Question about HP PhotoSmart C4280 Laser Printer
How do i load a new ink cartridge - HP PhotoSmart C4280 Laser Printer
    Scholar:
  • 121 Answers
Here is the link to the user manual. Your specific topic is in Chapter 11, page 67. Hope this helps
http://h10032.www1.hp.com/ctg/Manual/c00897310.pdf
Posted on Aug 06, 2010
My printer won't align new ink. It says load paper in tray. I load it. then blank page come out and gives me the same message. Load paper in tray. I did a diagnostic test and at the bottom it says...
Sorry to know you're in trouble with your printer. Here are my suggestions: You have to buy a new genuine cartridge or you can refill ink. Be warned! Refilling ink or using a refilled ink cartridges will not work until the ink cartridge chip or ink monitor is disabled. For instructions on how to disable an ink cartridge chip, please visit [http://www.ehow.com/how_6201242_disable-ink-cartridge-chip.html]Now you can CURSE the manufacturer of your printer for making your life sucks by making it complicated the things that should be made SIMPLE and EASY. Printer or Cartridge, more or less, cost you the same. Don't you think the printer cartridges should be made simply refillable/usable unless they are broken, and we should be buying only the ink for the cartridges. It is SO ANNOYING, dude! Good luck.
May 06, 2011 | Office Equipment & Supplies
Do not know how to change ink cartridge x2650
Lift the scanner unit, and then press down on the cartridge carrier latch to raise the cartridge carrier lid. The print cartridge carrier moves and stops at the loading position, unless the printer is busy.
Remove the used print cartridge. Insert your new cartridges.
Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Follow the steps below:
1. Unplug the printer from the power source.
2. With the cover open, hold the solid white strip that connects from the carrier assembly to the ink cartridge carrier and gently slide the cartridge carrier to the center of the printer.
3. Remove the used cartridges.
4. Load the new cartridges. Close the cover.
5. Plug the printer back to the power source.
Apr 28, 2011 | Lexmark C533DN InkJet Printer
How to instal a new printer ink cartridge
Turn on your printer.
Lift the printer unit, and position the scanner support between the tabs to hold it open.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
Press down on the ink cartridge lever to raise the ink cartridge lid.
Remove the old ink cartridge.
Dispose of the old cartridge properly.
If you are installing a new ink cartridge, remove the sticker and transparent tape from the back and bottom of the ink cartridge.
Insert the new ink cartridge.
Snap the lid closed.
Lift the printer unit, and hold the scanner support up while lowering the printer unit until it is completely closed.
DON'T FORGET TO RATE THE SOLUTION, THUMBS UP!
Nov 22, 2010 | Dell 810 All-In-One InkJet Printer
How do I change the ink cartriges in my printer
1.Turn on your printer.
2.Lift the scanner base unit.(The ink cartridge carrier moves and stops at the loading position unless the printer is busy.)
3.Press down on the ink cartridge lever to raise each ink cartridge lid.
4.Remove the old ink cartridges.
5.Insert the new ink cartridges. Make sure the black or photo ink cartridge is secure in the left ink cartridge carrier, and the color ink cartridge is secure in the right ink cartridge carrier.(Make sure to take off the sticker and the transparent tape from the back and bottom of the new cartridge.)
6.Snap each lid closed.
7.Lower the scanner base unit until it is completely closed.
Enjoy printing...
Sep 14, 2010 | Dell V305w All-In-One R840635AU InkJet...
Loaded new color ink cartridge to my canon printer pixma 480
Use the wizard to replace the ink cartridge. The main idea is that the software must "reboot" and restart measuring ink levels and the only safe and easy way to do that is by using the wizard.
Feb 15, 2010 | Canon Pixma MP480 All-In-One InkJet...
How to load new ink into printer Canon Pixma 620B ? Thank you!
Step 1.
Open the hood of your printer; if the ink cartridge holder does not slide into view, check to make sure the printer is turned on.
  • Step 2 Remove any empty cartridges from the ink cartridge holder and dispose of them properly. Some Canon printers have a protective cartridge lid that must be opened before you can change a cartridge.
  • Step 3 Remove all protective tape and plastic film from the fresh cartridge. Canon uses a bright orange protective tape on its ink cartridges. Some Canon ink cartridges also have a bright orange protective cap over the ink nozzle that must be removed before installation.
  • Step 4 Insert the new cartridge into the ink cartridge holder. Tilt the cartridge up slightly and insert end-first into the proper slot; push down gently on the cartridge to lock it into place. Some Canon printers have an indicator light that will activate when the cartridge is firmly installed; other models have a cartridge cover that will lock into place when closed.
