Question about Fantom Titanium II (TFD250U8) 250 GB USB 2.0 Hard Drive
Problem i have a fantom ex. drive 250gig sometimes the lights in front flickers from red to blue. sometimes it will reconize it but when looking at all my folders they are all empty if any one can help i would like it alot
  • dogslave Jun 02, 2008
    Originally I had the Fantom hookup via USP to my Mac running 9.2.2 and it always worked great. I then switched it over to my MacPro running Leopard via a Firewire port. It worked fine for about a month or two, and then I started getting the fluttering blue/red light on start up and t the Mac won't recognize it. I've switched to the USB port, then back again. No luck. I tried running it back on the old machine, and it won't recognize it either. I do hear the drive spinning up, but it won't mount.
  • Anonymous Nov 24, 2008
    MyTitanium 250 now suffers from the flashing blue/red light, which seemsto indicate mechanical failure.
    The drive is clicking, and will notmount. Fantom will repair the drive if I mail it back to them, but theywon't recover the data.
    I don't care about fixing the drive, it's onlyworth $100. I WANT THE DATA BACK!!! There are 10,000 songs on it!
    leaser62816
  • 7 Answers
SOURCE: Fantom 160GB Har Drive power light alternating btw red and blue
Have you tried running a search from your start menu (in Windows XP, Vista)? If not, go there and then use the drop down line at the top of the window. It should register what drive is plugged into or hooked up to your computer.
Posted on Mar 23, 2009
Crankstart
  • 696 Answers
SOURCE: fantom titanium external light turns red on connecting
Red is a failure warning but if it only hasppens with the usb plugged in it's mostly likey a failure in the IDE/SATA to USB conversion board.
Take the drive to your local PC shop, ask the techs there to pull the hard drive out of your phantom and test it in a new enclosure. If it works there, buy the enclosure, if it doesn't reply back and let me kow your Country, State and City and I can recommend a pro to look at the actual harddrive if you need files recovered from it.
Hope this helps FixYa
Posted on Sep 03, 2009
bruce508
  • 44 Answers
SOURCE: fantom drive is not being detected. Shows a solid
Since you've already tried different cables and computers, that eliminates a lot of things. Are there any configuration switches?
Possibly a cable or connector has come loose within the unit, particularly the edge connector that connects to the drive itself. If the unit is under warranty, try that first, espcially if you don't have important files that could be lost on the drive if you had to send it in for repair or replacement.
If you open it up, re-seat the connectors --- push them firmly into the drive PC board. If possible, remove each and put it firmly back into place. If that doesn't fix it, something is probably burned out and it is probably not something one can handle without access to factory replacement parts.
Posted on Sep 19, 2009
  • 14 Answers
SOURCE: Fantom hard drive red light!
There are no drivers for this unit. It is a plug & play unit that is one of the worst Fantom has ever offered. Very unreliable and many power cord problems.
I tried for several weeks to find the drivers over the net and researched a ton before I called Fantom Tech Support. The number is posted on New Egg under the their Mfg contacts
Posted on Oct 17, 2009
  • 60 Answers
SOURCE: Fantom 120 gb external usb harddrive
Make sure you are using the right power unit, or the power unit is working.
Posted on Dec 25, 2009
When i turn it on the light is flashing red and blue and my comupter will not reconize it
if your computer came with a motherboard disc the drivers could be on it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
make sure the lead/s that attach to this drive have a secure seating and are not bad/faulty the light on only tells that its getting power it might not be getting enough power you might test the lead/s or
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
hope this helps
May 16, 2011 | Fantom Drives 120 GB Hard Drive
I have a Fantom Titanium II FireWire+USB 500 GB Hard Drive that needs a new casing (blue light / red light / drive not spinning). I do not know if the current drive is IDE or SATA or something else. I...
Yes it does make a large difference. I did a search on that drive and there a lot of people who had good luck getting a replacement from the manufacturer. As far as a case is concerned I recently purchased one off of amazon and it was very inexpensive. Just look up "drive enclosure" on amazon.
May 02, 2011 | Fantom Titanium II (TFD500C16) 500 GB USB...
My Fantom II Hard drive only has a red light on
Sounds like the drive has gone faulty, all you can do is take drive out of case, get USB to HDD - USB "Dongle" and hook up HDD, and see if it works on PC & USB, If YES, then Case and interface are faulty, otherwise the HDD is faulty.
May 01, 2010 | Fantom Titanium II (TFD500C16) 500 GB USB...
Fantom titanium external light turns red on connecting
Sep 03, 2009 | Fantom Titanium Hard Drive
500 GB Fantom Drive not recognized on either of my Macs. Tried Firewire and usb; blinking light turns to steady red.Worked fine for about 2-3 years.
The symptoms don't look too good. Looks like the host controller is querying the hard disk (blink) and not liking the answer - or lack thereof (red).
It looks like the internal disk is defective. Sometimes the disk can be (possibly partially) recovered by disassembling the enclosure and mounting it in another enclosure or directly inside a compatible desktop PC.
Aug 14, 2009 | Fantom Drives 120 GB Hard Drive
Light blinking from Blue to Red
  1. 99 times out of 100 this means the hard drive has crashed.
The clicking sound is the key. If the data is critical you may need a specialist to retrieve it, if not, you can take it apart and replace the drive.
External drives with IDE drives get very hot because there is no fan in them usually. I recommend leaving it off unless you are using it. I have had hard drives crash on several very expensive ones...and they are usually only warranteed for a year.
Jul 31, 2009 | Fantom Drives 120 GB Hard Drive
May 13, 2009 | Fantom Drives 120 GB Hard Drive
Mar 23, 2009 | Fantom Drives 120 GB Hard Drive
Drive NOT being recognized by WinXP
Put your ear to the drive and verify if it is making any strange low level sounds. Check to make sure the usb connection wasnt affected. YOu wont need a driver as it appears to be hardware related. Either the enclosure or drive may be failing.
Oct 24, 2007 | Fantom Titanium II (TFD500C16) 500 GB USB...
Fantom Titanium II (TFD250U8) 250 GB USB 2.0 Hard Drive Logo
74 people viewed this question
Top Fantom Computers & Internet Experts
Mohammed Ebrahim M
Mohammed Ebrahim M
Lyle Siemens
Lyle Siemens
Are you a Fantom Computer and Internet Expert? Answer questions, earn points and help others
