Question about Makita BO5010 5" Random Orbit Sander
I need a new pad ours is worn out. makita 0125mm B05010 120 volts 532117A 8 wholes.
  • 34 Answers
Buy from one of the many on-line parts sellers. Or do a Google search and you'll find hundreds.
Posted on Aug 10, 2010
MAKITA HMO870CUSER MANUAL
According to the manual, "The red service indicator lamp flickers up when thecarbon brushes are nearly worn out to indicate that the tool needs servicing. After approx. 8 hours of use, the motor will automatically be shut off."
Apr 24, 2014 | Makita Drills
I have been using a Makita random orbit sander model BO5010 for years without problems until I replaced the pad with a Porter Cable 13910, sold as compatible. Now the sander takes off, ie: increases speed...
HI, i have a feeling the pad could be the issue there. The genuine Makita one is designed for the motor, so unless the the replacement is exactly the same thickness, diameter, and weight then you will have problems. Imagine putting a small wheel designed for a car on a truck, that kind of issue. Best thing to do is to try putting the old Makita pad back onto the machine and see if that make any difference. (that is if you still have it) At work we have had similar problems where we have used non-genuine circular saw blades onto our Makita saws, and its has burnt the motor out.
Jan 13, 2011 | Makita BO5010 5" Random Orbit Sander
Hi, my BO5010 spins like a grinder if it is not held tightly to the workpiece, can it be fixed? Thanks, Ope.
Just under the sandpaper pad is a bearing that allows the pad to work as an orbital, that is it can turn freely, independently of the armature. If enough sawdust builds up around or inside this bearing the pad will spin like you describe and this is a fairly common problem with orbital sanders. You need Makita part number 211236-8 or a bearing #6002LL. It's fairly easy to replace; remove the screw in the center of the pad and remove it. Depending on which is tighter, the bearing will either be in the back of the pad or it will stay on the armature. Pry it off/out of the sander. Reassemble everything with the new bearing and you'll be back in business.
Dec 30, 2010 | Makita BO5010 5" Random Orbit Sander
Drill will not turn but will you can here a grinding sound. Drill will turn when done by hand. Drill has not been run for over three years.
The gears are worn out,take it apart to verify. They need to be washed out with mineral spirits and greased if okey,otherwise they wear out the gears
Buy a new one on--- Tool Barn.com
Best prices for Makita
Nov 06, 2010 | Makita 6402 3/8" Drill, 5.2 AMP, 0 - 1,200...
New 4" angle grinder does not come with sanding disc pad
You need the 4" rubber pad, Makita Part #743009-6. It can be found on websites like www.ereplacementparts.com.
May 23, 2010 | Makita 9553NB 4" Angle Grinder
Between us my son and I have 10 18 volt batteries for our Makita power tools which we use in our Carpentry work of these 10 batteries 6 have failed. I have to say the reliabillity of the Ni-cad equipment...
Join the battery collectors club. I have 25 batteries, 12 guns, I quit buying the batteries, I found it cheaper to buy the gun with new batteries and charger once a year. Cause they don't even last that long. I have tried different brands too all the same. Got batteries?? Sure do.
May 15, 2010 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Need to change felt pad on Makita finishing sander model #BO4552
go to Makitausa.com and type in your model number and you can download a schematic for the tool. Let me know if you can't find it or need more help
Aug 08, 2009 | Makita BO4552KR Reconditioned 1/4 Sheet...
I bought a new highter current ni cad for my makita; however, the
As long as the charger voltage and the battery voltage match (7 volts) there should be no problem. A fast charger just runs more current thru the battery (per unit time) than a not-so-fast charger. If you notice the battery getting really hot when it's charging (like too hot to touch), stop using it.
Apr 28, 2009 | Makita 6019DWE 3/8 Cordless Drill Keyless...
Makita BO5010 5" Random Orbit Sander Logo
171 people viewed this question
Top Makita Tools & Hardware - Others Experts
Jim Thurston
Mike Squire
John Trevino
Are you a Makita Tool and Hardware - Other Expert? Answer questions, earn points and help others
