Question about Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k
Craftsmen air compressor #919.155730-motor runs,pump moves, but doesn't build pressure. how long does it take? could I not be waiting long enough?
    President:
  • Craftsman Master
  • 1,388 Answers
Your unit should fill within 5 min. Compressor may have worn cylinder or just leaking. Easy test. Spray soapy water on all connections/fittings including drain valve and regulator while compressor is running. Repair as needed. If no leaks, remove plug from outlet, remove cover and examing cylinder. Turn crank by hand till piston is all the way up into cylinder. Examing carefully the condition of the cylinder close to top. If the cylinder is scratched or worn then pressure is leaking between piston/cylinder and will not fill tank. Replace cylinder kit available at Sears, cost under $50. Good luck with your project.
Posted on Aug 07, 2010
Motor turns and pump pully does not. burning up belt.
Air Compressor Trouble-Shooting, Problems, The Causes ...
www.portlandcompressor.com/compressor/trouble-shooting.aspx
Provided below is a general list of common air compressor problems, and a few quick ... Loose pulley, flywheel, belt, belt guard, cooler, clamps or accessories. ... Piston rings installed up-side down. ... Receiver does not hold pressure when compressor is unloaded. ... Turn on power, check fuse, breaker, or motor overload.
Reasons Why an Air Compressor Will Not Build Pressure
fix-my-compressor.com/compressor-will-not-build-pressure/
An air compressor that will not build pressure runs on long past the point where it normally ... air compressor with at least one piston that moves up and down or side to side to pump air - cycles, .... I have an Ingersoll rand 7100 compressor 2stage 175 psi 120 gal tank ... The motor is a 2.5hp 3450 rpms with a 4 inch pulley.
Supercharge your Air Compressor for 20 bucks or less - Sawmill ...
www.sawmillcreek.org > ... > General Woodworking and Power Tools
Mar 16, 2006 - 15 posts - ‎8 authors
I have a 27 gallon belt driven Sanborn (Coleman) compressor and I have been ... I'mnot suggesting they won't compress air or give good service. .... Most any small oil-less compressor will serve a nailor, pump up the snow tires ... A two stagecompressor pumps 20 to 30% more CFM per motor HP thanks to ...
Jan 05, 2016 | Ingersoll Air Tools & Compressors
Wont build pressure past 60 psi
If you have oil-less type of compressor you may be leaking pressure past cylinder/piston ring or just air leak. Easy to check. Spray soapy water on all connections, first with pressure in tank and motor shut off, then once again with motor running/pumping. Repair as needed. If no leaks remove cover to motor and move piston to top of cylinder and examine condition. If you see scratches neer top of cylinder, then pressure is leaking past vinyl ring. If cylinder looks shiny and smooth and piston vinyl seal looks intact, suspect problem with reed valves or head gaskets. Parts are avilable at sears parts on the web. Good holidays expensive.
Dec 14, 2010 | Craftsman 1 Hp, 4 Gal. Air Compressor
I have a 5 gal, i hp craftsmen compressor, 3 years old, used once a year to blow down sprinkler system. Compressor ran up to 120 lbs upon turn on, would not cycle off. manually shut off unit and turned...
Oil free pumps do tend to blow the piston ring (not too expensive) available at searsparts.com. Remove covers to pump and manually turn crank until piston is at top and look at the condition of the cylinder neer top, If it looks scratched, order cylinder kit with piston ring. If it looks good and shiney, could be the valve plate in the head. There are reed valves that tend to break. Run pump however with covers removed and check with soapy water for air leaks and repair as needed (air leaks under the cover will prevent unit from filling). Good luck
Nov 13, 2010 | Craftsman 15 gal Air Compressor 3 hp UMC...
My craftsmen air compressor wont build pressure. How do i fix it?
If the unit will not build up pressure you need to remove the compressor head from the compressor and inspect both the intake and the exhaust reeds as well as the piston ting on the compressor.
Without the model number of the compressor this is about as far as I can help with.
Sep 30, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Will not build up pressure
worn out pump on the compressor, or leak in tank.
Jul 05, 2010 | Craftsman 1 Hp, 4 Gal. Air Compressor
Husky 202900 when i turn it on motor runs but it but will not bui
when i turn it on motor runs but it will not build up air pressure
Apr 13, 2010 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Have a husky 19 gal 1.5hp it kicks on when first start to work and when it builds up air and i use it and when it wants to kick back on it wont i have to wait till it cools down.
Is there an option for you to run this compressor on 220 volts vs 110 volts??? If so, you may want to convert it by following the re-wire instructions on the motor or wire access plate/instuction book. The reason your compressor won't fire up again after building pressure is the head pressure is to great at restart and 110 household current is not enough to give the power needed to turn the piston. You'll need to replace the plug and have someone run a 220 volt circuit once the conversion is completed.
Jan 18, 2010 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
My compressor doesn't build enough pessure.
SOUNDS LIKE THE VALVES IN YOUR HEAD ARE NOT CLOSING ALL THE WAY. THEY ARE MOST LIKELY REED VALVES, THIN STRIPS OF METAL THAT OPEN AND CLOSE WHEN THE PISTON MOVES. MAKE SURE THEY ARE CLOSING ALL THE WAY (NOT CARBONED UP). DID YOU REMOVE THE HEAD AND DID YOU PUT BACK LIKE YOU FOUND IT. NOT TURNED OR FLIPPED OVER.
Mar 18, 2009 | Craftsman Air Tools & Compressors
Husky comp on 1st start builds up 75 lbs and wont restart
Check the reset button on the motor to see if it tripped. The motor may be overheating. Some motors have an internal breaker and they have to cool off before they restart. Also check the pressure switch. Move the switch back and forth ( on and off ) and listen for a click. If it doesn't click with low to no air pressure then the switch is bad.
Dec 30, 2008 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Air compressor w/5hp motor
Assuming that the motor is factory matched to pump, it should be powerful enough to turn the pump. Most problems with motors are related to pressure switch and/or capacitor. The pressure switch could have burned contacts causing low amps to reach the motor. The capacitor should test at least 90% of rated value printed on capacitor. Some volt meters have capacitor check setting. Also this motor at 5 hp must draw lots of amps. The outlet should be rated at least 20 amps and plug the compressor directly into oulet without an extension cord. \
Secondary problem is the in-tank check valve. The check valve should hold in tank pressure without leaking back to the head of the pump. If check valve leaks, replace it with any brand of same thread size. enjoy
Oct 29, 2008 | Air Tools & Compressors
Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k Logo
346 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
