Question about Toshiba REGZA 42WLG66 42 in. HD-Ready LCD Television
My Regza is less than 2 years old and it suddenly turned itself off. I cannot turn it back on and there is a yellow led light flashing. What could possibly be the problem? Is there a fix for it?
  • 11,361 Answers
More likely to have somting shorted out in the power supply or in the backlight inverter board. Right now the 5vdc standby power supply is working but not the rest.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx
Posted on Aug 06, 2010
Toshiba 46 inch regza yellow light blinks and picture wont come on but I have full audio
Most likely the power supply board needs to be replaced. It could also be the T-con board or less likely the display itself.
If you don't know what you're doing, DON'T OPEN THE TV UP TO FIX IT, THERE ARE HAZARDOUS VOLTAGES ON THE POWER SUPPLY BOARD, EVEN WEEKS AFTER THE TV IS UNPLUGGED!
If you don't know how to do it yourself, find some local Electronic repair shops, get quotes, try to find reviews on the shops.
Sep 21, 2016 | Toshiba Televison & Video
What's your problem? won't turn on..... yellow/orange light continually flashes three times...
Toshiba Regza 37in - 37HL17
TV will not turn on - Yellow power ind. Light blinks three times...
Fixed with a firmware update (hard to believe, but true). Search Google for a file named: 2007SEN069.zip (don't worry if the page you find it on doesn't mention the 37HL17 - it worked fine). Unzip the file, and copy the 3 folders and 3 files to the root of a small SD card. The SD card MUST be 2GB or less in size (I used a 1GB card), and it MUST be formatted with FAT-16 (not FAT-32). Mine was pre-formatted as FAT (FAT-16). The SD port is on the back of the TV behind a cover plate near the power cable. You do NOT need to remove the back cover of the TV, just the small cover plate (1 screw). UNPLUG the TV; remove the cover plate; insert the SD card (prepped as explained above); Plug in the TV; Watch the yellow lights blink, then turn blue, then go dark; UNPLUG the TV; remove the SD Card and replace the cover; Plug in the TV; Yellow lights will blink a few times (this is normal); when blinking stops, turn on the TV and you should be good to go. :-)
Pictures attached are from a Toshiba software upgrade bulletin I found online.
09adb97e-8925-4d59-b218-7443a6e64989.png 82ea33aa-2353-4e13-a5db-8be13ba85711.png
Aug 06, 2012 | Toshiba Regza 37HL17 37 in. LCD TV
Recently I purchased Toshiba REGZA 47 XL 700 E is LED. Is this TV LED ?
Yes and NO your tv is a LED. To be exact it is a LED Backlight LCD TV. An LED-backlight LCD television is an LCD TV that uses LED backlighting instead of the CCFLs used in traditional LCD televisions. It is not a true LED display but is called "LED TV" by some manufacturers.[1] The use of LED backlighting has a dramatic impact, resulting in a thinner panel, less power consumption and heat dissipation, and a brighter display with better contrast levels. You can go to http://www.regza-asia.com/pdf/LEDTV/XL700/47XL700SPEC.pdf and look at the complete specs for your tv
Mar 07, 2011 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
My toshiba 42" REGZA 42RV535U
U have sound but no picture?Picture does flashes a few sec?Yes,than those 2 long LCD inverter boards are dead.Tries websites like Shopjimmy.com,Ebay.com to buy those 2 long LCD inverter boards for the replacement.
Jan 13, 2011 | Televison & Video
I have been given a used Samsung TV without manual and have no idea how old it is or the exact size of this particular TV however, it is bigger than a 42''. I have written down the model code, serial...
The front panel LED light indication "LAMP" flashes?Change the the tv projection lamp or LED lamp first,see what happen?Than go from there?Tvs with "LAMP" LED indication light flashes,tv 1 1/2 or 2 years old use like 4 or 5 hours a day.The projection or LED lamp or bulb,inside life span is over.Require changing LED lamp or projection bulb.
Sep 10, 2010 | Samsung Televison & Video
Wont turn on but yellow light is flashing
I followed the steps at the following link and it worked for me. I have a 2007 Toshiba Regza 42HL67, but the firmware applies to many models as documented in the readme file at the location found via the link below. I used a 1gb SD card formatted FAT16, copied the unzipped files and folder to the card (wasn't sure if it required the top level folder or only the files under the top level folder so I copied both to the root of the SD card), unplugged the TV, inserted the card, plugged in the TV, waited 2.5 minutes, unplugged the TV, removed the card, plugged in the TV, yellow light flashed 3 times and went out. I turned on the TV and it has worked normally since last night.
http://www.benjammin.net/www/pages/techtips/Toshiba-Regza-42HL167.html
Jul 23, 2010 | Toshiba REGZA 47HL167 TV
I have a Fujitsu 42'' PDS4221 - 10 years old - shuts itself off
See Fixya tips and tricks:-
'Fujitsu Plasma 42" random shutdown - continuous flashing red'
While the model of your set is slightly different, the checks described generally still apply, as it is very similar.
Nov 18, 2009 | Cars & Trucks
Tv won't turn on at all
Hi
the best thing you do is to go back the unit where it you buy because this is under warranty
Thanks!
Jun 09, 2009 | Toshiba REGZA 47HL167 TV
Won't turn on, power button goes red, yellow, then flashing red??
it probably overheated if the fan doesn't come on if its under a year old call sony for warranty repair they will send you a box and pay for shipping and everything if it isn't under warranty anymore sony will still fix it for 149.00 includes shipping
Jan 06, 2009 | Sony Playstation 3 (PS3) Console
Toshiba REGZA 42WLG66 42 in. HD-Ready LCD Television Logo
192 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
