Question about Hannspree Televison & Video
Hey, Just got teli and am not getting cable menu. Some shows appear then go away also. stations do not appear to be usual stations. HELP! :) Hannspree 25" HDTV Oh yeah! It isn't plugged into cable box.
  • 11,896 Answers
Check your tv settings. Go to menu, then find the tuner option.
Make sure your tv is set to CATV if you have cable or dish or the sort.
If you are just using regular tv, then make sure it is set to AIR
After you have those settings corrected, next in the menu, find the "autoprogram" option and select it. Let it run completely through. It will add all available channels into your tv.
Posted on Aug 06, 2010
  • jfunliving Aug 06, 2010
    I've done all that. Still no success. Unable to tell what channel and when I change stations it takes forever for it to decide to show a picture or not.
  • Nate Stansfield
    Nate Stansfield Aug 06, 2010
    Sounds like a faulty tuner card that will need to be replaced.
No instructions included in quick start guide on how to connect to wi-fi
I'm sorry you're having difficulties connecting your telyHD to wifi! Step-by-step instructions can be found here. If you still need help, please don't hesitate to contact us at support@tely.com.
Kind regards,
Tely Labs Support
Oct 31, 2012 | Tely Labs | TelyHD Skype Camera
My new VIZIO is connected to cable through a Comcast Xfinity cable box. I have not been able to get a picture for a large number of stations which I have aways gotten before. The name for the show on the...
If your tv set is good and you cannot get Comcast to help then you have to get rid of them. What are you paying them for? Try another set hooked up to the service just to make sure that it is on them to avoid any embarrassment.
Sep 15, 2017 | Vizio XVT373SV 37 in HDTVReady LCD TV
How to get from standard TV to Cable TV?
Should use remote to bring up the menu. Go to channel search and it will ask you if for ant or cable. This is where you will select for antenna or cable.
Feb 15, 2009 | Televison & Video
Not receiving my local cable stations
You need to make sure the TV is set for "cable" tuning and not "standard" or "air." (If you are getting only local off-air channels and no cable stations at all, be sure you have a good cable and connection to the set. Normally, even if the TV is set for "air" you will get the low-number cable channels 2-13.) This is usually a selection through the TV's set-up menu. With a universal remote, it may be difficult or even impossible to get to all the menu entries. Most replacement remotes don't support all the original remote functions. Try with yours and good luck. Once you get the TV set to the proper tuning, you should have all your cable channels.
Jan 03, 2009 | Durabrand BH1304D 13" TV
The tv will not let me access all channels.
Turn off the text box with the TV/CAP/TEXT button. Go into the menu and change from TV to CABLE. Run the AUTO CH MEMORY.
Dec 11, 2008 | Durabrand DU1901 TV
Tv won't work
I downloaded this off of Wikipedia. You are not the only person having the problem with the switch to digital television. The complaints are nationwide. the old TV Guide Plus has gone away for many viewers and soon for all viewers as the transition to DTV gets nearer. If you are using an antenna be sure to get the digital converter. They are practically free with a government sponsored coupon.
Digital television
The new service, launched in the United States in 2006, is entirely digital, using the ATSC digital television standard. While this will significantly improve the service, older systems will no longer be able to download listings once analog shutdown is done in early 2009.
It should be noted that the Program and System Information Protocol (PSIP) within the ATSC standard already allows for each station to send out its own EPG information, and in the U.S. the FCC in fact requires stations to do so for OTA (but not cable, unless they are rebroadcasting an OTA station that provides the PSIP data). However, actual implementation is rather spotty, and usually very minimal -- stations often don't have full descriptions (or even correct information) on the current show, much less the next 3 hours required of them, or the 16 days worth of guide information that can be transmitted. Additionally, ATSC tuners are not required to even show the EPG, only the very limited information for the current show on the current channel.
While the TV Guide service also requires software in the TV or other device, and licensing fees or royalties to be paid to Gemstar TV Guide, it also offers a more complete solution for broadcast television, more like digital satellite or digital cable.
Nov 28, 2008 | RCA 20F420T 20" TV
Operating my ipod docking station
Absolutely!
Keyword(Read the instruction and follow it step-by-step.) Well,if you do,you wouldn't be asking for help,cause you want a 50+ pages Denon manual instruction to be concise to few paragraphs so you could move on with your life-:o)
Okay.only this time!
Denon ipod docking station comes with a power plug and a set of cable which you need to connect behind the Denon AVR-2807 receiver which is under an INPUT LABEL for IPOD only(not going to give it away,you will find it!)
Now,of course you could use HDMI......but,the quickest way to view your video(on screen menu) will be using a composite(RCA) video cable to connect from the Video output(yellow color) from the receiver to the TV composite video input.Turn on your IPOD,and you are ready to see the on screen manual.
Hey,this is just a lazy way to start you off if tomorrow night you have a date;otherwise,set it up properly by using the instruction!
Cheers,
solutiondoct
Oct 18, 2008 | Denon AVR-2807 Receiver
Auto Tuning Channels on LC20B2MA Aquos TV
 Automatically tunes in and preset
receivable TV stations.
Make sure the antenna cable is
properly connected.
1 Press MENU (PRESET-1) on the
upper part of the LCD TV set for
more than two seconds. The
AUTO mode screen appears.
2 Press VOL (–)/(+) (PRESET-2)
on the upper part of the LCD TV
set.
All the TV stations in your area
that can be received by the LCD
TV set are automatically preset.
3 The screen shows whatever is on
channel 1 when full auto channel
preset is finished.
Aug 07, 2008 | Sharp Aquos LC-20B2U 20 in. LCD Television
Can't get cable stations
you have to go into the menu and set for cable then scan for active stations.
Mar 15, 2008 | Televison & Video
Magnavox MPTV68A "Magnavox" emblem is displayed and won't disappear
I don't know the exact TV, but Magnavox usually have an item or two items in the menu system where the "Magnavox" and also the "blue screen of death" can be disabled. Look in your manual.
I'd suggest the reason it appears is temporary loss of signal from the antenna, set top box, cable system or whatever it is you receive your TV programming via. I don't have an answer as to why it occurs watching video, but turning off the logo and blue screen should help. If it still occurs, it's time for professional intervention!
Jan 02, 2008 | Philips Magnavox 27MS343S 27" TV
Televison & Video Logo
Top Hannspree Televison & Video Experts
Are you a Hannspree Televison and Video Expert? Answer questions, earn points and help others
