Question about Sanyo PLV-Z2000 Projector
Problem is, turning on the project the slide opens but then closes 15-30 seconds later, yellow filter light is steady and power light turns steady red... manual says send to dealer for repair but I'm trying to avoid resorting to that - any suggestions?
  • 89 Answers
Try cleaning the air vent filter and reset the timer.
Posted on Aug 10, 2010
Turns on with snow and yellow light under lamp. Why does it shut down after 20 seconds?
yellow steady light is overheating. you have a stuck fan or its all clogged with dust. The only way to fix it is to find what is causing it to overheat or prevent the fan from spinning. It is not lamp related unless you bought a lamp that does not have an Osram bulb inside.
Sep 08, 2015 | Mitsubishi WD-65734 65" HDTV
I turn on my set and the power light comes on for 2-3 seconds then the set turns off. What causes this to happen?
F power light comes on and a few seconds later goes off, do the self check this model has.
On front of set when this happens, press and hold both the menu and input (device) buttons at the same time for at least 5 seconds and then release both buttons.
Watch the power light closely, it should blink a two digit error code like; 2 blinks, 2 blinks, a pause and then repeat it several times.
Let me know what error code you find and I will tell you what it means.
SD TECH
Dec 11, 2010 | Mitsubishi WS-65411 65" Rear Projection...
I have a philips dlp 55pl9773 has one red flashing led on the front when i do a hard reset tv boots up lamps lites led goes from flashing yellow to green for about ten seconds and then back to red flashing...
MY philips tv model number 55PL9773/17 WAS TURNING OFF THE SCREEN AND LEAVING THE AUDIO ON FOR ONE MINUTE. THEN THE YELLOW LIGHT STAYED ON. THEN THE LIGHT TURNED OFF. thEN I TURNED ON WITH THE REMOTE AND THE YELLOW LIGHT TURNED ON AND A FEW SECONDS LATER CHANGED TO THE GREEN LIGHT AND THE TV TURNED ON. AFTER A FEW MINUTES, BETWEEN 10 AND 30 IT DID THE SAME THING. NOW IT IS OFF WITH A BLINKING RED LIGHT PERMANENTLY ON. TO TURN IT OFF I HAVE TO UNPLUG IT FROM THE WALL. I REPLACE THE LAMP A FEW WEEKS AGO AND IT IS FINE.
Dec 01, 2009 | Philips 55PL9773 55" Rear Projection...
Turn on the tv a few seconds later it shuts the power light blink
Replace both of your convergence ICs they are STKs big black ICs will have part number on them.
Jun 19, 2009 | Mitsubishi WS-55511 55" Rear Projection...
When turning on the TV the green light on the front does not come on. You hear a click and then about ten seconds later you hear another click but the tv never comes on.
What light do you get, green blinking, red blinking, yellow steady light or yellow blinking light. The led lights will tell what is wrong with your tv.
Jun 12, 2009 | Mitsubishi WD-52327 52" Rear Projection...
TV was working earlier, today came home no green power light no nothing
I looked up the manual online - after you replace the bulb, you need to reset the bulb life timer. Using the TV remote push the menu button, SETUP menu, select the lamp reminder option to reset the hours to zero. That might help the status indicators.
Sep 04, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Tv keeps turning off?
cutta, you will most often hear a click on boot then the fans start up and lamp will then fire. The picture will start to show up....at what point does it shut off? and do you hear a click when the tv is turning off? Is it the complete tv shutting down, fans and everything that turns off? Do you see any lights on the the front panel "POWER", "STATUS" or "LAMP", what are they doing? If you see a Power, Status or Lamp light after it shuts off the below are what they mean if there is an issue. POWER - STATUS - LAMP - CONDITION/ISSUE: Off - Yellow - Off - Temp. high/dirty filter/excess room temp Off - Off - Yellow - 4000 hrs. Lamp usage warning Off - Off - Blink Yellow - Lamp Cover open Off - Blink Yellow - Off - Air Filter Cover open Off - Off - Red - Lamp failure (failed to turn On or broken) Off - Blink Red - Off - Fan Has Stopped Off - Red - Off - Circuit failure (short) or DVI cable disconnected If you want to check for the last "Error Code", after you first turn the TV on, by pressing the front panel ?DEVICE? and ?MENU? buttons at the same time and holding them for 5 seconds, it activates the Error Code Mode. The ?Power LED Light? blinks/flashes (1/2 sec delay) and then flashes again denoting a two digit Error Code indicating no problem or an error has occured since the last Initalization. i.e. "Power light" blinks 3 times (1/2 second delay) and then blinks 4 times then 1 sec delay and repeats a few times. This would mean "Error 34 - Lamp abnormality". See below for error codes..... Error Code - Description or issue 12 - No Error detected, check Power Supply 32 - Lamp Cover is open 33 - Air Filter Cover is open 34 - Lamp abnormality 36 - Light Engine (DMD or LAMP Fan stopped) 37 - Exhaust or Lamp Ballast Fan stopped 38 - Lamp temperature high 39 - DMD temperature high 41 - Short is detected 44 - DVI cable between FMT & Engine disconnected. Sorry for the long answer but it was an open ended question.
Jul 11, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Sanyo PLV-Z2000 Projector Logo
117 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
