Question about Sony KDF-E50A10 50 in. LCD HDTV
The tv shuts shuts off by itself and wont come back on until next day, do you know what causes this
  • 608 Answers
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Posted on Dec 09, 2010
My magic chef microwave locked itself. it wont unlock when i hold down the cancel key. what do i try next?
PDF]microwave oven and keep it for future reference. - Home ...
www.homedepot.com/.../ef8a2fd1-648b-424f-81d1-37...The Home Depot... of insurance loss. Once again, thank you for purchasing a Magic Chef product. .....To Lock/Unlock Control: The microwave oven must be in for 3 seconds until
Oct 07, 2015 | Magic Chef Microwave Ovens
Sylvania LD320SSX turns off by itself.
your powersupply is dying in the set.. have it checked..
Apr 10, 2010 | Sylvania LD320SSX LCD TV
Tv runs for about 4 hours and shuts off.
the tube is going out better off getting a new one since the cost to repair it would not be worth it but if even tho it may work after doing all of that the reason it stay on is that the switching of the channels is doing something to the control board and allowing it not to short and turn off
Aug 28, 2009 | Philips Magnavox MT1905B 19" TV
Sony KDF-E50A10 50 in. HDTV stays on for 25 - 30 minutes then shuts off by itself power stand by light flashes green and turns back on in about 20 seconds by itself. can you help?
Hi, Lamp of TV getting weaker and requires replacement. This shut off by itself will increase day by day until you put new lamp in TV. Always Buy Sony original lamp and avoid aftermarket/ cheap lamp for TV safety.
Jun 09, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
My TV shuts itself down by itself
Poer supply is the cause of the shutdown and would need to be replaced. These cost around $150 bucks just in parts the labor you would need to find someone that knows just what there doing or you could wind up into the hundreds, Thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 25, 2009 | Mitsubishi VS-6055 60" Rear Projection...
My Kohler OHV engine stops after 5 minutes. I have replaced the spark plug, fuse, solenoid, fuel filter and oil filter. After it stops there is no spark until I check on it the next day. Seems like it...
Most engines such as this have a low or high oil level shut off. It sounds to me like you may have to much Oil and it is shutting itself off for safety reasons. When there is too much Oil it takes a long time for it to drain back into the oil pan. This may explain why there is no spark until the next day.
May 03, 2009 | Garden
Mitsubishi rear projection TV , Model VS-45603.In the last year it started to turn off by itself. It has no real pattern. It can turn off 2-3 times one day and none the next day. It is hooked up with...
What kind of cable are you using to connect it with (coax, HDMI, RCA (composite), component, s-video)?
This may be a grounding problem. Either the cable from the satellite dish is grounded to something with a little electricity running through it or you may have a hot ground in your electrical outlet. Or the cable may be on a different ground than your electrical outlet and by connecting the two it has created a slight electrical current. You can try using a plug adaptor to remove your receiver from the electrical outlet ground. These adaptors are meant for older homes and electrical outlets that do not have a third hole or ground plug. The outer metal part of all video connectors is the ground and this may be causing the tv to act strangely.
I hope this works.
Apr 24, 2009 | Televison & Video
Have a Mitsubishi vs 70601 shut off by itself one day and wont po
i would think it is going to be the main fuse, open the back of the tv, you will see where the power cord is connected to the board, there will be a glass fuse next to it, you will be able to see if it is bad,----make sure you unplug the tv befor you mess with it
Jan 09, 2009 | Mitsubishi VS-70601 70" Rear Projection...
JVC TV crisis.....HELP
yes... i actually work at verizon the tv is to old for fios because fios is so advanced we run off ot 720 to 1080 depending on areas. what kind of box is it? is it the hd box or stb>
Feb 13, 2008 | JVC AV-32230 32" TV
Sony KDF-E50A10 50 in. LCD HDTV Logo
53 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
