Question about Mitsubishi VS-45607 45" Rear Projection Television
Mitsubishi wt-42413 I too have a unit which is shutting down after 15 seconds. When you say press the menu key and input key...do you mean channel up and down? I'm unclear how to check my code? Tx
  • kanecats Apr 29, 2008
    I do not have a menu or input key on the front of my unit?
  • tin tola May 25, 2008
    i have a mitsubishi vs 5004 r and its asking me for a 4 digit personal password how do i take it off
Well, pressing the buttons for 8-seconds is a pretty neat trick when the thing powers-off almost immediately!
Posted on May 20, 2008
  • Mitsubishi Master
  • 8,617 Answers
No you have to push the buttons on the set that say menu and the button that says Input or device both in together for 8 seconds to initiate the self diagnosis feature.
Posted on Apr 27, 2008
When turned on mitsubishi WT-42413, it turns off itself within a second. any help?
Check you -24and + 24 on power supply and you green fuses if open fuse replace fuse and the stk394-250 good luck
Jan 16, 2011 | Mitsubishi WT-42413 42" Rear Projection...
My Mitsubishi WT 46807 will not power up. The green light on the front stays on for approximately 2 seconds and then goes out with no audio or visual. I tried unplugging the set for about 15 minutes but...
yes!
When you turn set on and power light goes out do the self check this set has.
On front of set when light goes out press and hold both the Menu and Input (device) buttons at the same time and hold both for at least five seconds and then release both.
Power light will blink a two digit error code like 2 blinks,2 blinks, a pause and repeat it several times.
Let me know what error code you find and I will tell you what it means. Make a comment here and I will assist you.
SD TECH
Nov 27, 2010 | Mitsubishi WT-46807 46" Rear Projection...
I have a mitsubishi wt-42315. when i turn it on it shuts down right away. any thoughts?
Do the self check this model has.
When you turn it on and green power light goes out:
on front of set press and hold both the menu and input (or device) buttons at the same time for at least 5 seconds and release both buttons.
The power light will blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code you find and I will tell you what problem is.
If this helped rate this solution as very helpful as I do this here for free.
SD TECH
Sep 20, 2010 | Mitsubishi WT-42315 42" TV
Tv won't stay
It sounds like the convergence went out. STK 394-250 and some pico fuses. Check that the error code is 2.2 before you replace any parts.
To check the error code simply hold down the menu and device buttons for 5 sec and count the flashes inbetween pauses. Goodluck.
Jul 05, 2010 | Mitsubishi WT-42413 42" Rear Projection...
How do I access RCA HDTV D52W23 Service Menu?
Shut unit off. Wait 10 to 15 seconds then press and hold volume down and channel down together for 10 to 15 seconds. This will get you into the service menu.
Apr 07, 2010 | RCA D52W23 52" HDTV CRT TV
Mitsubishi WT-42413 Red Convergence will not move left right
U check all the resistors with the Ohm Meter?All the resistors u check it in tolerance?Resolders all the resistors,so it make good resistance for the ICS?U do all these steps,u still have problems,Ur ICS some how it shorted it dead,again.
Apr 02, 2010 | Mitsubishi WT-42413 42" Rear Projection...
Mitsubishi WT-42413 Blue Green and Red Line
there is a section in the tv working just to keep the screen fitting top to down (vertical section) some capacitors are dry now in that area. this one has not to be a expensive job in the workshop. Try estimates
Apr 14, 2009 | Mitsubishi WT-42413 42" Rear Projection...
Certain HD settings won't work
no the set uses only two settings in the Y, Pb,Pr which it swithes back and forth. when a 480i,480p SD singal is detected it will switch to 480p, when an HD signal is detected it swiches to 1080i. when it swiches the picture scrambles for a second or two. to correct this in your cable box (if it's a motorola box) leave the tv on, press the power button on the box to shut down the box. next press the menu button on the box and the internal menu will show. use the cursor buttons on the box to select "480i overide" use the arrow to the right to select "streached" them hit menu to get out. hit the power button to turn the box back on.
Dec 16, 2007 | Mitsubishi WT-46809 46" Rear Projection...
WT-42413 continues to shut down. Need to wait 15 minutes to restart
End of year Followup: 2004 TV I swapped for is still working great. No issues of any sort.
Happy New Year,
Don
Jan 01, 2007 | Mitsubishi WT-42315 42" TV
Mitsubishi VS-45607 45" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
