Question about Polaroid TDA-03211C 32 in. LCD HDTV
I have a polaroid 32 inch tv have sound but no pitcher what worng it
  • 11,361 Answers
Unplug it for about an hour first to let it reset itself and try again, if it is still not working then:
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there are some troubleshoot you will have to do to find out the causes of the problem you are having.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx
Posted on Aug 06, 2010
My LED LG TV 32 inch is not diplaying pictures on screen but the sound is working normally. how can I fix it?
hi you may have a power supply,or the led or leds in the panel are shorted,thanks
shaun
Mar 03, 2017 | LG Televison & Video
The screen is blank on my Polaroid 32 inch led tv but there are sounds from it
Do more research next time (check both good and bad reviews of any product) on amazon and then buy chosen product from your place of choice. Polaroid seems not very highly rated for tvs losing picture or sound. Good luck. (: x
Sep 16, 2016 | Polaroid Televison & Video
Sound on but no pitcher
Sound on means audio section is ok. No picture is video board problem. Pl check input cables. Or give Hdmi cable input. Disconnect all inputs switch on u should get plain raster that is only dots on screen, or blue back screen, if nothing contact authorised dealer,
Feb 08, 2015 | Panasonic TH-L32C20X 32 inch Multi-System...
Screw size for 32 inch polaroid
Kindly check the operation manual, if not locate one for free download in websites.
Jul 16, 2012 | Polaroid Televison & Video
Tv blacked out no sound either, but power light comes on and off
just talked to polaroid because mine did the same thing......... power light is on and when you first power it on..... the polaroid screen appears for a second and then goes out............. they told me it sound like the control box and would cost me 225.00 to have it fixed............. does anyone know how to get a control box from some one other than polaroid....
my tv is TDA-03211C 32 inch with built in DVD
Mar 22, 2010 | Insignia IS-LCDTV32 32 in. Television
When I try to turn on my polaroid tv (FLM2601),it wont turn on.
Try unpluging the unit for a few minutes. And try again.
To reach Polaroid's warranty services call 1-866-289-5168. Polaroid's TV warranties cover the units for 1 year similar to most manufacturer warranties. For TVs less than 31 inches Polaroid requires you to carry the unit into a servic center for repair. For TVs 32 inches and larger Polaroid provides in home service.
Feb 24, 2010 | Televison & Video
Looking to buy a Polaroid TDA-03211C the needs repair
I have a 3 year old TV with the same problem as shema_ross.
Aug 16, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
I have no sound on my 32 inch polariod tv none at all please help
What it sounds like is wiring inside to the speakers got disconnected. Does the TV have a jack for headphones or external speakers? If so, then I would connect something to see if you get sound.
If you still do not have any sound, then your audio outputs may have fried.
Jan 17, 2009 | Polaroid FLM-3225 32 in. LCD Television
Polaroid TDA-03211C 32 in. LCD HDTV Logo
286 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
