Question about Planet Audio AP1000D Car Amp
Wehen I turn the volume up my subs destort and it seems like my subs are bogging down..I have 2 kicker comp 12 vrs
If they are 4 ohm dual voice coil wire them to 1ohm and bump do not turn gain all the way you will fry the amp and if you really want to make them kick . write each 1 to 2 ohms and get another amp they are not getting enough wattage for the volume you are trying to run them at and could be the way you have it tuned .
Posted on Mar 22, 2011
Speaker blown?
disconnect the amp and do a "pop" test with a 9v battery, it should be clear and no rattle... if it rattles sub is blown
Jan 29, 2014 | Kicker Comp CVT 12 Car Subwoofer
2 kicker cvr 12's in prewired kicker box with 1 wire terminal, kicker cx1200.1 amp. Whats the best way to wire this combo?
Well you really can't run both speakers on one term. because you will over heat the amp , unless your amp is rated at twice the capability of your subs , Then if so , Try positive to one sub , then neg. to the other sub , then bridge the remaining positive to the remaining negative terminal , But it is really best to get a two channel amp for your subs !!!
Sep 23, 2013 | Kicker Comp CVR 12 x 12 Car Subwoofer
Kicker comp 12'' subwoofer swingarms snapped
when you say swing arms i assume you are talking about the wires connecting the terminal (where you connect the wires to the sub) to the voice coil (the center of the sub).
If these are broken it is tricky to solder new wires back on. If your sub is still under warranty i would suggest sending it back to them. below is there number and business hours.
Kicker Customer service Email: Warranty@kicker.com Phone: $05-624-8510
Aug 23, 2012 | Kicker Car Audio & Video
I need to know what to put the frequency at for my subs... they are 2 12" kicker comp's
40 - 45 Htz is the usuall. It really depends on the music you listen to. They are built to handle a little more mid bass. Where they are located, power supplied, direction the subwoofer is facing will all have an effect on what you need to set it at. My suggestion is follow the basic steps in setting up your amp. 1. turn your amp gain all the way down. 2. turn your radio volume to 75% of max. 3. start turning up the gain until you obtain the sound you want. You want to do this so your don't "clip" the sub. Kicker is good, but the comps can only handle so much before they start popping. This will heat up the voice coils quickly and cause them to fail prematurely. Hope this helps.
Jul 31, 2011 | Car Audio & Video
I have a alpine MRP-M500 amp connected to 2 10 inch comp kicker subs. The problem is the subs rattle and distort. The subs have been tested ok and all the wiring has been tested also ok. What could be...
Any time that there is a rattling sound from the subs, that indicates that they are probably blown. How were the subs tested ok? If the resistance of the subs is still close to OK, that is good, but it doesn't necessarily indicate that they are working properly.
Try using different subs at a lower volume, or turning down the gain slightly.
Mar 11, 2011 | Alpine MRP-M500 Car Audio Amplifier
My sub woofer will stop working if i put the bass up to loud, ill have to turn my car off and on to get it to work again. What could be the problem?
Seems like your power amp for the sub woofer may be going into protect mode/thermal overload when you push the volume too much. Therefore it shuts down. I am surprised the speaker hasn't blown yet.
As far as turning car off/on to get it to work, it's as if your car is the power switch.
Amp and speakers may not be wired correctly, as you want to make sure your amp/speaker ohm measurements are within a specific range for the amp and speakers work together properly. You may have it wired for a 2 ohm load, and maybe your amp can't do 2 ohms all day long.
Apr 09, 2010 | Kicker Comp DC12 2-ohm Enclosed Subwoofer...
Need help.. I have two 12 inch dual voice coil kicker comp vrs.. they are 4 ohm subs..how do i wire them to get a final ohm load between 1.5 to 4ohms in a dual enclosed box...Im hooking them up to a jl 500...
To do this they MUST be wired in parallel, IE: Plus to Plus, Negative to Negative. 2 4 OHMS in parallel is about 2 OHMS in series it would be 8 OHMS... series is positive to negative. Are you using a crossover network?
Mar 05, 2010 | Kicker CVR12 Car Subwoofer
I have a 12 kicker sub and a 600 wt power acoustic
there is a volume on the amp try that and the settings on your deck allow you to adjust your subs
Jan 15, 2010 | Kicker Car Audio & Video
Kicker compVR 12
get a ground loop isolator. and another set of rca's or just run the power wire on the other side of the car let me no if that helps please rate if help full or not
Sep 18, 2008 | Kicker CompVR 05CVR84 Car Subwoofer
Blinking protection light on mrv-t757 amp
Could be the power supply or output stage electrolytic capacitors.
Possibly breaking down/drying out inside.
Mar 17, 2008 | Alpine MRV-T757 Car Audio Amplifier
Planet Audio AP1000D Car Amp Logo
42 people viewed this question
Top Planet Audio Car Audio & Video Experts
michael galang
Robert Rankin
Are you a Planet Audio Car Audio and Video Expert? Answer questions, earn points and help others
