I have a SamsungHL-R4667W DLP that the pitcher just freezes and then shuts down and turns on by it self,also at the same time I could not use volume, chang chanels or shut off or turn on. I replaced the Lamp and that did not work
  • gkhanifan Apr 27, 2008
    How do you chang the systemboard and were would i buy one.
  • 758 Answers
Your problem is either your lamp or your ballast. When was the last time you changed your bulb?
Your fist best bet is to buy a bulb to see if it fixes it, if not you dont lose much because you ALWAYS need a backup..
My recommendation as usual is discount-merchant.com... Here is the link to the lamp that would most likely fit your tv:
http://www.discount-merchant.com/Philips-Lamp-Adapter-Convert-your-your-DLP-p/ne w_samsung_plus_pla.htm
If that doesnt work check the digital board or the DMD board?
I hope that helps
Please rate acordingly
Thank you
Computerrep
Posted on Apr 27, 2008
  • Jean Sintulaire Apr 27, 2008
    If it is out of warranty it is on you to fix. You can search for a DMD board on ebay to maybe find one used for cheap
    The part number for your TV is the BP96-00678B
    President:
  • 3,130 Answers
I'm afraid that you are suffering from a common fault with this TV set. They also have a nationwide backorder for your part. it is called the DMD board and I am sorry to say it cost about a grand. This is the site where you can see the info on the DMD board.http://www.samsungparts.com/part_detail.asp?catalog%5Fname=Parts+and+Accessories&product%5Fid=BP96%2D00678B&search%5Fmodel=HLR4667W
Good luck.
Posted on Apr 26, 2008
    Genius:
  • 3,587 Answers
Sounds like a control board about to fail, to me..you handy enough to replace a main system board? not under warranty, right?
  • Patrick Michaels
    Patrick Michaels Apr 27, 2008
    now, that's what I call a management level decision..hope this turns out well for you
My lamp burned out and I got the replacecent lamp from samsungparts.com, but the housing didnt fit into the tv. So I put the new lamp in the old housing, after verifying the lamp was the correct part...
According to an aftermarket lamp manufacturer, there are 2 different lamps (1st and 2nd generations) available for the Samsung HL-R4667W, but only one of them will actually fit. The lamp that is commonly associated with this model, BP96-00826A, is used in housing that has a silver bump protruding from the opposite side as the front face of the bulb itself. The other type, BP96-01073A, is placed in a housing that has a smooth back face and a overall larger bulb. I can verify that the HL-R4667W that I own seems to have the second type of lamp.
As long as you didn't open the housing of the lamp that you purchased to try to install the lamp in the housing that your TV came with, you might still be able to request an exchange from samsungparts.com, given the circumstances.
Jan 11, 2011 | Samsung HL-R4667W Rear Projection...
Why won't my Samsung HL-R4667W DLP tv turn on?
Theres a cover on the back that is vented w/4 screws on like the corners,also theres a symbol that looks like a "T" on it,take that cover off and right behind the symbol "T" an arm like plastic piece is what hits a lever inside when then cover is installed ,flip that little blue lever up and down a couple of times with the set unplugged reinstall cover making sure the "T" is in the position to hit the lever and tighten not too tight.
if this don't work it may be your colorwheel.Good Luck!
May 27, 2010 | Samsung HL-R4667W Rear Projection...
I have a Samsung DLP 50" TV (HL-R4667W) that has been nothing but trouble. The bulb has to be replaced about every 6 mos or the set turns itself off. I believe there is some other problem other that the...
If the color wheel is the problem you can generally hear a high pitch whine coming from the TV. If it is seized the lamp will ignite for a few seconds and then shut off.
The ballast is only used to ignite the lamp, it shouldn't cause the TV to turn off once it is on.
Since the TV shuts off after it is on I recommend the following:
1st - The lamp cover has a safety switch. if the lamp cover is not pressing on the switch, the TV will turn off after random periods of time.
2nd - The other thing to check is the fan for the Lamp. If the fan is seized or spinning slowly, the lamp will heat up and trip the thermal protection switch. Once that happens the lamp is super hot and could rupture while cooling down.
Sep 09, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung DLP TV HL-R4667W. When turned on, the TV comes on normally. Within about 10 - 20 seconds, the screen goes blank, can hear the sound for another couple of seconds, then can hear a relay trip, and...
Those lights flashing mean the lamp is the issue. You need to test it with a meter. If the lamp tests ok then it may be the ballast is bad and that is what powers the lamp.
Oct 12, 2017 | Televison & Video
When I power the TV on there is no picture, the lamp light is flashing, and there is a squeaking noise coming from there rear of the TV. It kind of sounds like a wheel turning and rubbing against...
The squeeking sound could be the high voltage trying to strike the lamp, it will try several times to strike the lamp then shutd down. Take the bulb out and see if it s blown. Even if it is not blowen it sounds like you have a bad bulb.
Sep 01, 2009 | Samsung HL-R4667W Rear Projection...
My tv plays about 1-1/2 hours then shuts down
YOU WILL NEED TO REPLACE YOUR PROJECTOR LAMP #BP96-01472A AND THIS SHOULD RESOLVE YOUR ISSUE.
HOPE THIS HELPS
Jul 07, 2009 | Samsung HL-S5087W DLP TV
Picture wont come on, makes noise like it is on, but no go
when u plug the set in does it make a whinning noise or a poping noise. this might be a lamp or a color wheel stalled.
Jun 16, 2009 | Samsung HL-R4667W Rear Projection...
HL-S5687 DLp tv
your keeping a part that is warming up and shuts down your shutdown that protects the tv from burning up... cooler... to find this you might need a hair dryer or a can of freeze mist.
I believe the left side is your high-voltage section.
you can also let it warm-up without the fan .. let it shut down and feel parts with set unplugged to see what is running hot.
Oct 22, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung Projection TV
You need to take out the DMD bord and open it up then remove the DLP Chip very carefully and blow out under the chip and all the components in the box with dry air something with a dryer on it then reassemble the chip on to the bord and make sure that the three screws that holds the mount that houses the chip are snug then you will need to put the Bord back in and have someone Else watch the pitcher so you can center the pitcher. This happened to me with my samsung tv and ran across this in sum service notes for this problem. Hope this helps
Dec 22, 2007 | Samsung HLN5065W 50" Rear Projection...
Bightness Change
It sounds like your lamp is going bad. The lamp part number is listed as "lamp code" on a sticker located on the left side of the set. Use this number to grab a replacement off ebay.
Dec 20, 2007 | Samsung DLP HL-P5663W 56" TV
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
