Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
How to fix a P0420 code for Honda Accord LX ?
  • 2,272 Answers
The code PO420 you have is Catalyst System efficiency is below threshold bank one. Usually replacing the O2 sensor that's the front most in the exhaust system will cure your problem,
Your Check Engine light is on and you find a P0420 code for a catalytic converter fault. Does that really mean your converter has reached the end of the road and needs to be replaced? A new converter can cost $600 to $1000 or more if a new car dealer or repair shop does the job, or maybe half that amount if you do it yourself. It's an expensive fix that may or may not be necessary. The problem, in most cases, is an emissions issue, not a performance issue that affects the way the engine runs.
A P0420 diagnostic trouble code is a "generic" fault code that is set when the Onboard Diagnostic II (OBD II) system sees a drop in converter efficiency. The OBD II system monitors catalyst efficiency by comparing the switching activity of the upstream and downstream oxygen sensors in the exhaust. The upstream O2 sensor in theexhaust manifold reflects the condition of the exhaust gases as they exit the engine. The downstream O2 sensor in or behind the catalytic converter reflects the condition of the exhaust after it passes through he converter.
The catalytic converter is like an after-burner. It oxidizes (burns) any residual fuel vapors (unburned hydrocarbons or HC) in the exhaust. It also burns any carbon monoxide (CO) in the exhaust. The exhaust must meet federal emission standards, and if a problem exists that causes emissions to exceed the federal limits by 150%, the OBD II system is supposed to catch the fault, set a code and turn on the Check Engine light.
Thanks
Posted on Oct 01, 2010
I have a PO 420 code on 07 accord. Does that mean my catalytic converter is bad?
Usually does. But I check the O2 sensors first. Ohm check them and the wires. Your cats are expensive, I don't won't to misdiagnose.
Feb 07, 2015 | 2007 Honda Accord Sedan
My 1996 honda accord lx did not pass smog due to
these codes indicate there is a miss fire on cylinders 1 and 2 hence the 0301 and 0302 code the 1300 just indicates multiple engine miss fires. so anything that can cause these cylinders to miss fire need to be attended to in order to fix your problem.
Sep 20, 2014 | 1996 Honda Accord
I HAVE A HONDA CIVIC LX 1998 WITH 122,459 MILES AND I TOOK IT TO AUTOZONE AND THEY GAVE ME THE CODE P0420 THE CAR RUN GREAT BUT THE MUFFLER IT HAVE A WEIRD SOUND.
Catalitic convertor needs replaced, if this an automatic trans you willexperience shiftinf problems abd loss of power.
Mar 26, 2013 | 1998 Honda Civic
I have an 02 accord that has the check engine light on. Its got 145000 miles on it. I got it scanned. The codes were p1259 vtec system circuit fault bank 1, p0420 catalyst system efficiency below...
Fix the P1259 code first. Are you using the recommended oil viscosity? If not, change that immediately. Also, check the screen in the Vtec solenoid for sludge buildup. If the variable valve timing isn't working properly, it can cause the P0420. If not fixed soon, that can destroy your cataltytic converter. The P1457 code is less important.
http://ricksfreeautorepairadvice.com/motor-oil-viscosity-warning/
Jul 19, 2017 | 2002 Honda Accord
Need wiring diagram for 1992 honda accord lx to trace
I need honda accord lx wiring diagram for free
Feb 09, 2012 | 1992 Honda Accord
Hi could u tell me what end of net code means my honda accord had a diagnostics and mechanic said that
I never say a code call "end of net" before, are you sure? Code are usully PXXXX(example:P0420,P0300, etc...). You might want to have it double check.
good luck
Jan 20, 2011 | 1996 Honda Accord
Code P0420 - what does that mean? The car is an
Code P0420 probable cause, 1. Secondary HO2S (Sensor 2) or 2.Three Way Catalytic converter.
Aug 15, 2009 | 1997 Honda Accord
Honda accord lx
coolant temperature sensor....MAP, MAS, vacuum leak ......check codes and advise
Jan 13, 2009 | 1998 Honda Accord
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
1,022 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
