Question about Ariens Lawn Mower Universal Solenoid Starter Replaces ARIENS 03551000
The deck will not engage,the lawn mower its self runs good but the blades wount turn. I tried bypassing the pto but that don't work eather. any thing else I could try.Dont have the money to send it to a shop.and any info would be helpfull. Thank you so much.Bobbie Powell
panilling9
  • 284 Answers
SOURCE: PTO does not engage
if your belt was tight when you finished installing it and all the pulleys that it went around are free turning by hand and lining up reasonably well you should be ok.
to the clutch
are you good with a volt meter 12volts dc?
Find your connector close to the clutch
unhook it from the clutch
take your volt meter and engage your red knob (Have the key on and parking brake applied)check your voltage to the connector
Do you have 12volts dc?if so your clutch should work if not you need to trace the wire back to the red knob
check all of your fuses check all of your safety switches.
Or have a 12 volt source (a battery )and hook it briefly to the connector you found directly to the clutch connector pos. and neg. from your battery you should hear an audible CLICK if so your clutch is good if not you are losing 12 volts back toward the red knob
this is the best way to check the clutch while it is still on the machine.
if its the bad clutch get your wallet out they are expensive.
to remove it unlosen center bolt on the crankshaft
remove or move belt guards out of the way and whole assembly should slide right off, note any shims and spacers that may come down with it and their locations
put back the same way it came off and tighten center bolt to 55 ft.lbs.
goodluck
Posted on May 26, 2009
  • 376 Answers
SOURCE: deck belt diagram
Go to ... http://www.partstree.com/parts/ Then click on Cub Cadet, enter the model number on the left that is under the seat and all the different diagrams are there. Click on Mower Deck.
Posted on Jun 29, 2009
SOURCE: I just installed mulch kit on my Ariens 34
i'm wanting to install a mulch kit too but it seems diffecult. hoew do you access under the mowing deck to install everything?
Posted on Sep 14, 2009
rwvanlue
  • 486 Answers
SOURCE: not sure, but i think the electronic clutch is not
The electric clutch is to power the blades/mower deck. There is a belt that drives the hydrostatic pumps to power the wheels. Make sure the Parking brake is OFF. Could be a belt, spring, idler pulley.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Posted on Nov 19, 2009
  • 15 Answers
SOURCE: how much does a pto cost, is it easy to replace or hard
The electric clutch is approx $100 to $150. It is easy to replace. Blades are inexpensive.
Posted on Apr 19, 2010
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ...
www.shopyourway.com > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
https://www.ifixit.com/.../Why+does+my+engine+die+when+the+bl...
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real ...off I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Dec 29, 2015 | Garden
Troy Bilt 33" walk behind mower blades won't turn on.
Troy-Bilt Lawn Mower Blades Won't Engage - Model ...
www.repairclinic.com/...Mower/...-/Troy-Bilt-Lawn-mower-blades-won-t...
Most Frequent Causes for Lawn mower blades won't engage. See All Lawn Mower Parts for model 13AP60TP766. Cause 1 PTO Clutch. If the blades don't rotate the electric PTO clutch might not be engaging. ... Lawn mower wheels don't turn ...
Nov 08, 2015 | Troy Garden
Cluch on mower doesn't turn blades when pto switch is turned on what do I look for
Craftsman Mower deck (clutch) Won't engage - GardenWeb
Jul 1, 2006 - I can push in the PTO switch to disengage the clutch and blades and the tractor starts fine and runs. But as ... If it doesn't lock up, look further into the deck...... Hi I hope somebody can help , I have a craftsman zero turn mower. PTO switch bypass????
Sep 4, 2010
Craftsman Lawn Mower Dies after a few seconds
Jan 31, 2010
Sep 19, 2008
Apr 6, 2008
Sep 25, 2015 | Cub Cadet Garden
When running the mower, it shuts off immediately when trying to engage blades(pto)
Hi Digger:
I've two possibles come to mind for you to check.
1) Engine OFF - Make sure that all of the blades and pulleys can turn freely.
2) Engine OFF - Double check belt routing. Move engage lever ON/Off and look at what movement happens. It may be that the belt is on the wrong side af a mounting flange and binds when engaged.
Cheerfuls.
Sep 18, 2015 | Garden
How to troubleshoot pto will bog down engine when you try to engage pto
when was air filter and fuel filter changed? are all pulleys turning free? spark plugs good? if everything seems good is motor wore out?
Sep 13, 2014 | Garden
Zero force 50 Cub Cadet runs fine , but when the mower deck switch is pulled , blades do not turn, does not engage
This would be one of a few different things, first check to make sure the belt is on properly and hasnt came off any pulleys, next check the clutch relay and fuse, next check the pto switch, and if all those check out, check the clutch for engagement, if it tries to engage with pto switch, then it may just need adjusted, if it doesn't try to engage, the clutch will need replaced, but check the other possible causes first.
Oct 14, 2013 | Cub Cadet Street Sign- tractor lawn riding...
Engage the blades and then drop the deckand the engine dies
Could be in safety circuit. or could be excessive load on the motor with deck running. Check all safetys, like seat switch, clutch switch, pto switch. You didn't indicate what type of tractor you have,
Jun 30, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
MY TRACTOR RUNS FINE& STOPS LIKE IT SHOULD. THE BLADES DO NOT TURN WITH THE PTO SWITCH ENGAGED
if this is a newer mower then the problem is usually a safty switch is not being completed and this is stopping the blades from turning on, most mowers have a switch under the seat that has to be shorted out in order for the pto to work, this can be checked by connecting the two wires going to the switch together, and seeing if this solves the problem. Does it sound like the pto is trying to turn on if this is the case then you might find you have a siezed up bearing that is stopping the pto from engaging but my guess is a safty switch is malfunctioning and causing the pto tp not turn on, Hope This Helps Don
Nov 10, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Cub cadet Z Force 48 inch zero turn blades won't engage
I hope this will help you...under the side panels on each side of the mower, there are "reverse lockout safety switches", they are supposed to stop the blades when both handles are pulled back. If one or both of the switches are out, the deck will not engage. Also, under the right side panel (when sitting on seat) there should be 3 relay switches, the one closest to the motor controls the PTO., if this is out, the PTO will not engage.
Jun 25, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Pto engages but the tractor shuts off
check the safty swith under seat if its bad it won't allow you to turn pto on for deck run a jumper wire in the plug if it works while you know its the safty switch
Jun 05, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Ariens Lawn Mower Universal Solenoid Starter Replaces ARIENS 03551000 Logo
118 people viewed this question
Top Ariens Garden Experts
Phil Walker
Phil Walker
Matt Olenzek
Matt Olenzek
enb54
Level 1 Expert
Are you an Ariens Garden Expert? Answer questions, earn points and help others
