Question about Haier 539490003 Air Conditioner
During a storm our air stopped working - Haier 539490003 Air Conditioner
Ethernet was working but suddenly stopped. Turning modem off/on did not help. Wireless access still works fine.
Some times a reseat of the cable will clear the deposits that will build up on copper contacts, I live in South Florida, hot, humid, salt air, it happens all the time. Also, during storms, we have many hurricanes, unplug all devices, it would be a shame to distroy all your electronic toys.
Nov 07, 2012 | Actiontec Electronics (GT724WGR) Retail...
Stopped working during a rain storm
Short circuit or fuse blown. Call electrician and check it.
Aug 17, 2012 | Heating & Cooling
My 1998 jaguars xj8L stopped starting after the rain storm 2 days ago. I did not drive the car during the storm and the car did not flood. I got a new battery and new spark plugs. The car tries to turn...
as crazy as this sound, Was there lighting during the storm? my car was parked under a tree that got hit by lighting and had to replace the ecu.
Apr 07, 2012 | 1996 Jaguar Vanden Plas
My internet works but it stopped working on my xbox during a lightning storm and ive tried all my imputs
That very common when systems are connected directly to a router/modem after lightning storm. your best bet is buy a usb wireless adapter.
Thanks
www.1RepairStop.com
Aug 30, 2011 | Microsoft Xbox 360 Console
Air conditioner went out during thunder storm and now only blows out hot air. How can I fix this problem?
check to make sure outside unit is running. power failures can damage alot. if it was running during storm.
Jun 17, 2010 | Bryant 463AAC005BA Air Conditioner
Lightning storm and all hdmi connections stopped working
It may be a problem with the DVRs. You can rule that out by connecting a different HDMI TV to one of the DVRs.
Aug 29, 2009 | Westinghouse TX-42F430S Television
Re: Kenmore Plasmaire air conditioner; suddenly stopped working during night. Motor will initially turn on but no air coming through, then will stop
Most likely you have a bad fan,did you have a storm or lighting strike or power drop / outage .
These type of things can cause trouble with a weak electrical part - not know the age of the Unit - you claim it happen in the middle of the night - if the fan Humms and cut outit could be a cap. that helps you fan start - but the fan is damaged if it tryed to start time and time again . Call service if the unit is worth it .
Jul 17, 2009 | Heating & Cooling
My maytag m7y12f2a stopped working is their any reset buttons
All devices that have circuit boards or digital displays need a surge protector or turn off during storms. If none of the functions or dispays don't come up, there may be an inline fuse on the panel. More than likely the board or transformer is fried. For that you need a Tech.
Jul 09, 2009 | Heating & Cooling
Amana wall ac unit
Try using your remote to turn it on. This is what worked for me. Hope it helps!
Sep 06, 2008 | Heating & Cooling
Patriot Air Storm stopped working
When suction is stopped, it is due to a clog in the hose, or the dirt inlet by the brush roll. Filters if clogged can cause this also.
Mar 23, 2008 | Vacuums
Haier 539490003 Air Conditioner Logo
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Michelle Balcom
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
