Question about Sanyo DP32746 32 in. LCD Television
Have a 52 inch sanyo dp52449 light come on the switch but no display sometimes light blinks on switch but thats all
    President:
  • Sanyo Master
  • 776 Answers
What you need is a replacement or repair of the main board N7KE.
You can find the later here:
http://www.coppelltvrepair.com/p/59/sanyo-dp52449-p52449-01-main-board-n7ke-repair-service
For some background of the same problem read here:
http://blog.coppelltvrepair.com/2012/07/sanyo-dp47460-dp42840-dp46819-and.html
Posted on Oct 03, 2012
  • 11,361 Answers
Unplug it for about an hour to let it reset itself, if it is still not working, you will have to do some troubleshooting.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx
Posted on Aug 06, 2010
DP52449-01 power on green light OK , no control one ch. comes on and flashes on and off aboujt 10 times and then stays on with audio. still no control just on AND OFF CONTROL.
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jan 01, 2017 | Televison & Video
Jake I have a 52 inch Panasonic plasma tv that will only run the fans for a few seconds and shutdown red light blinks 10 times and repeats.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Nov 10, 2015 | Panasonic Televison & Video
How to check power supply
You can use this LCD Digital Ohm VOLT Meter AC DC Voltmeter Multimeter
Or this Digital Amp Ohm Volt Meter Ac Dc Voltmeter Multimeter
or any other similar device..
Jul 29, 2015 | Sanyo 52" Class LCD 1080p 120Hz HDTV,...
52" SANYO dp52440 POWER LIGHT COMES ON AND OFF PICTURE WON'T COME ON
I had a similar problem with a smaller size sanyo, it turned out to be terminal due to cost of repair Vs cost of new TV
Sep 22, 2014 | Sanyo DP52440 52-inch 1080p 120Hz LCD TV...
Dp52449 firmware update
i ask one of the technicians you need to go though your sync setting againg but for firmware update, you cant update it.
thanks
Mar 17, 2014 | Sanyo Televison & Video
Sanyo dp52449-01 no picture, has sound, screen has faint brightness
The described may lead many to point to backlight inverters however it is extremely uncommon for backlight to work in a way that would produce "faint" light.
it is a whole lot more likely that backlight is functioning properly, but the display in front of it is all shut and not functioning, i.e. all light filters are closed and not opening.
This would point to either the T-CON board or the main board or, at worst, the LCD itself, which is however less likely.
May be something as simple as a bad connection of a cable on the LDVS cable - we've seen that happen once or twice.
We've also seen exactly that happen due to a problem on the main board, but the circumstances were such that it's hardly the same issue.
In any case , if you want the main board tested and possibly repaired you can use this:
Apr 05, 2012 | Televison & Video
Sanyo DP52449, tv getting power but no display
When DP52449 (chassis 01 - that is important!) does not power on and the front LED flashes every 15-20 seconds you have a faulty main board, which you need to replace or get serviced.
We presently do not offer replacement boards, but we do offer repair services for them at
You may also be curious to read the article we wrote back in July 2012 on a problem that sounds exactly like yours and which lead to the service offerring:
Hope this helps!
Feb 20, 2010 | Sanyo DP32746 32 in. LCD Television
Green status light keeps blinking after lamp replacement
continuous blinking green light indicates that the capacitors have failed on the DM pwb. You need the V26 DLP DM repair kit which is available at the following link under their repair category.
http://servicemanuals.vstore.ca/
Sep 07, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Sanyo DP32746 32 in. LCD Television Logo
1,288 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
