Question about Samsung RB2155SH Bottom Freezer Refrigerator
My Samsung is actually a RB215 LABP. The ice maker stopped working.
3 Suggested Answers
woodchuck789
  • 4070 Answers
SOURCE: our Samsung ice maker stopped working
Sound like the problem may be a gear broken or damaged in the module which appears to be replaceable in your model. If you can dissasemble it enough to inspect the gears you may can replace the part instead of the entire ice maker. It looks like the motor may be in part 18 on this diagram. http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=RS2630WW&productCategoryId=0165000&brandId=1482&modelName=SAMSUNG-REFRIGERATION&diagramPageId=00009&componentDescription=ICE%20MAKER&documentId=M0612092&backToLink=Return%20to%20Sub%20Components%20list
Posted on Sep 09, 2009
marka19
  • 1430 Answers
SOURCE: ice maker stopped working and fridge is hot on outside
This could be 2 separate problems or a control board issue. First I would check that the condenser fan is running, coils are cleaned. Here is a link to check the condenser fan http://appliancehelponline.com/referhotonsides.html If the fan checks out good more likely a control board failure.
Posted on Jun 07, 2010
Samsung rs257 ice maker not working. We already reset ice maker and checked water line to ice maker. We also used dryer to defrost bearing on ice maker. Still not working.
Hi!
The manual provides a number of reasons why the ice maker doesn't work:
Ice is not dispensed
Did you stop the ice making function?
Is there any ice in the ice storage unit?
Is the water line connected and the shut-off valve
open?
Is the freezer temperature too warm?
(Set the temperature lower)
Did you wait for 12 hours after installation of the
water supply line before making ice?
I'm adding a link to the manual:
http://manualsbrain.com/en/manuals/948215/?page=29
Jul 21, 2017 | Samsung Refrigerators
Samsung refrig, side by side, won't eject ice. How do I turn off the left hand light to quit ice?
How to Repair a Refrigerator Ice Maker ' HomeTips
www.hometips.com/repair-fix/freezer-ice-maker.html
If your ice maker doesn't make ice, check out these expert do-it-yourself ice maker repair ... W. Branner Side by side GE fridge, stopped dispensing ice both cubed and crushed. ... But now that it's cleared the motor won't run to dispense any ice (water .... Our Samsung French door ice maker is not working & is making noise.
Jan 01, 2016 | Samsung Refrigerators
Showing code 8E
This error code means the ice maker sensor is bad. On Samsung the sensor is part of the actual ice maker which you can find here.
Ice Maker For Samsung Refrigerator Model RF323TEDBSR
Sep 26, 2015 | Samsung RF323TEDBSR 31.6 cu. ft. French...
Ice maker 106 626635 spills water in the bucket after dumping the ice. What can I do?
Are the ice cubes getting small then its actual size.Sometimes ice cubes not get made full of its actual size.Can be issue with maker itself.
Replacement parts can be purchased at any of the following web sites:
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 24, 2012 | Kenmore Refrigerators
We have a Samsung RS2530BBP. The ice maker works ok... water stop coming out... What do I need to do to fix the problem?
My Samsung RS 2530BBP frige Ice maker stop tp make ice.
The water tray stays verticly after pushing the reset button and the water pours in the container instead in the tray. I purchased a new ice maker but it did the same. Any idea how to fix it
Aug 12, 2010 | Samsung RS2530BBP (25 cu ft) Side by Side...
Ice maker wont work, i have heard about a reset switch but where is it
The RB215 icemaker is a complex little thing....
There is a test switch on it....use the link, load the PDF and go to the section for the Icemaker...
You should be able to get a handle on what's going on.
You may need someone to help you reading the text and following directions.
http://www.ajmadison.com/ajmadison/itemdocs/DA68-01778A-EN.pdf
Mar 03, 2010 | Samsung RB215LASH
Our Samsung ice maker stopped working
Sep 09, 2009 | Samsung RS2630WW Side by Side Refrigerator
Ice maker not working
Cause could be the solenoid valve which controls water flow into the ice maker.
Could be bad solenoid, bad relay for solenoid, clogged solenoid valve, corroded electrical connections, etc.
More info? Let me know...
Charlie
Aug 14, 2009 | Refrigerators
Samsung fridge rb215 bottom freezer ice maker
On most samsung Refrigerator ice makers there will be a button on it to test the functionality of the ice maker. Its a small button covered with clear rubber. When you locate it hold that down for 10 to 15 seconds and if it is functional it should run through its paces. Is it the ice maker in the left fridge door , the freezer compartment, or the one inside the fridge to the left?
Jan 11, 2018 | Refrigerators
Loud periodic buzzing
Are you sure this noise is not just the ice maker trying to cycle without water? If it is not turned off it will dry cycle every 15 min or so.
Jan 18, 2008 | Samsung RB2155 Bottom Freezer Refrigerator
Samsung RB2155SH Bottom Freezer Refrigerator Logo
43 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
