Question about NRS Hoveround Technique Used Electric Wheelchair
Will this model fold down and fit into a van?
    Novelist:
    Champion:
  • 232 Answers
You can release the lever on the side of seat back to fold the seat back forward to that is lays flat on top of the seat bottom. That should give you clearance to transport the power chair inside of a standard van.
Posted on Oct 05, 2010
2nd Row Headrest Stuck in Upright Position and will not Fold for Stow n Go
You will need to take the seat apart to determine what is not fastened to release it.
Apr 09, 2014 | 2011 Chrysler Town and Country
Fold down handle to fit in car
Down behind the back wheels should be knobs on each side for folding. The handle will fold down on either side of the mower on top of the deck. var geo_Partner = '1890d1e7-e721-4f9c-b474-1a19eda23e94'; var geo_isCG = true;
Aug 18, 2011 | Toro Lawn Boy Self Propelled CARB Walk...
To remove 1993 mustang conv. top cylinders should top be up or down? thanks, bill
don't have 93. here's 94
Motor Assembly, Convertible Top Removal and Installation
NOTE: The folding top hydraulic cylinder rods should be in the fully retracted position.
Use absorbent rags or a container to catch any hydraulic fluid that leaks out when removing the fittings.
  1. Remove motor and pump assembly as outlined.
  1. Loosen each folding top motor upper and lower hose fitting on the sides of the folding top hydraulic lift motor and plate kit (533A00) .
  1. Remove the folding top hydraulic lift motor and plate kit .
  1. Remove each of the service folding top hydraulic lift motor and plate kit plugs one at a time and attach the tee fitting to the replacement folding top hydraulic lift motor and plate kit . NOTE: Make sure that the o-ring is installed in the bottom of each folding top hydraulic lift motor and plate kit port before attaching the hose tee fitting.
  1. Connect the folding top hydraulic lift motor and plate kit unit to a 12-volt power source and cycle the folding top hydraulic lift motor and plate kit in and out several times to purge the air from the folding top motor upper and lower hoses (53390) . Some noise squeal may be noticed due to the air. srb~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not overfill or the reservoir seal could be blown out.
  1. Carefully remove the rubber fill plug from the back and the reservoir and check the fluid level. The level should be at the bottom of the filler hole. If necessary, add Synthetic Mercon® Multi-Purpose Automatic transmission fluid E6AZ-19582-B (ESR-M2C163-A2) or equivalent.
  1. Replace the fill plug with a new fill plug.
  1. To install, reverse Removal procedure.
Section 01-17: Convertible 1994 Mustang. Workshop Manual
REMOVAL AND INSTALLATION Lift Cylinder, Power Top Removal and Installation
NOTE: The cylinder rods should be in the fully-retracted position.
  1. Remove pump and motor as outlined.
  1. Remove the upper and lower hose fitting from the folding top hydraulic cylinder (50600) . Use absorbent rags or a container to catch any hydraulic fluid that leaks out when removing the fittings.
  1. Remove each of the service cylinder plugs one at a time and attach the hose fittings. NOTE: Be sure each fitting is installed in the correct position on the folding top hydraulic cylinder .
    NOTE: Make sure that the tetra seal is installed in the bottom of each of the folding top hydraulic cylinder ports before attaching the upper and lower hose fittings.
  1. Connect the folding top hydraulic lift motor and plate kit (533A00) to a 12-volt power source and cycle the folding top hydraulic lift motor and plate kit in and out several times to purge the air from the hoses. Some noise squeal may be noticed due to the air.
Jan 21, 2011 | Ford Mustang Cars & Trucks
Stylus - Morocco Travel System Stroller: how do you fold stroller down to fit into car?...
please help me i really need your help on how to fold it down i am only 9 and i need to fold it down . i have this pram cause i have a dolly called sophie
May 05, 2010 | Graco Stylus Morocco Travel System...
1987 GMC VanDura electric fold-down seat
If it's anything like my 1994 Vandura, you have a small panel of rocker switchers above the rearview mirror for turning your interior lights and other gadgets(tv, vcr, etc) off and on.
The leftmost switch on mine moves the electric bench seat up and down, *and* forward and back. The trick is that you have to hold it down to make it move.
With mine, even though there are four actions:
- slide seat forward
- slide seat backward
- fold seat down
- fold seat up
there is only one rocker switch.
So what you do is hold "up" on the switch and see what it does. If it slides the seat in either direction, up for your van is for both sliding forward *and* back. To do the opposite direction, just wait a second then press the same button the same way a second time.
If up makes it fold, it's the same principle. Hold the rocker switch depressed in the up position to make it fold up. Wait a moment and repeat to make it go down.
It wasn't intuitive for me either but once you know and play with it a bit it makes sense. Probably better than having four switches up there anyway :)
Jan 26, 2009 | 1987 GMC VanDura
Just got an 2002 Chrysler Voyager. I can fold down the rear bench seat using the black lever on it but can't find a lever, or other release device to fold down the middle bench seat. How can this seat be...
i dont think they were meant to fold down but you should be able to take them out to haul bigger items. some of the vans they make are made that way so that you have to remove the seats rather than fold them down
Dec 06, 2008 | Chrysler Voyager Cars & Trucks
NRS Hoveround Technique Used Electric Wheelchair Logo
115 people viewed this question
Top NRS Health & Beauty Experts
Colin Taylor
wcdoc1953
wcdoc1953
Are you a NRS Health and Beauty Expert? Answer questions, earn points and help others
