Question about Rolex Daytona 116520 Wrist Watch
Rolex Daytona Chromograph
Hi - how do you start/stop/reset the stopwatch features on this watch?  I know you have to unscrew the buttons before you can use them, but then what?
  • BIGBORE Jun 03, 2008
    My Rolex daytona second hand is rest but at the 2 second register and not at Zero how do I fix it?
Ok. bear with me. lol. on most watches without a chronograph. the second is the largest hand on the watch and naturally that's what most people refer to as the second hand. On a chronograph the "true" second hand is the little middle dial. It should always be constantly moving and the large hand should only move when the stop watch funtion is in play. The way to employ the stopwatch funtion is by unscrewing both buttons. The top button starts the action. Once pressed then large hand will begin. The little dial on you left will keep up with each minute that passes. To stop the function, press the top button again. To reset the stop watch, press the bottom button. The little dial on your right is simply military time. Hope that helps. Good luck!!
Posted on Jun 07, 2008
  • fogg1980 Jun 15, 2008
    for bigbore. instead of pressing and releasing the reset button, hold it down until the second-hand stops. it should readjust itself. hope that helps
I have a diamond encrusted rolex daytona 24 watch, is it real? it has about 200 diamonds on it, if its real how much will it be worth?
A feature of Rolex watches is a solid caseback. The only time an engraving is placed on any Rolex watch casebacks is as an aftermarket feature (i.e "Tom, I love you, Sue").
The "Winner Daytona 24" engraving on the back is, i'm afraid, a common feature of a replica Rolex watch.
Aug 26, 2012 | Rolex Daytona 116520 Wrist Watch
Rolex daytona
its not the manual, but this might help:
the three button chronograph would be brought together in the form of the 5034. During the next fifteen years the 5034 changed into the 6034, which then became the 6234. This in turn became the 6238 and then finally evolved into the 6239. These changes although little by little had inspired Rolex to revive the previously shelved name the "Cosmograph". The only difference between the 6239 and the 6238 was that on the 6239 the bezel was engraved with tachymeter graduations rather than having them on the dial. The last major changes to the manual wind chronograph came in the late 1970's when Rolex introduced the 6263 model. This was the first model to have truly waterproof pushers. The earlier Oyster Chronographs had simple round pushers with internal gaskets as the only sealing mechanism. The screw down pushers were added to stop people pressing the buttons, whilst submerged in water. The locking function also prevented the chronograph being activated inadvertently. The new 6263 started life as being waterproof to 165 feet, ten years later it was capable of twice that depth (100 meters) The 6263 is unusual in the fact that the quality of the movement depended on which case you had. The steel chronograph movements were not timed to a chronometer standard. Despite the innovative design it was not until 1986 when the popularity of the Daytona started to increase, reaching its zenith with a particular Daytona model, the "Paul Newman". This model featured square markers on the subsidiary dials, and an outer track the same colour as the subsidiary dials.
Dec 17, 2007 | Rolex Daytona 116520 Wrist Watch
Thankyou for assisting me . On my Daytona , the top and bottom press buttons wont work the stop watch second hand at all. Also they must be screwed out to allow them to be pressed in . Is that normal ?
I don't know the solution to your problem (your could always send it to their nearest service center; see Rolex.com) but screwing out buttons is a feature that is often included to give maximum water resistance.
Feb 10, 2011 | Rolex Daytona 116520 Wrist Watch
Need manual for rolex daytona men's watch
Hello
These are the things you might need about the watch.
1. Turn the crown clockwise while it is in position 2 to manually wind the watch.It will stop if it has not been worn out or put in a watch winder for roughly two days.
2. Pull the crown out one notch to position 3 to change the time.Turn the crown clockwise to move the minute hand.
3. Push the crown back into the watch while turning it clockwise to return the crown to position 1.The crown should be tight to ensure the watch case is waterproof.
4. Operate the stopwatch and chronograph function by pressing the button located above the crown on the 3 o clock side of the watch.Stop the stopwatch by pressing the button again,Reset the stopwatch by pressing the button below the crown.
