Question about Palm Treo 600 Handheld
Blue screen Treo 600
Hi, my treo 600 is working (as far as receiving calls and making blind ones too :D ) except that the screen is completely blue! I performed a hot sync as well as soft and hard resets--to no avail. I think I may have caused this problem after placing small metal stick inside the charger port in an effort to remove some paper that was stuck.
  • 5 more comments
  • Artbell Apr 27, 2008
    Yes, it's just the screen that's completely blue. In essense no screen. It's a lit blue screen :D
    Taking it to a professional ---could cost $$$, thought there was something I could do.
    I finally was able to open the phone. It appears that the battery is glued in place. Not sure I can remove it.
    The battery connections are different on the Treo I have (it is literally glued in place and the wired is connected to the battery) I am unable to disconnect the battery, for the wired is glued on. It is not like the one shown on the site you sent. Hmmm...
    It looks like the battery is hotwired.
    Here is an image.
  • Artbell Apr 28, 2008
    The other end of the battery is different. It's directly connected to board.
    I performed the battery reset. Treo is currently plugged in to the charger. Screen is still blue--wonder if that'll change once battery is fully charged.
    Thanks.
    Art
    Okay, here's what occurred. After resetting the battery and charging it--nothing happened changed except that every time I pressed a key a sound would be heard. Now I couldn't even make a call! I was about to take it to the T-Mobile store when I thought--I'll sync it to the computer. The screen was still Blue though and even the thought to hot sync it seemed futile I still went ahead and plugged it in. The moment I did the screen came on!!!!! As it had when I first purchased the phone. I have my phone back. Thank you so much!!!! For what a a couple of days it has been without the phone.
  • Palm Master
  • 13,433 Answers
This can be difficult to fix, I supose the motherboard is fine since you can make calls and so on.
Must be the screen then?
Posted on Apr 27, 2008
  • 8 more comments
  • Ekse Apr 27, 2008
    if you have a custom case for the phone, remove it.
    Someone had a problem with a custom case that was made out of a certain material and it interfeared with the phone, hes screen went blue every time he receaved a call.
  • Ekse Apr 27, 2008
    its possible that the metal stick caused it. very hard to say from here.. Id have to phone checked by someone professional. as I beleave I live in the other side of the world I cant really do that.
  • Ekse Apr 27, 2008
    I beleave the problem is either in the lcd screen or then somewhere in the mainboard. But I cant say for 100% sure.
    Thats what I can say from here :)
  • Ekse Apr 27, 2008
    the lcd screen can be fine, but something is interfering with it maybe.
  • Ekse Apr 27, 2008
    if you wanna try something youself.
    btw this probably removes all your personal data.
    open the device up and remove the battery for a while.
    also check if theres anything odd in there.
    Heres something I found from youtube
    You dont need to fully dismantle it to remove the battery, I beleave its the blue thing in the video.
  • Ekse Apr 27, 2008
    heres the battery replacement guide
    http://www.gethightech.com/Merchant2/mer...
    Just remove it for a while- 30 mins Is probably enought.
  • Ekse Apr 27, 2008
    hmm, theres actually no need to really remove the battery just the connector.
    do you have a camera? could you post a picture of the connector / battery to me.
  • Ekse Apr 27, 2008
    if we cant remove it then lets not remove it, I don't want you to make it worse.
  • Ekse Apr 28, 2008
    It looks as its the same connector expt its glued in as you said. I supose if we wanted to remove it the glue would need to be removed, is it the same in the other end?
    Heres another way to 'disconnect the battery'
    Battery Disconnect Reset
    Treo 600 only
    A battery disconnect reset is a last resort step you can take to cut battery power, wipe all data, and regress a Treo 600 to its factory-fresh state. It only works on a Treo 600 smartphone.
    Important:
    A battery disconnect reset will erase everything on your smartphone, and also reset the wireless radio and disconnect the internal battery. All your data will be removed, and your formats, preferences and other settings are restored to their factory default settings. Don't perform a battery disconnect reset unless you've backed up your data, or you're willing to lose everything.
    You won't be able to turn your Treo 600 back on until you connect it to a power adapter, so do not perform this type of reset without your Treo 600 charger and a power source.
    HotSync note: Some third-party applications change the way your handheld backs up data. Other third-party applications do not back up data. If you have third-party software on your device, please contact the developer to learn what components are backed up during a HotSync operation, and if HotSync conduits are altered. Any data not backed up will be lost.
