Question about Konica Minolta bizhub 350 All-In-One Laser Printer
ERROR MESSAGE C2557 - WHATS THAT? - Konica Minolta bizhub 350 All-In-One Laser Printer
  • 1,110 Answers
C2557 is the code for ATDC sensor failure. ATDC stands for Automatic Toner Density Control. This code is usually caused by either a sensor failure or more commonly a mismatch in what the machine should have for toner density level and what the sensor is seeing. I have even seen this code pop up if the machne is run low on toner. Bad news is it is going to require service. This may require a drum and developer change to resolve as well. So you will need to call your local service company/guy and get it repaired.
Good Luck and Thank You for using Fixya.
wheatlandservices
Posted on Aug 06, 2010
Testimonial: "thank you very much. the problem got fixed."
What is error c2557
Whatever it is, you need to call a technician to find out.
Mar 14, 2016 | Konica Minolta bizhub Office Equipment &...
Ican't run F8 because of error C2557
Error c2557 means ATDC sensor abnormality.Most probably the developer is very low or weak in such condition.Check the developer.You can also increase ATDC GAIN in technical representative mode in order to get rid of this problem.
Also check the PC life/consumables life in "Counter"---"Special Parts life counter".Check if the life of PC Drum is 100% or near to 100 ten clear its value by pressing "C" button.Clear all counters to zero value.Now restart the machine and run F8.It will run smoothly.If you are replacing new developer then there would be no problem with it.
Jun 02, 2012 | Konica Minolta bizhub 350 All-In-One Laser...
We keep getting an error message c2557 for the bizhub 350. what does this mean? we have a tech out and he cant help us
this code means that the time has come to replace its parts, i mean some parts of imaging unit.its the code of a sensor.
May 26, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
The massege is code c2557 that message what's mean
c2557 means your machine is having problem with its ATDC SENSOR.
Oct 18, 2009 | Konica Minolta bizhub 180 All-In-One...
Bizhub 350 error code c2557, how can i fix this?
This code happens if you replace drum without replacing developer. Both must be replaced at same time.
Sep 30, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Error c2557 konica minolta 250/NEC IT2530
Reset it, start it with the right door open, go to service mode, clear the counters for drum and developer and go to functions menu. Close the right door and start immediately the F8 function. It should work.
Jul 31, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Bizhub 200 blank pages no error messages
problem in hv unit ( ch corona ) in drum unit replace if necessary
Jul 10, 2009 | Minolta bizhub 200 Copier
PAPER JAM ERROR MESSAGE
your sensor flag in the back is broken or missing
Jun 05, 2008 | Lexmark E342n Laser Printer
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
1,596 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
