Question about Insignia NS-LCD22-09 LCD HDTV
My insignia ns- lcd22 tv will not turn on when I press the power button the light goes on and stays on but the screen never turns on? How do I fix this? Can I fix this?
  • 11,361 Answers
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there are some troubleshoot you will have to do to find out the causes of the problem you are having.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx
Posted on Aug 06, 2010
I have an Insignia tv. I can see everything on the screen, but it flickers rapidly. Can someone help with how to fix?
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Nov 10, 2015 | Insignia NS-LCD22-09 LCD HDTV
Insignia ns-lcd22 speakers not working
To replace the speakers, you have to open its back cover. If you wish to get some details, check the site linked here. http://electronicshelponline.blogspot.com/Pull up older posts. Disassemble procedure to many popular brand TVs are given with illustrations.
Dec 31, 2013 | Insignia NS-LCD22-09 LCD HDTV
Tv wont turn on
does the light stay or blinking and how about the screen display totally black or a white screen. you can see in a dark room if their is a white screen. if totally black screen then with sound the cause is could be bad inverter board or screen back light. if a white screen it was the t-con board not working good.
Oct 04, 2012 | Insignia NS-L32Q-10A 32 in. HD-Ready LCD...
Ihave a insignia ns-lcd47hd-09 tv. when i press the power button the light turns blue but no picture comes on only black screen.
I think your insignia is set for SHOP mode instead of HOME mode. I changed mine to HOME and it's working fine now. Press your menu button and then scroll down to setup. You're looking for Plug and PLay which should be the very first choice. If it's greyed out as mine was you'll have to change your imput from HDMI to TV in order to get to the P&P. Once you're in the Plug and Play your first choice is language. The second should be SHOP or HOME. Make sure to select HOME. You can skip scanning for channels. This fixed my problem with the blue light. The store uses SHOP so if someone plays around and changes something, all they have to do is shut off the TV and turn it back on. Please let me know if this works.
Oct 03, 2011 | Insignia NS-LCD47HD-09 47 in. LCD TV
Lightning struck now my tv won't work.
No,Ur power supply board have a big jolt massive power search.It dead,change the power supply board,will solved this problems.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Apr 08, 2010 | Insignia NS-LCD22-09 LCD HDTV
Insignia TV
Ok, I had the exact same problem last summer, and Kevellen told me of a problem that Insignia tv's have: the circuit that controls whether the tv is off or on is messed up, and it can be fixed, but its not cheap.
http://www.fixya.com/support/t924975-wierdness_tv
Anyway, if the t.v. is still under warranty, I would say return it to the store and see if you cant get a new one, and from what I researched online after this incident, I will not buy an Insignia aver again.
hope this helps,
-Steve
Aug 17, 2008 | Insignia NS- 27" TV27 TV
Padlock, blue screen
Somehow in handling the remote control I pushed a button or combination of buttons and now have a blue screen with a lock symbol in red in the top left hand corner. I've tried turning the tv off, and unplugging it, as well as a combination of buttons on the remote, but it still is there.
What do I need to do to remove the lock?
Aug 02, 2008 | Insignia NS- 27" TV27 TV
Insignia NS-LCD22-09 LCD HDTV Logo
307 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
