Question about Zodiac Baracuda Zippy Pool Cleaner
My zodiac zippy will not move in the pool. Please help.
  • 640 Answers
Make sure that your pump is on and that your filter is clean and not clogged. You will also want to check your water flow with the Star Control system. This is most likely what is causing lack of movement with these types of pool cleaners. If you get a blue or black reading, your flow is too low and you need to adjust it to get it to yellow. Increase the flow by turning the Star Control Assembly clockwise until the black indicator line aligns with the yellow area on the indicator gauge.
Posted on May 11, 2011
My pool sweep stays in the deep end and will not move to the shallow end of the pool
make sure you have proper flow rate and try shortening the length of the vac hose. this will change the pattern the machine uses
Jun 17, 2014 | Zodiac Baracuda Zippy Pool Cleaner
Barracuda has plenty of suction but hardly moves around the pool, goes very slowly
You likely just need a new pad on the head. When they ware down they allow the head to get closer to the surface that it's cleaning, but the additional suction makes it difficult for the head to move.
I hope this helps you!
Jan 29, 2011 | Zodiac Baracuda Zippy Pool Cleaner
My barracuda stays in the deep end and will not move to the shallow end of the pool
You probably just need to redirect the returns in the pool. If they are angled right (or wrong) they will get a current moving in the pool and cause the cleaner to go to one spot and keep it in just that area of the pool.
Oct 30, 2010 | Zodiac Baracuda Zippy Pool Cleaner
Will not travel into shallow end
The first problem that you have is that you indicated that you have a Zippy pool cleaner by Zodiac. This cleaner is designed for above ground, flat bottomed pools. If you are using it for a dished above ground or in ground pool with a shallow end, the cleaner and the hose itself are not compatible with your pool. That is why it is not going to the shallow end of your pool. I would consider looking for pool cleaners that are designed for in ground pools if you want it to cleaner properly.
Aug 04, 2010 | Zodiac Baracuda Zippy Pool Cleaner
Zodiac Baracuda Zippy Pool Cleaner only clean one pool side because strong jet don't let move to other side
If you don't have directonal eyeballs on your jet's you can get a dirveter for the jet that will push the water down the wall rather than out into the pool. Get these at your local pool store. Baracuda and Kreepy Krawlie both make them.
Jul 05, 2010 | Zodiac Baracuda Zippy Pool Cleaner
The barracuda just returns to the deep end of the pool and stays there, how can I get the cuda to sweep the whole pool?
The Barracuda Zippy is an Above Ground pool cleaner and is not designed for a pool that does not have a flat bottom. They are generally not capable of climbing slopes, walls, etc.
Apr 19, 2010 | Zodiac Baracuda Zippy Pool Cleaner
When I turn my Zippy on it is going so hard that it goes to the top of my pool. Help please
Check your manual. There should be an adjustment that regulates the flow to the cleaner. I believe that it is called a "star control" but I'm not sure. As a last recourse, you can call Technical Support at 1-(800)822-7933. Good luck!
Mar 02, 2010 | Zodiac Baracuda Zippy Pool Cleaner
Zodiac Baracuda Zippy Pool Cleaner hose tear
I haven't seen any bulletins on the Zippy hoses. You might adjust the flow to the cleaner. You can find the Manual for the zippy cleaner on this page beneith the diagram. It shows how the star control works. You can also contact the Mfg Technical Support at Phone: 800-822-7933 They might be able to warranty a hose or two for you.
Nov 03, 2009 | Zodiac Baracuda Zippy Pool Cleaner
Zodiac Baracuda Zippy Pool Cleaner Logo
155 people viewed this question
Top Zodiac Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Jay Finke
Jay Finke
Are you a Zodiac Pool and Spa Expert? Answer questions, earn points and help others