    To perform a battery disconnect reset:
    1. Disconnect your Treo 600 from the AC charger.
    2. Hold down the K and Backspace keys simultaneously.
    3. While continuing to hold down the K and Backspace keys, press the e RESET button inside the hole on the back panel of your device (where's the reset hole?).
    4. Finding it hard to do? Good. We made this type of reset very awkward to perform, so that it would not happen by accident when your Treo 600 is jostling around in a pocket or bag. Sorry for the inconvenience. You might want to ask a friend to lend a hand if you find it too difficult to do by yourself.
    5. Continue holding down K and Backspace. The screen will flash white briefly, and then go black. Release K and Backspace after this happens. Your Treo will appear to be "dead" and the screen will not turn on. If you see any activity — such as the screen turning back on — the reset was performed incorrectly; try again
    6. To revive your Treo 600, connect it to the AC charger and plug the charger into a socket. The screen will stay blank for several seconds (as long as half a minute), then it will turn on. The LED will glow solid red, indicating charging.
    7. Finally, follow the steps for recovering after a hard reset (a battery disconnect reset is an extended type of hard reset).
  • Ekse Apr 28, 2008
    Ok, thats all we can do remotely I recommend you take it in to be checked / repaired. as I have no idea what is causeing the problem, or how to fixit without haveing a carefull look around the internal workings of the phone.
    this treo had a visit to the toilet
    http://mytreo.net/forum/index.php/topic,...
    "the screen initially was blue..." would indicate that both problems really are hardware issues. I wonder what happened to yours =/
    possibly you harassed it with the stick to death, dont know. =P
Palm treo 680 receives call but can't make calls
Same problem, but mine began, when I changed between one Sim (telcel) to other SIM (Movistar).  Whith the second my phone works fine, but with the first carrier, all sims failed to make phone calls
Apr 02, 2009 | Palm Treo 680 Smartphone
My palm treo 600
the 600 and 650 are junk get rid of it!trash!
Jan 31, 2009 | Palm Treo 700w Smartphone
Transfer of treo programs to Palm Centro
The Centro and Treo are virtually identical. Have you tried reinstalling the applications from scratch on the Centro (vs. relying on Palm synch to automatically synch all applications)?
Aug 25, 2008 | Palm Treo 600 Handheld
Palm Treo 600 Callers can't hear me when I answer
dang, no solutions... I have the same problem exactly
May 11, 2008 | Palm Treo 600 Handheld
Treo 600 Completely Blue Screen
I's sorry to tell you your screen is dead. The screen is not displaying any information but the backlight is still functioning. This is the most expensive part of the phone as far as replacement parts and after-market parts. If you can fine one that is a reasonable price, you are very fortunate.
I have three screens like this at home. There are three layers to the screen, the backlight, the imager, and the digitizer. All three sandwiched together create the screen.
If the phone was on when you fished around the charge port, it is possible that you inadvertently caused a charge or grounded the charging/power circuit. You are fortunate that only the screen was damaged...if that's the only part that is damaged.
Apr 26, 2008 | Palm Treo 600 Handheld
Treo 600 dropped calls
Try hard reset your phone
Dec 15, 2007 | Palm Treo 600 Handheld
My Treo Hard resets repeatedly
Do a simulated-battery-disconnect reset. This is a harder reset then the hard reset. It will simulate disconnecting the battery at a hardware level, so it will completely toast anything on your treo that might be causing the problem. Don't worry it won't hurt your firmware or anything, just all the data will go.
Hold down the BACKSPACE key, and the K key.
While holding it, press and hold the reset button using the reset tool on the stylus.
Hold all three for a few seconds. The treo should turn white, then turn off. If it won't come back on, then you've succeeded.
To get the treo to turn back on, plug it into the charger cable. In a few moments the treo will turn back on, and ask you for your language and regional settings, just like when you first bought it.
If this doesn't fix it, you have a hardware or firmware problem that will be far more difficult to diagnose/fix.
Dec 14, 2007 | Palm Treo 600 Handheld
Palm treo 600
No, the pixels are broken.
Nov 02, 2007 | Palm Treo 600 Handheld
Treo will not complete call
Try with a new battery, also the connection cable between the battery and the main board uses to loose contact, try unplugging and plugging again the cable which connects the battery with the main board. A symptom that the battery is loosing power is that the screen flickers while making a call.
Aug 30, 2007 | Palm Treo 600 Handheld
Palm 600 touchscreen
My Palm 600 touchscreen stop working after i dropped it and now the screen when i turn it on the screen it blue and orange
Aug 08, 2007 | Palm Treo 600 Handheld
Palm Treo 600 Handheld Logo
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
