Question about Sanyo Televison & Video
What is the best manual picture setting for a sanyo dp26640 on an xbox 360
  • 63 Answers
SOURCE: XBOX 360/SAMSUNG PLASMA TV
If you have an Xbox 360 Elite or a newer Xbox 360 Premium, you should use an HDMI cable if your TV supports it. Otherwise use a component cable.
Posted on Nov 25, 2007
SOURCE: xbox 360 wireless adapter connection
Try licking your balls.
Posted on Sep 12, 2008
joboo1
  • 257 Answers
SOURCE: Best setup for Xbox 360 for Sony 32" Tube WEGA tv
Hi, Not sure whether you are kidding or not. You don't mention the tv model so I will try to help using a KV-32FS100 as an example. You really only have 2 choices assuming you have a current model xbox 360. The component cable that comes with the xbox has 6 connectors, a green, blue, red, yellow on one part and a white and red on the other part. On the back of the tv below and to the right of the s video connector are inputs labeled Y, Pb and Pr and are colored Y is green Pb is Blue and Pr is red if they aren't colored that is the correct order. Don't connect the yellow to anything. The red and white on the other part of the cable go directly to the right of these connections. It will say audio and L and R they should also be colored but if not white is L and red is R. There is also a small switch at the xbox end of the cablewhich you need to slide to HDTV. Once you are powered up don't forget to enter the setup menu on the xbox and select the settings for your tv. Again without knowing the model most wega tvs limit the component input to 480p which was the limit of a dvd. I hope this is helps.
Posted on Jan 28, 2009
SOURCE: HOOKING UP XBOX 360 TO HDTV
You have to use the regular red and white cords(not the yellow) and u have to use all 3 hd cords. If ur tv doesnt have a place to put the cords in, then it isnt HD. Also on the plug connecting to the 360, there is a switch that has HD and regular, switch it to HD. hope this helped.
Posted on Feb 19, 2009
bill_48632
  • 149 Answers
SOURCE: Best XBOX 360 Disc Drive?
Hi, first let me say that as far as the DVD drives go I don't really think there is a significant difference in any of them. It basically boils down to who offered Microsoft a DVD drive cheaper. Next, I would strongly recommend that you get the same model/part number DVD drive.Reason is that you will have to do alot of work trying to get a different drive to work in your system. such as "flashing the drive" or having to change the sisterboards to make it work.
Posted on Aug 11, 2009
Testimonial: "yeah thats what i kinda figured. thanks"
Whee is the analog audio output for sanyo dp26640
After reviewing the manual ( http://www.manualslib.com/manual/306783/Sanyo-Dp26640.html#manual - page 6), it does not appear that this television has an analog output. A fix to this problem would be to purchase a digital to analog audio converter (just Google this) and some inexpensive solutions are available.
Good luck,
Feb 04, 2015 | Sanyo DP26640ARB - 26 LCD HD TV 720p...
How do I connect a Xbox 360 Console without HDMI to a Grundig LED-tv 40" to get the best picture?
If your tv has a composite wiring inputs (5 wire red,white,yellow,blue,green) use them it will provide a better picture picture quality than the standard rca a/v cable (red,white,yellow) After you connect the composite cable from console to tv go into system/console settings/tv picture quality and adjust settings there
Jan 12, 2011 | Video Game Consoles & Games
Feb 19, 2009 | Microsoft Xbox 360 Console
Xbox 360 no picture but sound, works on another HDTV
did you check to see if the av conponent was on tv/hdtv?
Nov 15, 2008 | Microsoft Xbox 360 Console
Xbox360
is your 360 set to 1080i
Sep 13, 2008 | Microsoft Xbox 360 Console
Xbox 360 stretched screen out and cannot fix it now
Have you checked the aspect ratio?? May be that when the kids had the X-Box hooked up they simply changed the aspect to zoom.
May 22, 2007 | Sanyo DS20425 20" TV
Televison & Video Logo
306 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