  • Step 5 Close the hood of the printer. The printer will indicate when it is ready for use with a message on the LCD screen or by blinking the LED indicator light.
  • Jan 22, 2010 | Canon Office Equipment & Supplies
    How do I change the ink cartridge on my Dell 810 printer
    Ink Cartridge Maintenance Replacing an Ink Cartridge
    1. Turn on your printer.
    2. Lift the printer unit, and position the scanner support between the tabs to hold it open.
    1. Press down on the ink cartridge lever to raise the ink cartridge lid.
    1. Remove the old ink cartridge.
    1. Dispose of the old cartridge properly.
    2. If you are installing a new ink cartridge, remove the sticker and transparent tape from the back and bottom of the ink cartridge.
    1. Insert the new ink cartridge.
    1. Snap the lid closed.
    1. Lift the printer unit, and hold the scanner support up while lowering the printer unit until it is completely closed.
    rcrtdrc1.jpg Aligning an Ink Cartridge You may need to align the ink cartridge when characters are not properly formed or are not aligned at the left margin, or when vertical or straight lines appear wavy.
    To align the ink cartridge:
    1. Load plain paper. For more information, see Loading Paper.
    2. In Windows XP, click Start® Control Panel® Printers and Other Hardware® Printers and Faxes.
    In Windows 2000, click Start® Settings® Printers.
    1. Right-click the Dell AIO 810 icon.
    2. Click Printing Preferences.
    The Printing Preferences dialog box opens.
    1. Click the Maintenance tab.
    2. Click Align Print Cartridge.
    3. Click Print.
    A blue and black alignment page prints.
    1. After the alignment page has finished printing, place the page face-down on the scanner glass. Make sure the upper left corner of the front of the page aligns with the arrow on the printer.
    1. Press the Scan button scanicoa.jpg .
    The page is scanned. When the scan is complete, the cartridge is aligned. You may discard the alignment page when the alignment is complete.
    Please download the manual from the link below and go to chapter Ink Cartridge Maintenance:
    http://support.dell.com/support/edocs/systems/PRN810/en/ug/ug_en.zip
    Hope it helped.
    Nov 22, 2009 | Office Equipment & Supplies
    Hi there
    Replacing Ink Cartridges 1. Turn on your printer. 2. Lift the printer unit. 3. The ink cartridge carrier moves and stops at the loading position unless the printer is busy. 4. Press down on the ink cartridge lever to raise each ink cartridge lid. 5. Remove the old ink cartridges. 6. Store the cartridges in an air-tight container, such as the storage unit you received with your photo cartridge, or dispose of them. 7. If you are installing new ink cartridges, remove the sticker and transparent tape from the back and bottom of each ink cartridge. 8. Insert the new ink cartridges. Make sure the black or photo ink cartridge is secure in the left ink cartridge carrier and the color ink cartridge is secure in the right ink cartridge carrier. 9. Snap each lid closed. 10. Close the printer unit. 11. An alignment page automatically prints.
    Mar 01, 2009 | Dell 926 All-In-One InkJet Printer
    Loading the ink cartridge
    Please remember to rate other users who assist you for free :)
    How to install or remove ink cartridges To print normally, install or remove ink cartridges in an orderly procedure.
    How to install ink cartridges
    1. After confirming that the printer is powered on, open the front cover. The ink cartridge holder moves to the replacement position.
    2. Take out an new cartridge from its casing and gently remove the orange protective tape in the direction of an arrow.
    Caution: Do not attempt to reattach the protective tape once you have removed it. Do not touch the gold electrical contacts or the print head after removing the protective tape.
    3. Insert the color cartridge into the right slot and then the black cartridge into the left slot.
    Note: Push up on the nearest side of the cartridge until it clicks into place.
    4. Confirm that the ink cartridges are installed properly.
    (A) The ink cartridge is not installed properly.
    (B) The ink cartridge is installed properly.
    5. Close the front cover. Wait until the preparatory operation is complete; it takes about one to two minutes.
    How to remove ink cartridges
    2. Remove the ink cartridges.
    Note: Handle the ink cartridges carefully to avoid staining clothes and surrounding work area.
    Sep 29, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
    Dell 725 printer no manual need to change ink cartridge
    Here is the manual
    http://support.dell.com/support/edocs/systems/725/en/index.htm
    2. Lift the front cover.
    1. Close the front cover.
    Feb 09, 2008 | Dell 725 InkJet Printer
    HP PhotoSmart C4280 Laser Printer Logo
    260 people viewed this question
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
