Question about Frigidaire 20.6 cu. ft. / 583 liter Upright Freezer FFU2124D
I have a frigidaire gallery. I think it is a GLFU206FWA upright freezer. but cannot find a model # or size. It no longer gets cold. Alarm is on and it stays the same temperature no matter where the thermostat is set. Coils are clean and no water. Is it the thermostatT If it is, how difficult is it to change?
    President:
  • 1,554 Answers
Enter Service Diagnostic Mode to determine the exact cause of the problem. Place the control in the lock mode by pressing and holding Control Lock key for 5 seconds then press and hold the Up and Down keys simultaneously for 5 seconds. When diagnostics mode is entered, the following information will be displayed for two seconds at a time then exit automatically when done.
Three short confirmation beeps are issued then the left digit displays “8”, turns off then second digit displays “8”. The following LEDs are illuminated: (-), (ºC), (ºF), (HRS), (Door Ajar), (Power Loss) then turn off after 2 seconds. The following LEDs are illuminated: (Hi Temp), (Duration), (Quick or Extreme Freeze), (Control Lock) then turn off after 2 seconds. Door Switch Status with tone (“dO” or “dC”) then displays “ld” with tone and then displays model ID.
Displays “5F” with tone, “00”, then the Software Version #. The thermistor status is displayed with tone , “tO” for open and “tC” for closed or “--” for a good thermistor. Enters Load Test mode for 10 seconds. Press Down key then displays “HE” and turns on heater. Press Up key then displays “CP” and turns on compressor. Press Temp Display key then displays “LA” and illuminates cabinet lamp.
Posted on Aug 06, 2010
What number should i set the upright freezer control
Thank you for your inquiry, friend!
Normally it is recommended to set your Frigidaire upright freezer to zero degrees. It is your option to make it cooler if you choose too. I hope this information has been helpful. -Matt
Oct 15, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Freezer is 11 years old. Alarm has gone on and freezer is not very cold. Has it died or can it be fixed?
Hi there. I really think it could be a thermostat or a small fault. But jump on Google to look for faults with that model. Let me know how you go
Jun 02, 2014 | Frigidaire 20.6 cu. ft. / 583 liter...
My Fridgidaire upright Gallery freezer is freezing my food but the appliance seems to be constantly running and the temperature control on the outside is reading 29 Celsius when it obviously isn't
Hi Susan Abboud - Modern freezers have increased storage capacity and keep more even temperature that may require the compressors to run longer but use less energy. Was the unit disconnected previously for any reason? If so, freezer requires a minimum of 4 hours to cold down completely. Confirm that the temperature control is not set too cold and that the door is not being open frequently. A dirty, cracked, worn or poorly fitted door gasket can allow warm air to enter the unit causing it to have to run longer to remove the warm air. Leaks in the door seal will cause freezer to run longer in order to maintain desired temperature. Cleaned the gasket, if it is too damage then it will need to be replace. You can check and see if the door seal is bad by, placing a dollar between the gasket and cabinet. Check to see if the door is being blocked by anything stopping it from closing properly. If nothing is stopping the door then replace gasket. Keep in mind that there should also be at least 4-6 in of air space on all sides of the unit. If freezer is built in or has items stored on top that cover the unit, the can cause long run times, high temperature in the freezer and premature failure to the unit. Do not block the toe grille on the lower front of the unit. Sufficient air circulation is essential for the properly operation of your freezer, about 3 inches around the unit.
Nov 22, 2012 | Frigidaire 20.6 cu. ft. / 583 liter...
Frigidaire upright frostfree freezer stored several years unplugged, restored power last night alarm keeps ringing and freezer is not getting cold.
Clean the unit entirely, coils, filter, etc. Then retry. You might have a faulty control board since it has not been used in many years. All depends on the location and humidity. That can tear up a thermostat and control board.
Jul 28, 2012 | Frigidaire 20.3 cu. ft. Upright Freezer...
I have a Frigidaire upright freezer model# ffu20f9gw3. The temperature alarm light is on. Cold air is blowing but the ice cream melted, and the hot dogs are still frozen and loaves of bread that i...
I have had the same problem with my frigidaire/electrolux upright freezer... I am researching to see if there is a pattern. Once or twice a year for the past few years, the freezer defrosted itself. I found the outside of the unit to be VERY hot to the touch around the time that this occurred.
We typically unplug it for a chunk of time when this happens and then replug it. It has always begun working again.
Sadly, we have lost many groceries and have had to clean many bloody meat messes as a result of this. ANYONE buying this freezer should save their receipt... That way, they can return it or have it repaired when it fails. I hate to think of sending all of these failing monstrosities to the landfill... =(
Aug 13, 2010 | Frigidaire Freezer 20.3 Cu. Ft. Frost Free...
I have a Frigidaire model GLFU206FWA upright freezer. The temperature control won't go above 10 degree F. This causes freezer burn on some foods after a period of time. Is there a way to regulate the...
Good day,
Manufacturers of freezers do not give the option of running the machine much above that temperature. Normal operating temperature for a freezer is about -2 to about 8 above F.
Otherwise people could accidentally set the temp too warm and cause a loss of food.
Some appliance parts houses carry universal thermostats that could possibly cover the temperature range your looking for, but 30 degrees is far to warm to preserve frozen food safely.
Jun 21, 2010 | Frigidaire 20.6 cu. ft. / 583 liter...
20.3 cu. ft. Upright Freezer GLFU2067F: We have an upright frigidaire 20 cu feet that is a...
Sounds like frost bulidup from door being left open warm air gets in making frost and ice. Need to turn off for 24hrs or so to let all the ice melt compleatey then turn back on keep door closed run for 24hrs check Temp. shoud be about 0 to -5 Deg. if good start using.
May 17, 2010 | Frigidaire 20.3 cu. ft. Upright Freezer...
Frig no longer cold
Hi, look inside freezer and see if there is a frost build up on the rear wall. Also listen to see if the evapotator fan motor is running.
Please let me know so I can assist you further.
Vic
May 27, 2009 | Frigidaire Freezer Refrigeration White...
Frigidaire 20.6 cu. ft. / 583 liter Upright Freezer FFU2124D Logo
87 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
