I'm trying to clean a used LG Fuzzy Logic WF T655TH washing machine, and not sure how to remove all bits for cleaning. Also I need operating instructions.
SOURCE: LG Fuzzy Logic WF-T7030TP Turbodrum Sensor
Error Peurta
Posted on Mar 24, 2008
  • 22 Answers
SOURCE: LG fuzzy Logic 5.5 WF T552
check drain to see if plugged. if it can't spin water out, it will shut down.
Posted on Oct 21, 2008
  • 6 Answers
SOURCE: I have a Brand LG
You probably have the drain hose too far down the standpipe and it is siphoning out. Check that first. If that doesn't work, look up Catriver, sounds like that cat knows his stuff. Tenbears.
Posted on Dec 20, 2008
  • 4 Answers
SOURCE: I'm using LG Fuzzy logic 6.5kg WF-S6607TC.
Check the lid cover. At the edge, there is a plastic housing some sort of a magnet. This is the magnetic sensor for lid cover open protection.
If the magnet is not there, place a magnet at the position on the washer where the housing will come in contact with the washer when lid is close.
Posted on Sep 09, 2009
SOURCE: my lg fuzzy logic wf s6607tc water level indicator
my daughter and myself give the lid cover a very hard knock and suddenly the washing machine works again.
Posted on Jan 11, 2010
I have a LG Fuzzy Logic WF-T5001PP washing mashine. It is taking longer for the water to enter. Does it have a water inlet filter that I can clean?
HI... If u see your backside of your machine there is a inlet valve (water inlet valve) open that water tube and see one small netted filter is there you just remove that filter outside and clear that filter with a tooth brush and insert it again....
Jan 15, 2017 | LG Washing Machines
How to remove the agitator in order to clean the bowl?
To remove agitators on these models, this fastening bolt must first be removed. To access the bolt, remove the cap at the top of the agitator - this can usually be done either by hand or by prying with a screwdriver. Take care if the cap is glued down
Jan 05, 2017 | Washing Machines
Fuzzy Logic 8.5Kg WF-T857 Turbodrum. How do you clean your machine and can you replace the fluff pockets?
Your owner's manual will show the amount of bleach your size tub requires. Run the machine on normal cycle that you use but do not add washing powder or fabric softener, only the bleach.
When the cycle has ended, open it up and allow to air dry.
The lint filters are replaceable and are available from your nearest LG service center or distributor.
Apr 16, 2015 | LG Washing Machines
Hi I have a LG Fuzzy Logic 8.2kg WF-8071TTP washing machine. It washes but does not spin dry. Please heelp
may sound crazy, but sometimes the water pump gets clogged and does not operate, so will not spin. safety feature, I guess.
Try cleaning out pump.
Bruno
Aug 06, 2014 | Washing Machines
Lg fuzzy logic wf t652
Front loader? Coins do get into the baffles. They may be riveted on. I would leave it alone, personally.
Dec 01, 2013 | Washing Machines
I have a LG top loader Fuzzy logic 6.5kg model WF-T655th spin cylce not working, the light is flashing. I have a load in the machine, how do I emppty the water out of it. Have misplace the manual.
I have a LG washing machine WTF655TH, it has stopped working, its full of water, but when you push the one button, it trips, how do i get it working again
Jan 16, 2012 | LG Washing Machines
My LG washing machine model-fuzzy logic WF-s6607tc, is not spinning
The filter for your empty pump is probably clogged. The machine can't drain the water in the alloted time because it is draining to slowly through the clogged filter. The machine won't start the spin cycle if all the water hasn't been evacuated. You will need to find and clean out your empty pump filter (Probably behind a little door at the bottom of the machine.
Jun 23, 2011 | LG Washing Machines
WATER COMING INTO THE MACHINE IS VERY SLOW. HOW
Most machines have an inlet filter which requires periodic cleaning. If the water hose connection screws onto the rear of the machine, unscrew the hose at the washing machine, remove the filter, rinse, clean and replace.
Apr 06, 2010 | Washing Machines
My washing machine is not draining the water properly,so when i do a wash, the clothes inside after its finished are still soaking wet and then i have to manually drain the water from the clothes. I have...
  • That the outlet hose is not kinked or raised more than 40° from the floor.
  • If you wish to remove articles when the water will not pump out, place the end of the drain hose into a bucket on the floor and allow water to drain out by gravity, noting that more than one bucketful may be present. Hook the hose into the sink again and try the spinner before removing the articles - if this fails most of the water can be baled out with a cup.
  • If the above method fails to remove the water then the pump is probably blocked - do not open the door, but contact your nearest Service Engineer.
  • Thanks for using Fixya!
    Aug 26, 2008 | LG Washing Machines
    Washing Machines Logo
    61 people viewed this question
    Top Washing Machines Experts
    Marvin
    Marvin
