Question about Logitech QuickCam Messenger Web Camera
I have a logitech webcam STX which does not work on windows live messenger It formerly worked well and no changes made to my computer except adding a program which scans and "repairs errors" once a day Can you help me?
  • Logitech Master
  • 3,015 Answers
Set your webcam mic (if it has one as default)
Vista - If you have an earlier OS, you may have to access your hardware from the Control Panel.
Plug in the webcam
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
Test your webcam here to make sure it broadcasts ok - Hit 'Allow' in the top window and check your cam in the left hand panel.
http://www.testmycam.com/
If it fails to work here concentrate on your webcam drivers and software before moving forward.
Having proved your cam is working ,you can configure it to WLM (MSN)
CONFIGURE SOFTWARE to MSN
Its good practice to disconnect and re-connect your webcam before you start - if you have been using it elsewhere the MSN software may have difficulty in locating it, even if you exited the previous program correctly.
The reason being, the webcam software can remain hooked-up to a program and needs to be rebooted.
Mine, I just unplug it from the USB and plug it back in to reboot the software.
If yours is integral with the computer you will have to re-start the computer, use a keyboard shortcut or disable / enable the webcam from the Device Manager.
Open MSN
Click 'Open Menu'
From 'Tools; navigate to, and click, 'Audio and Video setup'
Set your speakers
Click 'Test' - if OK, move on.
Set your mic as default
Use the slider to set volume and test.
Click 'Next'
This takes you to the video setup
Your webcam should be broadcasting - (if not - make sure the webcam is set as default - restart MSN)
Use 'Webcam Settings'to fine tune the picture.
Click 'Finish'
Posted on Aug 06, 2010
Logitech e1000 notbook doesnt connect to others msns
if you are using a proxy server ...you have to fix the messenger on that server too ( and otherwise if its setted on a proxy and you are using a broadband.... high speed ......)...also ...try to upgrade the windows live messenger to the last update ...if you are using the one it was installed with the windows..its not gonna work until update ..
Apr 07, 2009 | Logitech QuickCam Communicate STX Personal...
Logitech STX
Normal 0 Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype set it up as follows:
  1. Go to TOOLS, then OPTIONS, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if installed properly will come up and show a picture.
  4. Then on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now see and talk to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
C. Windows Live Messenger:
  1. After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
  2. Then on the Windows Live messenger window on the right side, click on “ “Show Menus.” And then click on “Show the Menu Bar”.
  3. Next go to the Menu Bar on right side, click on “ “Action.”
  4. Go to “TOOLS” and click “Audio and Video Setting” and follow the instructions.
NOTE: You audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
Hope this helps. Bud
Jan 11, 2009 | Logitech QuickCam Communicate STX Personal...
I am having touble connecting to the internet with the webcam. We have uninstalled, then reinstalled, and updated all software and yahoo messanger. We have the Logitech Quickcam communicate stx. Please...
Did u try checking the USB cord?Sumtimes faulty cords can coz problems.Try videoing normally thru ur webcam without the internet.Most webcams come equipped wit a software that allows u to film or tek photos using ur webcam.U can use that software or (if u have windows) u cud go to start>accessories>camera&scanning wizard.
And if that doesnt work try to check the settings in yahoo massenger.Go to messenger>privacy settings>click the related tabs and good luck.
And if that doesnt work,,,,,,,,try windows live messenger....
Open a chat window and go to tools>audio and video setup(or something like that) and follow the instructions.
Thats all i gt..........Hope it works 4 u.
If evrything fails,u shud get a new and more simple webcam.....XD or try getting help from the proffesional people,
Dec 25, 2008 | Logitech QuickCam Communicate STX Personal...
My Logitech quickcam STX works only with mic webcam or mic with yahooIM
A. Skype Setup:
B. Yahoo Setup:
NOTE: You audio and video shoud work. Enjoy.
Mar 01, 2008 | Logitech QuickCam Communicate STX Personal...
I've bought a logitech quickcam communicate STX. When I installed it first it worked fine. Someone unpluged it from the usb port and it wouldn't work. I re-installed the drivers and it was fine again but...
The microphone may not work because of a hardware or configuration problem. To determine if it's a hardware problem, test the microphone in Sound Recorder.
  1. Click "Start," > "Programs" ("All Programs" for Windows XP) > "Accessories" > "Entertainment" > "Sound Recorder."
  2. Click the Record button and speak into the microphone of the camera. You should see the green line move, indicating the application is picking up sound.
  3. Click the Stop button.
  4. Click the Play button. If there is no sound at playback, check to make sure the correct device is selected.
    1. Click "Edit," then "Audio Properties."
    2. Make sure Logitech is listed as the Preferred device for "Sound recording."
The microphone may also be defective. To test this, try the camera on another USB enabled system.
If you can record sound in Sound Recorder, but not in the QuickCam application, try setting the Logitech Microphone as the Preferred device in Audio Properties.
Feb 25, 2008 | Logitech Webcam
Built in Microphone doesn't work in AIM, Windows Live Messanger
You would be surprised at how many people don't realize that each application has it's own configuration screen.
It's not the end-users fault - like you said... the instructions could be a BIT more clear.
Feb 12, 2008 | Logitech QuickCam Communicate STX Personal...
Logitech quickcam pro for Notebooks and windows live messenger
its the vista been told buy many people its not very good best bet is xp some things arent suppotred by vista yet as its new
Dec 30, 2007 | Logitech QuickCam Communicate STX Personal...
Logitech quickcam communicate stx
Check the camera settings are not too high 320x480 or similair should be enough. Have you installed Windows Messenger live, the new MSN and tried it with that? If your'e problem persists try this problem page. http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=534&p_created=1087233145&p_sid=tDSxcPki&p_accessibility=0&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PWRmbHQmcF9ncmlkc29ydD0mcF9yb3dfY250PTQyMiZwX3Byb2RzPSZwX2NhdHM9JnBfcHY9JnBfY3Y9JnBfc2VhcmNoX3R5cGU9YW5zd2Vycy5zZWFyY2hfbmwmcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD13aWxsIG5vdCBpbnN0YWxs&p_li=&p_topview=1
Mar 04, 2007 | Logitech QuickCam Communicate STX Personal...
Logitech QuickCam Messenger Web Camera Logo
37 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
