Question about Dryers
Our gas dryer from fridgeaire is not heating and will pause to a stop after a while. Is there a way to address problem with calling in a technician.
  • Dryers Master
  • 43,501 Answers
Hi, If you have a gas dryerOur gas dryer from fridgeaire - 2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas DrOur gas dryer from fridgeaire - 2_bing.gifc="http://i.fixya.net/uploads/images/2_bing.gif" alt="2_bing.gif" class="h_mi" /> Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrOur gas dryer from fridgeaire - 2_bing.gifthis problem...
Dryer2_binOur gas dryer from fridgeaire - 2_bing.gifss= Troubleshooting2_bing.gif EOur gas dryer from fridgeaire - 2_bing.gifg src="http://i.fixya.net/uploads/images/2_bing.gif" alt="2_bing.gif" class="h_mi" /> Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on Aug 06, 2010
Dryer is stuck on paused and won't spin. Turned off and re-started but the motor ran for a few seconds and then went to paused again.
Good Morning Jill,
So I see that you were drying bath mats and the dryer got stuck in a "Pause" mode and even if you cancel and restart it shows "Pause" on the display. I would suggest resetting the dryer. What you will need to do is either unplug it or you can shut the power off at the circuit breaker. When you do this you will need to leave it off for at least 2-3 minutes. Cut the power back on, start any cycle. If you are still having trouble not being able to start the dryer and "Pause" showing, I suggest you either contact the manufacturer or your local authorized technician. I hope this is helpful.
-Best Regards-
WP
Mar 25, 2014 | Electrolux Dryers
Dg8200 maytag dryer not heating. whats wrong?
hello thirteen.... this gas dryer has a few possible reasons why there is no heat.
First of all, if you use propane, you may be out of gas.
Also, the gas ignitor may not be working or it may be dirty.
Call your gas provider. They will send out a technician free of charge to check your dryer and generally get it going once again. Joe
Mar 21, 2011 | Dryers
My Kenmore Gas Dryer 26 77642 won't get warm. Everything else works fine. Bought 3/07.Anything that we can check here at the house without calling service technician?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 11, 2010 | Dryers
I have a speed queen gas dryer model number Aqm499w2 that will not heat up.
Better give technicians a call your problem seems the igniter is busted.
Nov 06, 2010 | Speed Queen AES68AWF Gas Dryers
My lg dlg7188rm gas dryer will not heat. the gas
Sounds like you need an ignitor part number 5318EL3001A but you will need a gas technician to work on this legally. Best off to call a reliable service company such as Sears.
Feb 01, 2010 | LG DLG7188 Gas Dryer
My gas dryer isn't producing any heat. If there is a service technician on kine now, can someone assist me with what they think it might be?? It starts and goes the while time, just doesn't dry the...
Hi
Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats, motor heat switch, timer, selector switch, sensor.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
Jun 20, 2009 | Kenmore 74602 Gas Dryer
Dryer starts, then stops, no heat
Need model # and brand
Dec 31, 2007 | Dryers
Maytag dryer does not maintain heat and clothes smell
Check coils on burner assembly. Often when a dryer heats initially and then stops heating a coils has gone bad.
Nov 09, 2007 | Maytag MDG7600AW Gas Dryer
Gas burner doesn't work
Gas burners serve as the primary source of heat in a variety of home appliances: water heaters, gas dryers, and gas cooktops and ovens, and-of course-- furnaces and boilers. When the burner fails, most gas appliances are designed to stop working altogether to prevent a gas leak. As a rule, it's best to have gas burner problems fixed by your gas utility service person or a qualified heating technician, but there are a few steps you can take to avoid paying for a service call.
Jan 18, 2006 | Coleman 2 Burner Compact Gas 425F499G...
Checking my furnace's ignition
Dryers Logo
Top Dryers Experts
Marvin
Marvin
