Question about Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
My audio does not work when watching cable. The audio works in the other modes (games, etc)
  • Sony Master
  • 1,527 Answers
Hello make sure the scart lead is fixed tightly. if this still don't work try a new scart lead
regards
shaun
Posted on Aug 06, 2010
My green light comes on but no picture
Sounds like tv is on wrong input. Be sure HDMI wire or cable input is connected to tv. Look at which input it is on. ( like HDMI 1. Or cable etc. take tv remote (with cable box on ) press input / video button and arrow down to different inputs ( slowly ) until the right input is detected or simply go to the right input you noticed the cable was connected to. Different inputs are there for different sources of connections like DVD. Games. Etc. each work like its own tv channel. Good luck.most times this happens when you are watching tv and press the TV. channel button which will take you to a different tv mode
Aug 10, 2014 | Sanyo DP42746 42 in. Plasma Television
Pc greyed out samsung
they may not be supported in the DVD you are currently playing. Try cycling through the differedt modes. STEREO, MOVIES, GAMES ETC
Mar 12, 2014 | Audio Players & Recorders
How to hook at&t uverse cable box
If set works with games etc via rear audio/video jacks do the same with cable----get a cable box with audio/video etc outputs on it and go from them to ones on the rear of set----no coax connection needed and a better picture.
May 19, 2012 | Toshiba 57h83 57-inch Hdtv-ready...
No surround sound when watching tv or other programs also when you turn the sound down the volume numbers go up.
Mine used to work but I recently moved and think I connected everything the same way, but I'm having the same problem you are now and I'm just curious if you ever solved the issue? For whatever reason, I'm simply not seeing the Dolby Pro Logic, PL Movie, etc. modes. Just the standard Stereo, Arena, Theater, etc. modes. I'm connected to the receiver's optical audio inputs both directly from my cable box and from the TV itself, so I feel like I must just be overlooking something simple.
As for the numbers going up, it's not actually a problem... It's just something about the way DB (decibels) work I think.
Jan 09, 2011 | Kenwood VR-507 Receiver
Can;t play back surround speaker while watching tv programs.
Nov 27, 2010 | Kenwood VR-507 Receiver
Hi, my RCA CRC311 BT turns on my Sharp television, changes the channels, etc, but it won't switch to video mode, even when I hit input. It is an old TV, but I used it to watch videos, dvds and play games...
Unfortunately you will not be able to switch input.
I also have a Sharp, I have tried 5 different universal remotes. None will switch input. I guess that function is not provided properly.
Sep 18, 2010 | RCA RCR311B Remote Control
Game sound doesn't work
Hello..
What you are experiencing is as a result of bad audio connection.
Please Check the mute function on your TV or audio system if there is no sound
Check the audio settings of your device to make sure it "sees" the PS3. Also make sure you are using the correct audio cables and they are properly connected.
Make sure the input mode on your TV is compatible with the connectors used by the PS3
Also check the audio settings of the game you are playing..
Jul 03, 2010 | Sony Playstation 3 (PS3) Console
Can't watch dvd
You need the original remote controller to be able to switch input modes.Universal ones don't work. If you don't have the original remote and can't find it ever then the only way to reach your tv is through coaxial antenna port. So you can buy an rf modulator ( very cheap) and connect your red yellow and white cables (rca cables from a dvd, game console etc) to the modulator then connect the modulator to your antenna with a coax cable. This worked for me. It placed the connection to channel 4 and other channels are still working,
You can buy the RF Modulator from: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=180299245670
Oct 11, 2008 | Symphonic ST420FF 20" TV
Lost Remote
the sony rm-v310 universal remote solved my problem. its about 15 bucks and worked on my symphonic 20" tv. bestbuy should have one.
Dec 15, 2007 | Symphonic ST419E TV
Game video input enabling
Dear krismedia
You should first confirm that Audio/Video output cable from the hifi is connected to the TV , then you should connect the game console to the input section in ur hifi system. And finally see if the TV is in AV mode and also see if the HIFI is detecting in the input mode.
Dec 12, 2007 | Sony MHC-RV777D 220 Volt Hi-Fi Music...
Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
24 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
