Question about Fisher and Paykel GWL11 Top Load Washer
I have an F&P smart drive model GW709AU and have had to replace the Main Board and inlet valves twice. How long should the board and valves last as it costs around $500.00 each repair. It was a water problem first time maybe age the second time as I have just worked out it was about 4 years between repairs.
  • Fisher and P... Master
  • 713 Answers
Hi just read your posting.From the information on your posting you have changed your Motor Controller twice and both valves twice in 4 years,Is this correct?And both times the cost of the repair has been in the range of $500,Is this correct?In my experience as a service tech the grey control modules and water valves should last a bit longer than 4 years.It also depends on how much you use the machine and how big the loads are.By the way did you ring Fisher and Paykel for both repairs or an independent service company?Please reply with additional information on the questions and I am sure I can help you further if needed.
Posted on Aug 07, 2010
Getting fadded black horizonal patch at the top of my Toshiba Smart TV. 50L3400U How can I fix it?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Dec 01, 2016 | Toshiba 50 Class 1080p 120Hz LED Smart HD...
Fisher & Paykel smart drive
Turn machine OFF on the front panel. Hold down the Water Temp Down button and press the POWER button. Release buttons. You are in Diagnostic mode.With your service sheet ,Diagnostic chart will explain where the error lights pattern and the path to your solution are.My advice is this....there is a known problem with the wire harness connectors,and the contact that is made at the point of connection.One at a time remove each connector starting at your main control board ,some where there is a loose connection.
Jun 08, 2008 | Washing Machines
My Samsung smart tv has sound but no picture
Sounds like Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Jul 25, 2016 | Samsung 5500 Series UN32F5500AF 32" LED...
Machine wont fill with hot water
problem in hot water tap
hot water solenoid not activating to let water in
to prove either switch the hoses on the taps and press cold water wash
that proves the tap
then press hot wash and that proves the solenoid
Jul 21, 2016 | Fisher and Paykel Washing Machines
1E code display. Checked water pressure, changed inlet valve and float. Still 1E code
You need to check the voltage on the inlet valve coil terminals to see whether the main control board is actually switching the valve on to take in water.
If not replace the main control board PCB as this is the only other problem remaining.
Mar 08, 2015 | LG 24 in. LDS 5811ST Stainless Steel...
Whirlpool 6th sense washing machine main board problem, twice changed with in 3 and 1/2 years. Now inlet valve problem. why this product is poor quality or what?
There can be design issues or the board does not perform to the condition it is exposed. You can ask for extended warranty on the board and clarify for the failure . Also check for moisture within, check your voltage, check the power sockets.
Oct 15, 2013 | Washing Machines
Fisher & Paykel Washing Machine
Check out the fuses on the main controller board if they are fitted. If you need a new motherborad you can get one from Fisher & Paykel in Australia at http://www.fisherpaykel.com.au/customercare/contactus/
Sep 08, 2012 | Fisher and Paykel Washing Machines
GW709AU
You may have all the symptoms ofa faulty main board. from my memory the main driving motor is 6 phase - normally one hears of single phase or three phase- anyway if a phase is faulty or open circuited it will cause this problem. you in all likely hood have a faulty phase Transistor/ or whatever that is gone open circuit. Try a second hand board. Ps in NZ, old FP washing machines makes good power generators.
Nov 27, 2011 | Fisher and Paykel Washing Machines
Fisher & Paykel want stop filling the machine with water
The problem will be on inlet valve will be open kindly replace the inlet valve
Still the problem exists the problem will be on the main board
Jan 03, 2010 | Fisher and Paykel GWL11 Top Load Washer
Overfilling then leaking through the door and drawer
Almost definitely the pump filter is blocked.
Its happened twice on mine. Tilt machine forward to expose filter, undo clips on flexible hoses and remove filter. clean it out and replace. problem solved. about an hours job.
Dec 22, 2009 | Hotpoint WMA64 Front Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
126 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