BEST OF LUCK
Jul 13, 2010 | Rolex SS/18kt Daytona
Stopwatch second hand stops/jams at 57 seconds point jamming the whole works. Watch stops. Keeps excellent time otherwise if stopwatch not used. 2003 ss model. Bought new from rolex.
This may sound obvious but it needs to be repaired by a jeweler/watch repair shop. Although it is possible that the stop watch second hand is out of sync it would usually mean that the stop watch is starting at 3 seconds before 00:00 for 57 stop. If that's the case you should be able to readjust the start/stop position by pulling the crown out to 1st or 2nd position and then pressing the stop watch start stop buttons. One press, one position. Although I am not certain of the exact sequence.
However if you are unsure or it starts at the 00:00 position you need to find a jeweler you can trust to do the work. Check out a few places and ask to see the credentials of the watch repair person then compare and make an informed decision. Don't just use the jeweler at purchase point.
Most times, if it's a simple repair, like readjusting the hands a good jeweler will do it for nothing.
Good luck
May 14, 2010 | Rolex Daytona 116520 Wrist Watch
Stopwatch second hand stops/jams at 57 seconds point, jamming the whole works. watch stops. keeps excellent time otherwise if stopwatch not used. 2003 SS model. bought new from rolex.
this watch will need a service from a rolex trained repairer wich wont be cheap 700 dollars min or 500uk pounds min..you could try tapping watch in palm of hand to see if a batton or luminous paint has come loose,then all it needs is movement taking out and blown clean inside case.any decent repairer can do this.sometimes the teeth on a wheel can wear in one place hence it always stops in same place.recomend service as best action,you never loose on a rolex...
Mar 26, 2010 | Rolex Daytona 116520 Wrist Watch
How to know fake or not rolex daytona 1992 ..
Take a look on amazon for real watch prices (Daytona): Amazon com Rolex Daytona . After that you can compare. I hope this was helpful. Cheers
Jun 12, 2009 | Rolex Daytona 116528 Wrist Watch
Rolex Daytona Replica
this may help. unscrew both buttons. push in top button to start.again to stop.bottom is to reset. coincidently large sweep second hand is used for chrono and not the smaller register. the other registers are 24 hr military time and chrono minutes.
Mar 30, 2008 | Rolex Daytona 116520 Wrist Watch
Rolex Daytona 116520 will not start
no! you have not done anything wrong my suggestion is bring it to an authorized rolex service center or any certifide rolex watch fixers.to avoid any damage of your rolex daytona. it mabe costly but you have made it wisely.
Mar 10, 2008 | Rolex Daytona 116520 Wrist Watch
Rolex ad Daytona 1992 replica
The advice given here is accurate to a degree. When wound, a rolex daytona IS running. However, it is the running seconds hand in the small sub-dial that is actually running. In the earlier Daytonas, this sub-dial was at the 9 o'clock position on the dial, (pre-2001 series daytonas). The later daytonas, from 2001 on, use the seconds at 6 position for counting seconds. The main sweeping second hand on the watch dial will NOT start until activated by the pusher at the 2 position. That pusher needs to be unscrewed and then pushed to start the large sweeping second hand. This action, in turn, starts the remaining 2 sub-dials in motion, counting minutes and hours. To stop the chronograph function, you push the pusher @ the 2 position again, to stop the sub-dial hands from counting, and then push the pusher @ the 4 position to re-set the dials to their "straight up position". This stops the chrono's function, until it is needed again, BUT the main running seconds, (at either the 9 or 6 sub-dial position, depending on the year series of the daytona) will continue to run, thus keeping accurate time.  Hope this gives you a better idea of how the timekeeping of the chronograph function on a Daytona works. So, to start your seconds running you need to start the chrono function by pressing the pusher at the 2 position. That will allow you to see the large sweeping second hand I think you're referring to here. Hope this has helped.
Doug
Jan 11, 2008 | Rolex Daytona 116520 Wrist Watch
Rolex Daytona 116520 Wrist Watch Logo
494 people viewed this question
Top Rolex Watches Experts
Samyfam
Samyfam
Are you a Rolex Watch Expert? Answer questions, earn points and help others
