Question about Biozone Water Filters for Counter Top: Water Filter for Counter Top Air Purifier
GTS22WCPBRWW where is the water filter - Biozone Water Filters for Counter Top: Water Filter for Counter Top Air Purifier
    Problem Solver:
  • 19 Answers
Below is a model diagram page for this part number:
http://lookup.partadvantage.com/lookup/ge/75754/00113209.i07
Posted on Aug 27, 2010
Problems installing water filtration replacement filter GE gxulqr
After you shut the water off, unscrew the canister, remove old filter and check it against new filter. (They should be the same) check fo arrows (if there are any point in upward position) insert and screw canister back on, fasten securely, turn water back on.
Jun 27, 2014 | GE SmartWater GXULQR Replacement Water...
Water filter
Check to see if you turned on the water to allow water to flow again if thats not it check to see if you put the fillter in the correct way you may have put in upside down. Good luck
Apr 11, 2014 | Manitowoc SY-1204A/B570 Air Cooled 1,205...
There are 2 holes on underside of filter housing & when turn on filter water , out both holes, why I hate running it as you don't know if you are getting filtered water from both holes.Help
The main problems I'm seeing on these posts for this filter are design and operater issues. 1. I never run hot water through the unit in filter mode. 2. I never run cold water through the filter turned on high (pressure issues arise), it doesn't filter the water any faster. You just want enough flow to run through the filter. 3. The steel sleeve was a good solution (again pressure) but came up alittle short (ie my epoxy fix). 4. The light is powered by a chip batterey that is unreplaceable and may be bad. Try reinstalling the cartridge. I personally pay no attention to the lights other than a clue. I change my filter when the taste changes or there becomes a flow issue. 5.There are filter screens prior the filter that can become clogged if you live in a poor water area. 6. The filtered water only comes out of the spigot and no other leaks (something loose or pressure issue).
Sep 30, 2013 | PUR (FM-9500) Air Purifier
Chemcial taste in water after changing water filter
Well this never happens with me but surely you might get some unusual result.
Chlorinated Solvents Exporters
Sep 12, 2012 | Whirlpool Gold GSS26C4XXB 26.4 cu. ft....
Do you add water
Air cleaners do not use water. I have never heard of a "water" air filter. There is a device which is a humidifier, and it has a tank for water. If you put water in your air filter, it will be ruined. alfiefinnell@gmail.com
Jan 13, 2011 | Duracraft DA5010 Air Purifier
Red led light on constantly
electronic circuit needs replacement
Feb 01, 2009 | PUR (FM-9500) Air Purifier
Can't remove the filter from my Pur Flavor Options faucet mount water filter
When mine gets stuck I stick the handle of a fork or spoon into the hole where the water comes out and use that to unscrew it. Works like a charm every time.
Aug 04, 2008 | PUR (FM-9500) Air Purifier
Water filter
electronic circuit needs repair
Jun 01, 2008 | PUR (FM-9500) Air Purifier
Water Filter Leaks
Since you weren't very specific where it leaks or when it started (like after a filter change) it could be tough to troubleshoot this leak.
If it is leaking at the faucet connection try tightening up where it screws onto the faucet. Depending on your strength (or lack of) you may need to use pliers to get a tight connection. Don't go crazy tight or it will crack the plastic fitting. If it still leaks remove the unit from the faucet and check the rubber washer inside where it screws onto the faucet. Make sure it's still there and is centered inside the cup and seated properly. Then reattach the unit to the faucet and tighten it well.
If it's leaking from the main body try removing the filter and reinstalling it making sure you have seated the filter properly and screwed on the cover correctly, and all the way. When it is tight the water outlet will be exactly at the bottom of the unit. Sometimes it's tricky getting it tight enough especially with wet hands.
Finally, if the leak is coming from the filter on/off selector this could be tough to fix. I would try firmly pushing and pulling the selector knob in and out several times while in both the on and off positions. This may re-seat the leaking seal. I wouldn't be too hopeful about this fix though. You may need to replace the unit if this part is leaking.
Nov 18, 2007 | PUR (FM-9500) Air Purifier
Air Purifiers Logo
117 people viewed this question
Top Biozone Air Purifiers Experts
Marvin
Marvin
Michael Youngman
Michael Youngman
Are you a Biozone Air Purifier Expert? Answer questions, earn points and help others
