Question about Jensen Audio Players & Recorders
I have a jenson 3 change cd player, jmc 1500. It has been in the box for 4 months and whilst it plays my cd's ok it jumps intermitently throughout each cd?. Most of my cd's are new so I know they are ok.and I am worried they will be scratched. Can you assist?\r\nThankyou patricia.
  • patricia  Heslam
    patricia Heslam Aug 06, 2010
    I will purchase a cd cleaner and hope this fixes the problem.
    Thankyou.
    patricia.
    Guru:
  • 528 Answers
Hi.You need to clean the lens of the CD player. Use a q-tip and alcohol and wipe the lens of the cd player gently then let it dry for 5 mins. Do not apply too much alcohol, Two drops to the q-tip will be ok.
Posted on Aug 06, 2010
  • patricia  Heslam
    W\Thankyou but where do I find the lens of the cd player. I am a 62 year old grandmother and have no idea of one end to the other?.
  • Archie Cruz
    Archie Cruz Aug 06, 2010
    I understand. You may also try using CD cleaners instead of using the q-tip. I see this is a mini component and mostly cd lens are inside the component and you need to take apart the unit inorder to see the lens.
JMC-600, CD won't spin, "Err"
if speakers are connected sorrectly and you have no sound from the radio your build in power supply is prob bad. call the manufacturer for warrenty or just buy a stereo
Jan 29, 2011 | Jensen JMC-600 CD Shelf System
Lost manual for jensen jmc-326
http://www.spectraintl.com/jn/pdf/JMC-326%20EIB.pdf
Nov 29, 2010 | Audiovox JMC326 2Disc CD Player
What age is recommeded for using the jumperoo? and how do I set the height to a lower level?
It should say on your box. but 6 months is usually the age. but really when they can support their neck and hold their own head up.
My son started using it around 3 months. I put him in it when he had good neck strength and no longer had any head wobbles.
From about 3-5.5 months he enjoyed the toys on it. But he didn't start jumping until about 5.5-6 months, but once he figured it out (literally after I demonstrated it by jumping in front of him) he LOVED jumping and playing with the toys.
Check that using Bumbo about 3-4 months. Doorway jumper 5-5 1/2 months. Exersaucer 6or 7 months maybe.
I hope helps.
Oct 04, 2010 | Toys
1996 vulcanD classic 1500 30,000km
sounds like the gear selector plate plunger is worn or needs a new spring. on most engines a hollow screw @ 3/4" is accessible from under gear box, take it out and stretch the spring and retry to eliminate possibility.
Sep 14, 2009 | 1996 kawasaki VN 800 Vulcan Classic
CD player does not play any CD
not play any cd...........
you can clean the lence or change if necessory,,,
the remot prob.......
you can check battery,,,pad (rubber) or sensor
check and change if applicable ........
or you can also change the remote .......
Jul 02, 2009 | Audio Players & Recorders
Starting problems when hot on hyundai coupe 1.6 1999
it sounds like an ignition component ( ignition module, coil, etc.) is heating up causing it to fail intermitently, look on ebay for ignition module it is located under the distributor cap.
Jul 01, 2009 | 2000 Hyundai Accent
Jenson VM9311TS will not play all speakers in cd mode
YES!! You used the blue wire to turn on factory amp (blue wire to GM pink) you NEED to use the Blue/White wire. That is the amp turn on. The blue wire goes dead when you play a CD or DVD because it's for a power antenna. So, Blue/White ok?
Enjoy,
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Jan 22, 2009 | Jensen VM9510 Car DVD Player
Sharp lc-26sh10u intermitent problem
its a motherboard problem. i got one for sale or you can sell me the tv cause mine has a broken screen
Dec 25, 2008 | Sharp LC-26SH10U 26 in. LCD Television
Brnt cd's?
angel1986..some decks will not play burnt cds .it was the way they made them..
Feb 08, 2008 | Car Audio & Video
103 people viewed this question
Top Jensen Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Jensen Audio Player and Recorder Expert? Answer questions, earn points and help others
