Question about MotorGuide STANDARD MOTOR REPLACEMENT PARTS SWITCHES AND COMPONENTSDescript
I have a motorguide tracker 40 Bow mount. How do you operate the steering.
3 Suggested Answers
SOURCE: Foot pedal on Motorguide is out of time with steering...
There should be a couple of allen screws on the shaft that you can loosen, which should allow you to swing the motor head in the direction you want it to be pointing for the desired pedal position. Tighten and carry on.
Posted on Jul 24, 2009
SOURCE: Wire going to prop of Motorguide trolling motor shorted
Unless you are mechanically inclined, dont attempt this. Take the lower unit apart by removing the prop and removing the two bolts that hold the forward and aft housing to the center housing. Fwd being the cone shaped part. Pull the aft housing away from the motor so you can inspect the connections to the board that holds the brushes and the soldered wiring terminals. You should find the solder missing from at least one of the terminals that connects the wiring from the foot switch to the speed control windings inside the aft housing. Clean up the terminal and wiring and re-solder. Also re-flow the solder on the other terminals. Clean up the seals and the area where the seals meet the housing parts. Replace seals if damaged. Reassemble the lower unit and torque the bolts 45-50 in-lbs and no more otherwise you will fail the seals. This problem is due to a "cold" solder joint that creates a high resistance to elec current flow and heats enough to melt the solder. This is a result of poor quality control at the manufacturer. Good luck.
Posted on Dec 29, 2011
Steering cable broke motorguide tr109 45
any marina/boat dealer and yes u can..rather simple too.
Aug 06, 2012 | MotorGuide Tour Series Freshwater Bow...
I have two 36 volt 107 lb thrust Great White motors mounted on the port and starboard sides of the polling tower of my flats skiff. My fishing application has changed and I wish to mount one of the motors...
Yes it should do, this is the bracket
Motorguide MGA515A2 Great White Troll Motor Removable Mount 17031 eBay
schematic of parts
http://www.boats.net/parts/search/Merc/Motorguide/2006/950010220/Gator%20360%20Flex%20Mount%20(Black)(MST9360FW)/parts.html
this is the installation instructions for the Gator 360
http://www.motorguide.com/userfiles/file/Support/InstructionSheets/Gator-360-Flex-Mount-Instruction-Sheet.pdf
Jul 23, 2017 | MotorGuide Boating
Jun 01, 2009 | MotorGuide STANDARD MOTOR REPLACEMENT...
54lbs bow mount. Unit only working in reverse!
Reverse the wires coming from the battery. good luck
Jan 01, 2009 | MotorGuide STANDARD MOTOR REPLACEMENT...
MotorGuide STANDARD MOTOR REPLACEMENT PARTS SWITCHES AND COMPONENTSDescript Logo
616 people viewed this question
Top MotorGuide Electrical Supplies Experts
Craig Butler
Craig Butler
Ian Summerfield
Ian Summerfield
Mike
Are you a MotorGuide Electrical Supply Expert? Answer questions, earn points and help others
