Question about Canon Digital Rebel / EOS-300D Digital Camera with EF-S 18-55mm Lens
Is there a diagram for spring setup for the sub mirror on my canon 300d the mirror has a small mirror under it witch should lift but the spring came off and i can't get it to work right.
Lost spring or broken pin inside the mirror box.
Posted on Oct 12, 2010
Linkage problem,
Make sure lens is set on AF and not M. Clean body and lens contacts with a Q-tip dipped in alcohol. Try multiple lenses to make sure it is not a problem with just one lens. Put the lens on M and turn the front and make sure it turns freely and is not stuck by impact/spillage etc. Push down on the release button and make sure you have two distinct 'pops' (release switch may be broken). Gently lift up mirror and make sure that the AF sub mirror also comes up properly. Impact can break the little plastic guide pin for the sub mirror so that it is not in the right position and the AF will not work. Also make sure that the spring that makes the sub mirror come up is in position (they come off). Can be on either the right or left side of the mirror depending upon the model.
These are the steps I would take if you brought your camera into the shop I work at.
Apr 28, 2013 | Canon Rebel Cameras
Bottom 3/4 of photos are black
Check out this website http://www.lotek.nu/misc/EOS_300D_sub-mirror_repair/
I had the same problem. You can check to make for sure by removing your lens, and carefully lifting your mirror. Does the sub mirror underneath flatten against the other one when you lift it? That's probably what is in the way creating your 3/4 "black" picture. I just repaired mine as in this website, and the mirror moves great now! Of course, I'm used to taking apart laptops and such. If you have a warranty yet, contact Canon. It is a defective issue on there part.
Mar 12, 2009 | Canon Digital Rebel / EOS-300D Digital...
Canon EOS 300D Loose primary mirror
Absolutely. Glue away. These mirrors of course in no way effect image quality, but you still want to be careful with the glue, and make sure the mirror stays aligned so it's free to flip up.
Hope this helps
Jul 06, 2008 | Canon Digital Rebel / EOS-300D Digital...
Bottom 2/3 of photo is black
It sounds like your autofocusing mirror is loose and obstructing the shutter.
Apr 03, 2008 | Canon Digital Rebel / EOS-300D Digital...
Canon 300d autofocus problem
Have you choose a correct "Focusing Point" by pressing the right outmost button on the rear of the body, just above the CF card compartment door?
Feb 23, 2008 | Canon Digital Rebel / EOS-300D Digital...
Canon Digital Rebel 300D
id recommend taking it to the canon dealers..this seems like a problem with the software
Nov 29, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Infamous error 99 (again!)
shutter mechanism of canon 300d lasts for around 5000 shots or less!! yes it is made of plastic materials thats why here in the philippines I am making my own metal replacement parts that lasts. Unfortunately, in your country you cant do anything but to replace it with same original replacement parts. avoid using faster shutter speed and continuous shots.
Nov 12, 2007 | Canon Digital Rebel / EOS-300D Digital...
My 300D wont lock on a point in its AF setting
If you are unable to focus in broad daylight and it just hunts through the whole focus range without locking, then it sounds like a problem with sub-mirror pin (also called the second mirror pin). My 300D just had this problem and I had to send to service to get fixed. I sent to http://www.keh.com/ as they were at least $50 cheaper than going straight to Canon. Just got it backed and it works like a charm again.
Jul 24, 2007 | Canon Digital Rebel / EOS-300D Digital...
Camera won't take a picture
It could be that the shutter has gone out or the mirror is not going up they are only rated to last for so many shots. That is what canon told me when my 10d did the same thing. I dont remember what the repair cost was.
May 28, 2007 | Canon Digital Rebel / EOS-300D Digital...
Pictures captured by my camera are not complete
your cmos sensor might be dead. try taking it into canon for repair.
Sep 04, 2006 | Canon Digital Rebel / EOS-300D Body only...
Canon Digital Rebel / EOS-300D Digital Camera with EF-S 18-55mm Lens Logo
212 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
