Question about Whirlpool GEW9250 Electric Dryer
How do i remove the control panel cover to see why the control lights wont come on? the inside light works and the breakers are not thrown so i checked the door switch and it clicks when i push it so i am assuming that the control panel is the problem. would it help to unplug it for a while to see if it will reset itself?
  • 347 Answers
UNPLUG UNIT remove three screws in back of dryer holding top, from in front of machine slide top to back of unit to remove, now you will see secrews securing panel to unit also two secrews come from inside unit to the front after these 4 screws lift user innerface panel straight up..
Now after that ck for connectors loose or unpluged hopefully, if not your going to need the tech sheet and a elec . meter to test system
Posted on Aug 06, 2010
FGMV205K cover removal
Good Afternoon Friend,
I understand that you want to know how to remove the cover on your Frigidaire microwave, model# FGMV205K. There are two different covers that you are able to remove for access to two different light bulbs.
If you are trying to change the Microwave Oven Light for inside your microwave:
    1)To replace light bulb, first disconnect power to your microwave oven at the circuit breaker panel or by unplugging it.
    2)Remove the louver by removing the three Hood Louver Screws.
    3)Push in the upper tabs and pull the louver away from your appliance.
    4)Remove the light bulb and replace with a new 20 watt light bulb. DO NOT USE BULB LARGER THAN 20 WATTS.
    5)Close the Oven Light Cover by carefully pushing into place. Push the louver back into place (engaging both the bottom and top tabs) and change to hood Louver Screws.
    If you are trying to change the light bulbs underneath your Microwave:
      1)To replace light bulbs, first disconnect power to your microwave oven at the circuit breaker panel or by unplugging it.
      2)To open Light Cover, remove the screw on the light cover.
      3)Replace the light bulbs with new 20 watt light bulbs. DO NOT USE BULBS LARGER THAN 20 WATTS.
      4)Close the Light Cover and secure with screw removed at step 2.
      If further troubleshooting is needed, I ask that you please let me know the error codes displayed on your appliance. Hope this is helpful.
      -Best Regards-
      WP
Jun 07, 2014 | Frigidaire Gallery FGMV205K 2.0 cu. ft....
Control Panel Doesnt Light. Breaker is good. Interior bottom light works ?
possible bad connection to the cord, inside the dryer.. unplug it, remove the rear panel, and do a continuity check with a meter.
Mar 11, 2014 | Maytag Neptune MCE8000AY Electric Dryer
665.68601890 Acts as though it is not receiving power but breaker is not thrown. Is there an internal reset. Nothing responds - no lights, fan or microwave. Panel is black and non responsive
ther is on most microwaves a fuse inside usually located behind display panel located in a fuse block or will be on the control board itself.. normally a 20 amp fuse...try that first if not then make sure you have power to control and if so and no display most likely the display control board...
may luck out and be just the fuse though....good luck
Jan 08, 2011 | Kenmore Microwave Ovens
Clock on control panel works, control panel counts down when start is pushed, light inside doesn't work nor fan or light under unit. I replaced fuse but wasn't the problem. Any ideas? I first noticed...
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
Dec 02, 2010 | Whirlpool MH1150XM Convection/Microwave...
Whirlpool oven: oven bulb popped and oven wont work. I already replaced the bulb. Does it have a reset switch? The stove top still works fine. The gas wont come on in the oven so that I could manually...
Sounds like you have an open cicuit in the oven power. The control for the gas uses the impedance of the hot surface igniter. Check for a circuit breaker. The wiring diagram should be inside the control panel cover.
Jul 07, 2009 | Kitchen Ranges
Stooped Working After Installing Inside Microwave Light
Either a fuse blew or the control board is damaged.
A fuse can be replaced pretty easily, but if it's the circuit board, we repair those for $39.95 for customers nationwide. This is a common problem.
Be sure the oven is unplugged. Remove the vent grille again. You will now see a screw at the top of the control panel frame.
Remove that screw, then gently lift up & out and the control panel can be eased away from the chassis so you can see inside to find the fuse.
You can usually find helpful exploded view diagrams by entering your full model number here: http://tinyurl.com/gv383
There may also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
If you think the problem is on the control panel, please feel free to contact me directly.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
May 09, 2008 | KitchenAid KHMS147 Microwave Oven
Maytag Dishwash - No lights will light up on the control panel
first off ck the breakers ofr tripped breaker, next remove lower acess panel and on right side is main wire connection remove box cover and make sure connection is good. ck fro 110 v there if not you got an electrical issue. next would be to check the door switch assy's.
Mar 08, 2008 | Dishwashers
Whirlpool GEW9250 Electric Dryer Logo
106 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
