I HAVE SONY XA21 M93 WEGA TV, VERY FREQUENTLY IT WILL NOT SHOW PIC AND SOUND. INSTEAD POWER LED WILL BLINK. SOMETIME IT STARTS AND WORK NORMALLY.
nfandres
  • 168 Answers
SOURCE: TV not working
the symptom is usually caused by a breakdown in the power supply circuit. in most modern receivers (transistorized and/or ic), it may also be caused by a breakdown in the horizontal deflection circuits (hor. oscillator, pre-drive, or drive circuits). supply voltages for the tuner, video if,sound if, and vertical output are usually supplied by the horizontal output circuit. but if you doesnt know anything about these stuffs, better bring it to a qualified service tecnhician.
Posted on Jan 20, 2007
  • 61 Answers
SOURCE: Sony Wega 40" TV will not turn on, standby light blinks 6 times repeatedly
Hello,For model KV-40XBR800,
Pls check following area.
Low HV Shutdown:
On the D Board.
Check IC8004/pin 7 should be 7.4v.
Check IC8006/pin 2 should be 2.5v if lower will trigger shutdown by causing pin 1 to turn on.
Check IC8006/pin 3 reference voltage 2.2v.
IC8006/pin 1 normally at 0v. If high
turns D5007 ON which turns the latch circuit Q6532,
Q6530, and Q6527 ON and turns the AC relay RY6501 OFF.
And NOTE: 6 blinks also can be Low B+ protection.
Unregulated 7.5 v from the power supply to 5v reg IC504 on the A Board. 5v to M Board Q2314
to CPU IC2300/pin 43. If 5v missing set will shutdown with 6 blinks.
Good Luck
Dals123
Posted on Oct 15, 2008
SOURCE: Sony FD Trinitron WEGA Tv KV32FQ86E two flashing led
Check 470 uF 450 V in the power supply. I don't know if the chassis is the AE-5, but I had a similar case and the capacitor was bad.
Please tell me if it worked.
e-mail: jlopes.electronica@sapo.pt
Posted on Jan 22, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: my 32'' sony wega blinks 5 times
The 5 blinks means a problem in the set's AKB (auto kine-bias) circuit. Sony TV's monitor the operation of the picture tube. When some kind of trouble has been detected, the TV blanks the screen and flashes the 5 blink error code. This may be due to problems in the video circuit, a bad picture tube, or adjustments that have changed due to aging of parts. There isn't anything I can suggest you try on your own to fix it. Because several things may cause the problem, and the proper tools and service information needed to troubleshoot, you should refer this repair to a professional.
Posted on Feb 17, 2009
localwonder
  • 6784 Answers
SOURCE: TV won't turn on, standby LED starts blinking
HI, this is the result of an unstable power sector in this unit. the fly back is malfunctioning and, you will need to replace it asap. i will list the part number below and a link to a site as well. you can purchase this part on-line if you wish.
FBT ASSY NX-4521//X4
Sony Part Number: 1-453-310-11
CLICK HERE TO ORDER
Posted on Jun 21, 2009
My Sony Trintron's LED Light blinks 9 times when I try to turn on the set
  1. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negative). If you wish to get more details about the blinking codes to Sony brand TVs, check this link. Pull up older posts there.
Mar 04, 2013 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony wega kdf42we655 power led blinking red
If lamp light is on at tv front then replace lamp as existing lamp sounds dead/ broken.
Lamp replacement procedure would be written in user manual of tv.
And if lamp light is not on but standby light is blinking then let me know how many times it is blinking to find out problem cause as standby light blinking is an error code.
Mar 25, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
No pic/sound lite blinks red and sometimes lamp
Need lamp replaced first.Find out it work or more problems to fix.
Jan 07, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
Our 32" Sony Wega CRT TV randomly shuts off. It starts to dim then completely shuts off. This is happening at faster intervals. (Shorter on times)The indicator led blinks 6 times after the random shut...
monitor if b+ voltage normal, if fluctuate check for the power supply area ckt parts for some discrepancy on biasing. if supply normal check on horizontal section area also replace crystal capacitor and check.
Aug 22, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Grand WEGA KF-50WE610 LED blinks 4 times
4 times blink shows Temp Error and requires temperature sensor replacement in Sony KF-50WE610 TV
May 21, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
TV powers off for no reason
Its your bulb on its way out.
the replacement bulb is a Sony XL-2400 But yours should definately be under warranty
Mar 20, 2009 | Sony KDF46E2000 46" Projection HDTV
Kv-32s120 standby LED blinking no sound or picture
How many times does the timer light flash between pauses?
Sep 05, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
SONY TV
how many times the led blinks?
Jul 31, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
