My washer has a bad smell what do i do - Washing Machines
    President:
  • 1,273 Answers
My answer will be generic, as the type of washer isn't defined here. Front loaders generally smell worse than top loaders. There are cleaners that can be tried, and the work "pretty well" for a time, but may not actually solve your problem. Look at your door seals and bellows where the washer tub mates to the door. Things tend to grow there, and can be readily removed with a good disinfectant wipe-down. The washer will also benefit from leaving the door open when the washer is not being used. This allows the surfaces that trap water (and grow the material that makes the odors) to dry out. Whenever I wipe down the seals and bellows, I run an empty load immediately thereafter with bleach in the soap dispenser, bleach in the softener dispenser, and a cup of bleach in the tub too, for good measure. I run the washer on a "sanitary" cycle (with the hottest water for the wash and rinses available), followed by another wash cycle to flush the machine out. I then leave the door open. There are more invasive techniques that yiels somewhat better results, but the method described above is usually mure than sufficient to keep the washer smellin' sweet! Try it, and if we need to go deeper, please post back. If you do re-post, please provide a bit more info....brand of washer, type (top/side loader?), and we'll give it another go.
Best regards,
--W/D--
Posted on Aug 06, 2010
Washer smells bad - musty
smell are normally due to 3 culprits
low temp wash , liquid soap , moisture
affresh washer cleaner may be worth a try
video
May 07, 2010 | LG WM0642H Front Load
Inside of washer smells bad!!
Your smell is inside the washer under the cabinet. You must take the cabinet apart and thoroughly clean it. You must have a small leak that has been going on for sometime now for the moister has mildewed. Lysol will kill the smell on this although it must be cleaned first of all
Apr 28, 2010 | Amana NTW4500V Washer
I got an estate whirlpool washer and it wont spin and i smell a burning smell
YOU HAVE SOMETHING STUCK IN THE WATER PUMP OR YOUR MOTOR COUPLING IS BAD
Jan 15, 2010 | Estate TAWX700JQ Top Load Washer
Washer smells bad
Whirlpool and Tide make a cleaner that you put into the washer and run it through a cycle. Front loaders get a build-up that cannot be cleaned by hand. Make sure you are using a detergent that is marked "HE". Do not overfill the detergent or softener cups. I've heard that other used a lot of bleach in a wash cycle to clear out the smell. Bleach is bad to use if you're on a septic system, though.
May 03, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Mold & Smelly in Washer
Wash on hottest and longest cycle with regular laundry soap and a bottle of vinegar. After cycle, wash again with soap on hottest/longest cycle. This will clean your washer like new.
Nov 21, 2008 | LG WM-2277HW Front Load Washer
Bad mold and smell from washwe
i have repaired appliance most my life i tested soaps and softer,at our own family shop,i can tell you that washers do not make mold or bad smells either does cloths its what and how much product that you are pulling in the washer that is molding and smelling and it stays in cloths building up load after load,i have a kenmore he3t front load washer i use 1/3 cup powdered only.armen hammer only. non he only.my washer inside is spotless smells clean and fresh all the time, you will need to clean yours inside out with bleach then use affresh weekly switch to 1/3c powered soap
Nov 15, 2008 | Whirlpool Duet GHW9150P Front Load Washer
My washer a Tromm LG DLE377W leaves a bad smell in clothes after washed the smell is in the washer also smells sour
Sears has tablets for front load washers that work great. I use one every month and it has helped the stinky washer smell and the bad smell in the clean clothes. It is called Affresh and it works better than any of the cleaners you can buy in the grocery stores.
Aug 07, 2008 | LG Washing Machines
Bad smell inside my washer
Washer Magic Its a special cleaner they sell at most appliance retail stores (probably not walmart or lowes) please rate my advice>>>
Oct 02, 2007 | Kenmore 23822 Top Load Washer
Washing Machines Logo
117 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
