Question about Haier Portable DVD Player PDVD7
How long is the battery charge last? - Haier Portable DVD Player PDVD7
After fully charged battery power lasted about 20 minutes.
Since it's brand new, return it. You didn't say what type of tablet it is, but they should last for many hours on a charge.
Oct 02, 2015 | Tablets & eReaders
Battery charger reads battery full when dead
The battery is no longer good. You will need to buy a new battery. Don't over charge your batteries. They all vary. Expensive cordless tools will come with a charger that shuts off automatic to prevent over charging. I own cheap Skill drills that has served me well. These batteries lasted over 11years. It makes no sense. They should not have lasted more than 5 yrs., even 2yrs. I make sure I never over charged them, but they should not last that long. Freaky. Your battery is dead forever, sorry. I have others just like yours waiting to be recycled.
Sep 29, 2012 | GRACO INC TrueCoat 18V Lithium Ion Battery...
After charging d battery when we remove cabele
the battery sounds like it has bad battery memory and needs to be replaced. Before you replace it look for software to give you the battery's status (how much charge it holds out of how much it should hold by design. for exaple i am using ubuntu linux and my battery reads
Capacity: 29% (Poor)
Current charge: 14.3 Wh
Last full charge: 14.3 Wh
Design charge: 48.8 Wh
Charge rate: 10.0 W
now that is my bad battery for staying at home and leaving it plugged in all the time (that kills the battery) i have another battery that reads
Capacity: 97% (Good)
Current charge: 38.8 Wh
Last full charge: 47.5 Wh
Charge rate: 5.5 W
it is my battery for travel. the difference between the two is that the battery that reads Capacity: 29% (Poor) only lasts about 40 minutes but the battery that reads Capacity: 97% (Good) lasts 3 hours. you probably have a low Capacity.
Jul 29, 2009 | Adapters.com Computers & Internet
LG Viewty battery discharges quickly .....
Charging duration does not connect to battery lasting duration in any way.Optimal charging time is 3 to 4 hours.your battery will drain soon if you keep your touchscreen pressed continuously in your jeans pocket.Keep bluetooth switched off. Reduce the brightness of your mobile display. Play music threw headphone rather than using loudspeakers.
Jul 19, 2009 | LG KU990 Viewty
Battery stopped charging
Yeah It Sounds like the battery is just had its last charge they only last for about 300 charges a piece i would get a new one go for at least a six cell they will last longer...Let me know if this works for you.
Apr 20, 2009 | Acer Aspire 3690 Notebook
Battery charge
Dave you are correct. You should never over-charge anything like a Roomba, Cel Phone, etc. That will kill a bettery very quickly.
Jan 11, 2009 | Roomba Robotic Floor Bagless Vacuum
Loss of charge on 91 loyale station wagon
the regulator is in the alternator. it sounds like it isn't charging the battery anymore. battery voltage should be around 14 volts with engine running. also check connections at alternator to battery. have seen corrosion here keep the battery from charging
Aug 04, 2008 | 1991 Subaru Loyale
HS850 charge doesn't last long
Sounds like you've got a defective model. Mine lasts about 4-5 days before I have to charge it.
Apr 10, 2007 | Motorola Mobility HS850 Consumer Headset
Haier Portable DVD Player PDVD7 Logo
Top Haier Televison & Video Experts
Jaime Hernandez
CoppellTVRepair.com
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
