful not to flood your bathroom when you do this. But usually you have to dig it out. I have spent as high as 3 hours digging the liner from the dip tube of a water heater out of a faucet.
Posted on Apr 05, 2009
  • 89 Answers
SOURCE: kobalt air compressor problem plastic tube gets a hole
EVERYONE WANTS TO MAKE EVERYTHING PLASTIC THESE DAYS. REMOVE PLASTIC LINE AND REPLACE WITH 1/4" FLEXIBLE COPPER ( ANY KIND ) JUST PICKUP A SMALL ROLL AT A HARDWARE STORE. MAKE SURE YOU GET A COUPLE OF FITTINGS, NUTS AND/OR FERRELS. HOPE THIS HELPS, JODY
Posted on Apr 20, 2009
The stem on the bottom of the medicine cup broke. I have a probasics by pmi nebulizer. Where do I purchase parts?
Go to your doctors office. I'm sure they will give you another mask circuit that has a new cup
Nov 17, 2013 | Health & Beauty
Where do you load the inhalation solution?
You may have already figured this out by this time, but figured that others could have the same question. Here's a simplified explanation on how to assemble and use the nebulizer. I apologize if the explanation sounds patronizing. I'm not sure of what you may or may not understand about the nebulizer, so I'm explaining as though you don't understand it. I'd rather someone explain something in a patronizing way, than assume I have knowledge that I actually don't. At least with the former, it's easier for me to ensure my questions are answered. I also apologize for my ADHD. It often cause me to write much more than is necessary or overexplain things.
There should be two pieces that screw together to make the reservoir.
Piece #1 is the male side/bottom side and may or may not have a green cone inside. If not, there are still a plastic piece inside that forms a cone shape. This side should also have a small plastic cylinder shape on the bottom. This is where one side of the supply tube should be attached.
Piece #2 is the female side and has a larger cylinder shape on the top. When the piece is turned on its side, it sort of resembles a flashlight. This is what the breathing apparatus is attached to. You attach the tee adapter to the tube side of it. Then you attach the mouthpiece to whichever of the tee sides it fits best. Once this is all assembled, attach the other end of the supply tube to the nebulizer.
Now, back to your question. Open the reservoir, pour the solution into Piece #1, then screw Piece #2 back on. It should only take a second or two for the steam to begin flowing through the breathing apparatus once you turn the nebulizer on. Also make sure the the supply tube is attached securely to both the nebulizer and the reservoir so it doesn't pop off. Now you're ready to begin.
If you start coughing during treatment, that's fine. Don't remove it from your mouth or stop treatment. My mom was my son's pediatric nurse and trained us on its use. She said that if you start coughing during treatment, that actually helps you to inhale even more of the solution which is beneficial..
Aug 02, 2013 | Salter Labs 8900 Series Small Volume Jet...
Tubing coming out of machine gets very warm
This is common that these smaller units get warm when running for longer than five minutes at a time. I have never had a problem with it overheating though. If it would make you feel better the larger Pari units rarely get warm. The Pari LC plus neb kit may need replacing. This may fix the problem.
May 26, 2010 | Pari AC Adapter for the Respiratory Trek...
My nebulizer has air coming out but no mist
The tube from the medicine is probably blocked. Generally needs factory service.
Apr 16, 2010 | Inspiration 626 Compressor Nebulizer...
Routine cleaning Mabis XP.
If your unit is the one pictured, he cup with the medication can be taken apart to be cleaned... the top unscrews and the nebulizer comes out....and should be done so after every use. Do not use house hold chemicals to clean the unit. Use a water/distilled vinegar mixture to clean, then rinse with clean water.
Apr 07, 2009 | Mabis Neb Xp Portable Handheld Cmpressor...
Low flow hot water in Delta Shower
Apr 05, 2009 | Delta & Single Handle Shower Faucet
I HAVE A SUNRISE NEBULIZER MODEL#46502. THE AIR
send to baroda dhmankad@yahoo.co.in mo 09426066704
Mar 23, 2009 | Sunrise Medical Economy...
Omron nebulizer will not mist. All tubing is intact. What to do?
You'll read a lot about making sure that the filter is clean and that the medicine cup is cleaned and that hard water can effect the operation of the nebulizer. However, the problem is most likely in the pump. Even though the pump is running, it is not pushing enough air into the medicine cup. You may even feel air coming out of the tube. When unrestricted, the air will come out, but, once restricted by the medicine cup, the air may not be fast enough to nebulize the liquid. If you want to confirm this, take the tube and hold it to the end of a bike pump, if, while pumpung, you successfully see mist, then you know for sure.
Fixing the pump is not too difficult. Over time, the chamber where the air is compressed becomes dry and, just like a dry bike pump, the air escapes from the chamber due to poor seals. The pump is pretty simple. Make sure it is unplugged from power and remove the screws holding the housing together. Inside you will see the motor, a fan, a power switch and the intake and outtake tubes. Follow the outtake tube to the pump. The junction where the tubes meet the pump is the location of the air chamber. You may need to remove the screws that secure the tubes to the chamber. Once apart, take some grease and lightly coat all of the interior surfaces of the chamber. When finished, reassemble and you're good to go!
Mar 23, 2009 | Omron Healthcare Omron NE-C25 COMP-Air...
Farberware Coffee Urn won't make coffee
Be sure that the washer at the bottom of the pump stem remains loose.
If coffee grounds lodge in this area, remove under running water or with
a wooden tooth pick. Dan
Dec 27, 2008 | Faberware 10-22 Cup Coffee Urn
Nebulizer portion is accumulating what appears to be saliva
well i have a inhaller tube to and yes it can be straight and it can slope down too. saliva no it's not possible but it could run down your cheek. or you could go and ask where ever you got the nebulizer from
Dec 01, 2008 | RTO Spider Nebulizer
Health & Beauty Logo
170 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Marvin
Marvin
Are you a Health and Beauty Expert? Answer questions, earn points and help others
